busdaddy Samba Member
Posted: Sun Apr 02, 2023 4:48 pm Post subject: Re: The Stupid Question Thread |
Something funny going on there, all bays use that hard white plastic plug, it grew a few terminals in 72 when the heater levers sprouted a booster fan switch, but 68-71 used the one you show earlier. The flat yellow(ish) vinyl spade blocks were used on signal and ignition switch connections.
Time to follow some wires and see where the mystery leads you..... _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Sun Apr 02, 2023 5:17 pm Post subject: Re: The Stupid Question Thread |
W1K1 wrote: |
this picture shows 73 8 pin connector
That's the same as on my '71, and presumably yours too.
Notice the legend on the '71 bus wiring diagram says
"T6 - Cable connector, eight connections" _________________ '67 bug: seized by the authorities
sebgi1 Samba Member
Joined: September 19, 2005 Posts: 169 Location: Quebec, Canada
Posted: Mon Apr 03, 2023 2:16 am Post subject: Re: The Stupid Question Thread |
The heater connector plug goes directly behind the timer knob. And, yes for the 8 pins plug you should look for the missing half…somewhere in the nest _________________ SEB
Dogs are the most precious and valuable possession of mankind. VWs are second!
'73 Neptune blue safare camper
'71 Neptune blue tintop |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Mon Apr 03, 2023 2:02 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
Time to follow some wires and see where the mystery leads you..... |
You're right, the connector was in a bag, I looked back at photos of when I pulled the harness out that goes to the back, and there it was.
the good news is the harness can take 7 more wires and get re-shrink wrapped and still fit in the stock body tube, just barely but I'm happy with the extra capacity for gauges and switches. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Hubster43 Samba Member
Joined: June 03, 2013 Posts: 43 Location: Northern CA
Posted: Tue Apr 11, 2023 9:21 am Post subject: Re: The Stupid Question Thread |
Our 76 Westy has been purring along for the most part lately, but twice it has died totally as we were just driving along. I believe I have chased the problem back to the ignition switch on the steering wheel since if I nudge the key a bit the bus will start back up. The second time it died, I did this as we coasted along and it started right back up. A VW mechanic mentioned to me that there is a ring inside the switch that wears out and I just need to replace that. I have checked schematics to the best of my abilities and didn’t see anything like that.
On a similar note, I often see the reference to bypassing the switch by clipping a wire to the coil and somewhere else. I have tried to find a demonstration of this in case I ever have to do this in an emergency, but was unable to find. I thought this thread was perfect for asking for information about this process. |
Posted: Tue Apr 11, 2023 9:56 am Post subject: Re: The Stupid Question Thread |
Hubster43 wrote: |
On a similar note, I often see the reference to bypassing the switch by clipping a wire to the coil and somewhere else. |
There wouldn't be any such "schematics" of the internal mechanical contruction of the ignition switch (or anything else). Electrical
schematics only deal with the logical electrical connections of a device, not how they are materially executed.
Jumping the ignition just means connecting the #15 ("hot") terminal on the coil with a source of unswitched 12V power, such as at
the battery + terminal, or any wire connected to it. It's just a wire with a clip on each end. _________________ '67 bug: seized by the authorities
Posted: Tue Apr 11, 2023 10:25 am Post subject: Re: The Stupid Question Thread |
Hubster43 wrote: |
Find an authentic VW switch and install it. They are available sporadically, usually a very good price. |
OG Velvet Samba Family Man
Joined: February 24, 2003 Posts: 2168 Location: Portland, OR
Posted: Sat Apr 15, 2023 1:10 pm Post subject: Re: The Stupid Question Thread |
OG Velvet wrote: |
Pinch bolt stripped. Do you think this is my problem? The spring washer is good. |
What is the thread pitch for this bolt? Thx! _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
D/A/N Samba Member
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Sat Apr 15, 2023 2:54 pm Post subject: Re: The Stupid Question Thread |
flip the top spring over so the center part is _______ and clears the wheel cyl _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Sat Apr 15, 2023 3:25 pm Post subject: Re: The Stupid Question Thread |
Aftermarket parts, whutuya expect? I would be concerned if I couldn't install them so they're not rubbing on anything. What was wrong with the old ones? _________________ '67 bug: seized by the authorities
D/A/N Samba Member
Posted: Sat Apr 15, 2023 4:11 pm Post subject: Re: The Stupid Question Thread |
skills@eurocarsplus wrote: |
flip the top spring over so the center part is _______ and clears the wheel cyl |
Hmmm,,, I was going to say flip the bottom one, sometimes they rub on the hub when faced to the spindle. Trial fit the hub and spin it a bit, then look for rub marks, I'd rather have it touch the cylinder than make noise constantly.
Ain't aftermarket shit great!? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
D/A/N Samba Member
Posted: Sat Apr 15, 2023 8:46 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
Ain't aftermarket shit great!? |
true, now that you mention it I remember having to do that dance, and flipping a spring around. _________________
Jake Raby wrote: |
Brian wrote: |
Robert Givler Samba Member
Joined: March 16, 2014 Posts: 28 Location: Fairfield, Ohio
Posted: Tue Apr 18, 2023 7:17 pm Post subject: Re: The Stupid Question Thread |
Can anyone help me identify what is missing here? Specifically referring to the area where the fan shroud meets the heater box. Replacing the muffler and noticed this was missing. Not surprising as the tins have a lot of issues. Would like to replace what is missing before I put it back together. It is a 1976 Bus 2.0L Type 4 with I believe 73 or 74 heater boxes if that helps. Had a 1.7L in it when I got it that detonated shortly after.
_________________ 1967 Beetle / Lil’ Tud
1968 Double Cab / Black Pearl
1970 Single Cab / Big Tud
1976 Westfalia / Pickle |
Posted: Tue Apr 18, 2023 8:22 pm Post subject: Re: The Stupid Question Thread |
The covers are available, maybe through the Samba classifieds? they are side specific, a search should turn them up. The flaps and pins are available as well. |
Posted: Wed Apr 19, 2023 7:09 am Post subject: Re: The Stupid Question Thread |
Thanks Wildthings. Do you know what they are called. I have found several lists of the engine tin parts but they do not show that "cover." Are the flaps just called called Fan Shroud Flaps? _________________ 1967 Beetle / Lil’ Tud
Posted: Wed Apr 19, 2023 10:28 am Post subject: Re: The Stupid Question Thread |
Is this the correct one for the right? I found one for sale but it is listed for a 70-74 Porsche 914 1.7 to 2.0L.
Posted: Wed Apr 19, 2023 7:07 pm Post subject: Re: The Stupid Question Thread |
Robert Givler wrote: |
Is this the correct one for the right? I found one for sale but it is listed for a 70-74 Porsche 914 1.7 to 2.0L. |
Pretty sure the Porsche parts are the same as the VW parts. |
