The Stupid Question Thread
Page: Previous  1, 2, 3 ... 329, 330, 331 ... 361, 362, 363  Next
busdaddy
busdaddy is offline
PostPosted: Tue Jul 04, 2017 1:20 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Disko72 wrote:
busdaddy wrote:
KentPS wrote:
But I'm a little confused... She has an early bay Westy top, but a late bay body (hi lights, no step bumper). Did someone replace the pop top at some point? Or was it a bus assembled during a transitional production phase?
It looks like a 73, early top and mostly early interior on a later body, still has the gas door though.
AFAIK (and according to the PO ownership) she is a '72. She may have had some body work mid-70's, I believe the interior is orig. Motor rebuilt 10 yrs ago. However, as her 2nd owner, I would love any help in how I can identify which parts came from which year ie 72 or mid-late 70's.
Re the emblem there appears to be three unused drilled holes behind the current emblem besides the two current screws - 2 at the top and one at the bottom, so 5 holes total. Sticky tape might be the best way to adapt a new one. Any idea whether 7" emblem is the right size for a '72? Thanks for all the help friends!
That late nose used the small plastic emblem with 3 clips, the 4 holes might have been drilled by someone for the earler 68-72 metal version.
The 3rd digit of you VIN will tell you the model year, the M plate behind the LF seat will narrow down the fine details.
bbrowncods
bbrowncods is offline
PostPosted: Tue Jul 04, 2017 1:23 pm    Post subject: Re: The Stupid Question Thread Reply with quote
busdaddy wrote:
bbrowncods wrote:
Anyone know what the small black piece of tin is with the hole in it. It is mounted on the case just below the oil breather.
A spark plug wire clip goes in there.
Ahhhh... perfect. Thanks! I don't have any of those. I think I need three then.
obnoxiousblue
obnoxiousblue is offline
PostPosted: Wed Jul 05, 2017 4:54 am    Post subject: Re: The Stupid Question Thread Reply with quote
What size is the bolt that secures the headbanger to the underside of the top bunk in a late bay?
Mike
Schwing wrote:
Pretty sure that bumper is specifically designed for pushing bay bashers out of the way.
Again, M code unknown.
j.pickens wrote:
I haven't seen that much fiberglass tilted to the sky ever before.
1977 Westfalia Camper Pop Top | 2L F.I.
gotmeabus
gotmeabus is offline
PostPosted: Wed Jul 05, 2017 8:40 am    Post subject: Re: The Stupid Question Thread Reply with quote
I am having some kind of electrical trouble with my emergency flashers/ turn signals on my 75 bus/westy. It seems like the trouble started when I left my flashers on but killed the engine- and somehow didn't notice my flashers were on? Maybe they were on a long time or maybe they died when i killed the engine. I dont know. But since then, neither the emergency flashers or turn signals work. When I engage the turn signals with the switch on the steering wheel there is a sort of "buzz" and the dash light blinks really fast but nothing is happening on the actual turn signals. I have looked at wiring diagrams and my brain melted a little because I have no idea what I am looking at. It seems like it could be one of like 20 connections or fuses. Does anyone have any advice? Does this sound like a fuse issue or something else? All the fuses in the little box under the dash are in tact.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Wed Jul 05, 2017 9:02 am    Post subject: Re: The Stupid Question Thread Reply with quote
Sounds like the flasher relay.
busdaddy
busdaddy is offline
PostPosted: Wed Jul 05, 2017 9:47 am    Post subject: Re: The Stupid Question Thread Reply with quote
Start by making sure the hazard switch hasn't popped apart, you may have to squeeze the plastic part with the wires attached back into the body and secure it with a zip tie around the switch.
Tcash
Tcash is offline
PostPosted: Wed Jul 05, 2017 10:25 am    Post subject: Re: The Stupid Question Thread Reply with quote
Might be in here?
https://www.thesamba.com/vw/archives/manuals/1978westymanual.php
Tcash
Tcash is offline
PostPosted: Wed Jul 05, 2017 10:27 am    Post subject: Re: The Stupid Question Thread Reply with quote
lil-jinx Premium Member
lil-jinx is offline
PostPosted: Fri Jul 07, 2017 1:07 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I am about to start working with some gerson body panels,what is the green paint?is it primer or weld thru primer or do I have to remove it all before welding or top coating?
1968 Dune Buggy
1974 parts bus
wihr
wihr is offline
PostPosted: Fri Jul 07, 2017 2:04 pm    Post subject: Re: The Stupid Question Thread Reply with quote
It looks like zinc chromate to me. Standard undercoating foe aircraft parts.
WW
WIHR
1970 Campmobile "Van Ordinaire"
1972 Mercedes Benz 280 SEL 4.5 "Buttercup"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc
KentPS Premium Member
KentPS is offline
PostPosted: Sun Jul 09, 2017 8:21 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I look through the new Bay Window postings in the Samba classifieds quite often, even though I'm not looking for another one. I'm betting I'm not the only one who window shops, right?
After going through the hassle this past year of converting my '76 Riviera from carbs to FI to meet Calif smog requirements, I thought it would have been wiser to have bought a '75. In Calif, vehicles of model year 1975 and before don't require smog testing.
However, in the months I've been perusing the classifieds, I rarely find any '75 Westys, or any body style for that matter.
Harkening back to the mid-1970's, the US was going through an energy crisis. Gas prices were going up, supplies were low, long lines at gas stations, fuel rationing, etc. And that created another crisis...the Ford Pinto! Twisted Evil
Question During that period, were Bays not imported as much as in previous years? Is that why '75s are few in numbers? Question
-Kent-
1976 Riviera, my 1.7l FI chrome yellow VAN - "Chloe"
--> Whatever you do, have fun doing it! Smile
WildIdea wrote:
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. Its.... like driving a celebration!"
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Sun Jul 09, 2017 10:38 pm    Post subject: Re: The Stupid Question Thread Reply with quote
According to Ratwell's production figures from VW, 1975 was the lowest full-year production run (1979 was only a half year production due to Vanagon tooling) but not by much…
http://www.ratwell.com/technical/MSRP.html#count
I wildly speculate that because they are smog exempt in CA, they're more likely to get a shit aftermarket carb setup and parked when it doesn't run correctly. But that's totally guessing…
Robbie
www.airschooled.com
Three rules of troubleshooting:
1. Do the easiest thing first.
2. Don't rely on the guy before you. He was not able to fix the problem.
3. 90% of problems are between the driver's seat and the steering wheel.
Reverend
Reverend is offline
PostPosted: Sun Jul 09, 2017 11:43 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Could not find specific "windowless bay" thread so i'll ask some stupid questions here. I have 79 kastenwagen, and heard a rumour that these "run trough" models (sliding doors on both sides) are rare-ish. Anyone has first hand info about that?
Wildthings
Wildthings is offline
PostPosted: Mon Jul 10, 2017 4:07 am    Post subject: Re: The Stupid Question Thread Reply with quote
The move towards fuel injection may have seriously hurt sales. Fuel injection was not something the average person of the time would have looked fondly upon.
RBurn
RBurn is offline
PostPosted: Mon Jul 10, 2017 7:16 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Looking at a 68 westy popup camper. The question surrounds the roof. The rear oiece is missing, is this difficult to find? The front part of the fiberglass has the hinged part attached to the roof metal and seems right. There are two long rods? That are connected to the metal but seem to have no place to attach to the fiberglass shell. What is missing here?
The cots are stock and the rest of the rig is fabulous as well as the body work that was done by a local shop. It has all the westy interior that is id say a 8 out of 10 on condition. Has front window but not installed, unfortunately my phone batt died before interior shots.
[/img]
70 T2 Model 221
70 T2 Model 231
70 Karmann Ghia Vert
67 Beetle deluxe
busdaddy
busdaddy is offline
PostPosted: Mon Jul 10, 2017 7:28 pm    Post subject: Re: The Stupid Question Thread Reply with quote
[pics]
Too bad the phone died, some pics of the rocker panels from underneath looking outwards would be very useful, shiny paint doesn't indicate a good repair.
The prop rods should screw to the wooden frame in the top near the back, it's the same strip of wood the canvas staples to, it's sometimes rotted and missing, count on learning how to fiberglass if you have to fix that. The luggage rack is available used and fairly easy to find, there are also new ones offered by a seller here on TS.
Don't pull the trigger until the windshield is installed by the shop, if they F'd up the lower lip rust repair the glass may not fit now.
RBurn
RBurn is offline
PostPosted: Mon Jul 10, 2017 7:50 pm    Post subject: Re: The Stupid Question Thread Reply with quote
[pics]
Great, thanks for the information, the wood is solid and been glassed to the shell. Good info on the front window. I used to do body and paint and i hear what you are saying. Ill need to get serious and crawl all over it, but the work has been done and looks good. What under is a good question. The owner got it for rent due on a some commerical space he owns. He need to tell me if he wants to keep the project or sell. His daughter was interested, but you now how that goes, motor runs, basically stock. We will see. I wanted a popup so i may sell the 70 tin top westy and keep this and my 70 passenger bus.
Thanks again.
Rob
70 T2 Model 221
70 T2 Model 231
67 Beetle deluxe
GfunkBus76
GfunkBus76 is offline
PostPosted: Wed Jul 12, 2017 11:04 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Definite stupid question... What is the purpose of the tiny lightbulb in the turn signal housing? Is it a running light in addition to the main turn signal? Some kind of parking light?
I'll try a voltmeter on it soon but figured I'd consult the gurus.
Thanks in advance!
Gavin
1976 Westy - Customzation in slow-progress.
-8V TD swap
It Runs! -- http://youtu.be/kT5hOtwiOgk
And drives! - https://youtu.be/rVkoAgeOop0
obnoxiousblue
PostPosted: Thu Jul 13, 2017 5:25 am    Post subject: Re: The Stupid Question Thread Reply with quote
USDOT requires cars to have side marker bulbs. VW saw the exhausting turn signal housing as the easiest spot to put them. Even though there is the yellow reflector on he front door they were never intended to illuminate though many people have made them do so.
Mike
cv66seabear
cv66seabear is offline
PostPosted: Thu Jul 13, 2017 5:41 am    Post subject: Re: The Stupid Question Thread Reply with quote
Nice bus! I bought a replacement base for my right rear marker, but for the life of me I can't get it to attach, is there a trick to this? (from Jbugs). I'm thinking it's just because the gasket is so new.
Where did you get that front guard?
Thanks in advance,
Kent
"Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
2015 Passat 1.8T "Rudy"
Page 330 of 363
