The Stupid Question Thread
Page: Previous  1, 2, 3 ... 330, 331, 332 ... 355, 356, 357  Next
GfunkBus76
GfunkBus76 is offline
PostPosted: Thu Jul 13, 2017 9:39 am    Post subject: Re: The Stupid Question Thread Reply with quote
GfunkBus76 wrote:
Definite stupid question... What is the purpose of the tiny lightbulb in the turn signal housing? Is it a running light in addition to the main turn signal? Some kind of parking light?
I'll try a voltmeter on it soon but figured I'd consult the gurus.
Thanks in advance!
So I'm assuming they just duplicate the effect of the running light already on the turn signal?
Cheers!
Gavin
1976 Westy - Customzation in slow-progress.
-8V TD swap
It Runs! -- http://youtu.be/kT5hOtwiOgk
And drives! - https://youtu.be/rVkoAgeOop0
WestySteff
WestySteff is offline
PostPosted: Thu Jul 13, 2017 3:52 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Heeelp
I recently imported a 73' Westy to Norway from UK, the bus originally came from the U.S and was imported to UK in 2011.
today I changed the headlamps to European spec (so the glass reflects the light according to driving on the right-hand side of the road.)
I switched from a pair of Autopal H4's that was fitted in the uk in 2011 to a pair of brand new ones I got from vwbusshop.de, same brand, autopal, but for driving on the right side of the road.
Anyways, the problem I have is that when I pull the switch out to the first level my fuse for parking lights immediatly blows, and obviously, no parking lights. When I first tested the new right headlamp with my friend holding it, there wasn't any problems. When I screwed it in however, and tested it again there was a shortage and my fuse popped.
Any ideas? I used the same bulbs and everything, and the headlamp is fairly similar, the only thing different is that the relay for connecting up the parking lights into the lamps is slight longer, and reaches further in towards the body.
Everything was working fine before I changed headlamps, and I'm sure I've connected everything right, with the smaller connection for the parking light connected with the smaller cable connection etc. What could possibly had gone wrong?
busdaddy
busdaddy is offline
PostPosted: Thu Jul 13, 2017 3:57 pm    Post subject: Re: The Stupid Question Thread Reply with quote
WestySteff wrote:
.......the only thing different is that the relay for connecting up the parking lights into the lamps is slight longer, and reaches further in towards the body.........
Hitting the back of the bucket and grounding out perhaps?
WestySteff
PostPosted: Fri Jul 14, 2017 2:38 am    Post subject: Re: The Stupid Question Thread Reply with quote
Hmm, og thought of that possibility, we tried taping up the cables for he parking light but it didn't work,
Below is are pictures of my cables, as well as the new and the old headlamp.
WestySteff
PostPosted: Fri Jul 14, 2017 7:39 am    Post subject: Re: The Stupid Question Thread Reply with quote
Never mind, I figured it
Switched around the two cables For parking light, it was shortening out as soon as the lamp touched the chassis.
Tcash
Tcash is offline
PostPosted: Fri Jul 14, 2017 9:59 am    Post subject: Re: The Stupid Question Thread Reply with quote
RBurn wrote:
Looking at a 68 westy popup camper. The question surrounds the roof. The rear oiece is missing, is this difficult to find? The front part of the fiberglass has the hinged part attached to the roof metal and seems right. There are two long rods? That are connected to the metal but seem to have no place to attach to the fiberglass shell. What is missing here?
The cots are stock and the rest of the rig is fabulous as well as the body work that was done by a local shop. It has all the westy interior that is id say a 8 out of 10 on condition. Has front window but not installed, unfortunately my phone batt died before interior shots.
1978 VW Westfalia Repair and Troubleshooting Manual
https://www.thesamba.com/vw/archives/manuals/1978westymanual.php
Westfalia Pop Top
Tcash
Tcash is offline
PostPosted: Fri Jul 14, 2017 10:01 am    Post subject: Re: The Stupid Question Thread Reply with quote
cv66seabear wrote:
Nice bus! I bought a replacement base for my right rear marker, but for the life of me I can't get it to attach, is there a trick to this? (from Jbugs). I'm thinking it's just because the gasket is so new.
Where did you get that front guard?
Thanks in advance,
Kent
I popped the plastic pins off and drilled holes for screws and nuts to mount them.
Then over time, I would tighten them up a little at a time to compress the seals and suck in the cover.
Tcash
Tcash is offline
PostPosted: Fri Jul 14, 2017 10:12 am    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks in advance!
Cheers!
Side marker lights
https://www.thesamba.com/vw/forum/viewtopic.php?p=4104081#4104081
mark tucker
mark tucker is offline
PostPosted: Fri Jul 14, 2017 1:38 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Ill ask hear first...any body using the LED head lamps?
busdaddy
busdaddy is offline
PostPosted: Fri Jul 14, 2017 2:04 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Here's one: https://www.thesamba.com/vw/forum/viewtopic.php?t=661886&highlight=led+headlights
And 37 others from various forums: https://www.thesamba.com/vw/forum/search.php?searc..._chars=200
GfunkBus76
PostPosted: Fri Jul 14, 2017 2:55 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Tcash wrote:
Thanks in advance!
Cheers!
Side marker lights
Thanks TCash... always a wealth of answers. I tried searching, but it was hard to narrow down the terms and come up with an answer. Appreciate it!
Gavin
-8V TD swap
cv66seabear
cv66seabear is offline
PostPosted: Fri Jul 14, 2017 6:30 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I bought a set from Vintage LEDs. They fit very well and I bought the 4000 Lumens (the medium brightness) and they are bright. Very Bright!
We have a ton of deer around here, and the original headlights just weren't lighting up the road well enough.
I love how bright these are!
And thanks for the answer about the side marker Tcash!
"Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
2015 Passat 1.8T "Rudy"
WestySteff
PostPosted: Sat Jul 15, 2017 4:34 am    Post subject: Re: The Stupid Question Thread Reply with quote
One more stupid question...
Is there any left or right for fitting the headlights on a late bay? or can you just take them out of the pack and put them on? That is what I've done and they fitted fine, but I've heard you have to adjust the backplate or something for fitting it on one side?
cv66seabear
PostPosted: Sat Jul 15, 2017 5:51 am    Post subject: Re: The Stupid Question Thread Reply with quote
No right or left designation for headlights as far as I know. If you have a right hand drive bus, then there is something you have to do to aim them properly, but I imagine there is a thread for that.
D/A/N
D/A/N is offline
PostPosted: Sat Jul 15, 2017 10:48 am    Post subject: Re: The Stupid Question Thread Reply with quote
For a stock '70 bus motor, is the carburetor preheat hose from the air cleaner down to the stove pipe the same diameter (50mm) as the fan shroud hose or is it wider? Also, what's the correct length?
I'm nowhere near the bus, otherwise I'd check for myself!
RBurn
RBurn is offline
PostPosted: Sat Jul 15, 2017 12:31 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I'm nojwhere near the bus, otherwise I'd check for myself!
Same diameter as shroud , inside diameter is 50mm. Length is 21 inches, id get 25" to be safe.
70 T2 Model 221
70 T2 Model 231
70 Karmann Ghia Vert
67 Beetle deluxe
mechanicjay
mechanicjay is offline
PostPosted: Sat Jul 15, 2017 9:46 pm    Post subject: Re: The Stupid Question Thread Reply with quote
by Cyl #3...what the hell is this sensor? I found it hanging out when I pulled my engine tins today for cleaning.
1973 VW Riviera Camper - "Sunshine Daydream"
1981 Ford F100 - In family since new!
1983 Rx-7 - The Sports car.
2006 Jeep Wrangler LJ - The wife and kid mobile.
KentPS Premium Member
KentPS is offline
PostPosted: Sat Jul 15, 2017 9:49 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Temp sensor (TSII).
-Kent-
1976 Riviera, my 1.7l FI chrome yellow VAN - "Chloe"
--> Whatever you do, have fun doing it! Smile
WildIdea wrote:
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. Its.... like driving a celebration!"
AircooledHome
AircooledHome is offline
PostPosted: Sun Jul 16, 2017 10:55 am    Post subject: Re: The Stupid Question Thread Reply with quote
Alright I've got one.
My brother and I are doing a quick restore on his new project, 68 bay window. We got the trans installed from our donor parts bus a 69. All seemed fine until one Cv shaft mount out of one side seized, and shifting it into other gears or neutral didn't change it. Think of it as the whole rear backed up, cus we didn't have the wheels bolted to the axles.
Any ideas? Lol
'71 Deluxe Bus - http://www.thesamba.com/vw/forum/viewtopic.php?t=659421&highlight=
busdaddy
busdaddy is offline
PostPosted: Sun Jul 16, 2017 6:42 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Any ideas? Lol
Do you have an engine installed yet?, are the axles connected?
Page 331 of 357
