Kabasue Samba Member
Posted: Fri Jul 21, 2017 6:35 am Post subject: Re: The Stupid Question Thread |
asiab3 wrote: |
Kabasue wrote: |
What lube do people suggest I use on my steering knuckles, or is good old generic molly grease good enough? |
What do you plan on greasing? Do your ball joints have zerk fittings? Or are you asking about the spindle shafts where the wheel bearings ride?
Or do you have a Brazilian bus with king-pin front suspension?
Robbie |
The spindle shaft part of the steering knuckle the part the disk breaks ride on. _________________ Remember to get your VW spayed or neutered
71 SB convertible (Finally Finished!)
73 Transporter (next project)
73 Westy with a 411 engine (Finally Finished) |
xavnz Samba Member
Joined: August 16, 2015 Posts: 28 Location: New Zealand
Posted: Sat Jul 22, 2017 1:39 am Post subject: Re: The Stupid Question Thread |
marty_mcfly wrote: |
72 westy, rear wheel backing plate stuck. Took off the top bolt behind brake cylinder and two bolts above star adjusters. Looks like some kind of pin or bolt possibly broken off and certainly well-rusted in that third hole (at the vertex where the star adjuster housings converge).
Maybe this is a dumb question, but is that unusual? Can I drill that out?
I'm waiting on turtle-paced postal service for my Bentley manual, so please bear with me if there's something in there about this...
Yup, that's a pin, just drift it out from the inside, it should be pretty smooth but it's a tight fit and takes confidence if you've not seen one apart (took me a while to pluck the courage to whack it with a bfh). If you have the bolts out, you can probably just give the whole thing a tap to one side and it'll show it's colors. _________________ '72 Bay Devon, 1776 barrels in a TP with dual Weber 36IDFs, 009, and a cheap ass EMPI muffler |
Mr west Samba Member
Posted: Sun Jul 23, 2017 6:06 pm Post subject: Re: The Stupid Question Thread |
Sorry for robbing this thread, I'm new to Samba and need some help for the VW community. I've been working on my Westy for 3 years and finally have the motor somewhat working...almost drivable. My question is about electronic distrubtor. I switched from a 009 distributor to a SVDA . My new distributor has a hose hookup on the cap ... never seen this before. Help would be great . Also to the left of the fan housing there is another hose port that I'm not sure where the air is suspose to go. Thanks again for the help
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51131 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jul 23, 2017 7:00 pm Post subject: Re: The Stupid Question Thread |
Welcome!
That thing on the distributor cap is a vent, some aftermarket brands have them, nothing connects there, leave it alone.
The nipple on the left end of the fan shroud by the coil is the purge air supply for the charcoal canister, it connects to the end with the single larger nipple on it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jul 24, 2017 12:51 am Post subject: Re: The Stupid Question Thread |
Nice , awesome I'll plug it and won't mess with the cap. Thanks homes |
Posted: Mon Jul 24, 2017 4:54 am Post subject: Re: The Stupid Question Thread |
Next question, timing at idle . I set my timing with the light at 28degrees BTDC at 2500-3500 rpm. I let the motor idle dawn and attach the vacuum assist line to the carburetor and adjust the idle screw....what RPM should the motor be set at. All the reading I've found is anywhere from 900-950 rpm . I have a 1700 big bore.....not sure if that changes anything. |
Posted: Mon Jul 24, 2017 7:06 am Post subject: Re: The Stupid Question Thread |
850-950, it depends on where it seems smoothest and what suits your driving style, higher idle in warmer weather improves cooling too so consider that. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
lightice Samba Member
Posted: Mon Jul 24, 2017 8:14 am Post subject: Re: The Stupid Question Thread |
Did VW issue a workshop manual for early bays to dealers?
All I can find are bentleys with this front page:
But did they have those that came in binders or something that were for internal VW use?
I believe the 72-74 ones were orange in colour. |
Tcash Samba Member
Posted: Mon Jul 24, 2017 9:23 am Post subject: Re: The Stupid Question Thread |
lightice wrote: |
Bus service manual+Bus repair manuals |
westysmb Samba Member
Joined: July 06, 2017 Posts: 65 Location: San Antonio, TX
Posted: Mon Jul 24, 2017 9:32 am Post subject: Re: The Stupid Question Thread |
I'm looking to replace the brackets on my Westy bed because they're pretty worn and rusted in certain spots.
Is Bus Depot's "rear sofabed kit" the same as the 1970 Westy bed brackets?
this is what I'm looking at http://www.busdepot.com/98553 _________________ 1970 Westfalia with a late Sportsmobile top |
Posted: Mon Jul 24, 2017 9:40 am Post subject: Re: The Stupid Question Thread |
Ok last question for the day , do I adjust the valves at TDC or 7.5 BTDC? When I adjusted them before both valves were closed.....am I good? I believe I adjusted the valves when the valves were at 7.5 BTDC. Motor runs good but there's a little tapping not much out of the norm for a VW. |
Posted: Mon Jul 24, 2017 10:13 am Post subject: Re: The Stupid Question Thread |
Hi Tcash, I've seen that thread, and I know about the bentley reprints.
But was there such a thing as a dealer issued workshop manual?
Like the early beetle/split blue binder type, or the later 'orange' 74-78 type?
Or is the kenneth ball one as close as we can get? |
Tcash Samba Member
Tcash Samba Member
Posted: Mon Jul 24, 2017 3:27 pm Post subject: Re: The Stupid Question Thread |
I think it's this, :
(1) - the full title of the blue manual is "Volkswagen service manual. Hints on the repair and maintenance of the 1968-1970 model Volkswagen; station wagon, delivery van, pick up, double cab". [Wolfsburg, Ger., 1970] x, 332 p. illus. 28 cm
Volkswagen service manual (1) Volkswagenwerk Y 72188053 68-70[/img] |
Posted: Tue Jul 25, 2017 3:48 am Post subject: Re: The Stupid Question Thread |
I brought my number 1 piston to the top of the cylinder while on the pressure stroke adjust the valve accordingly. Then found out that the motor is set up to run at 7.5 BTDC so I went and readjusted the valves at 7.5BTDC and not at TDC.....do I need to move my pully mark to 0 TDC or can it stay at 7.5 TDC. This is a repeat question, sorry but every video and forum I've watched and read doesn't explain this much just says bring the piston to the top and looks at the valves to make sure they are booth closed etc. |
RBurn Samba Member
Joined: May 08, 2016 Posts: 115 Location: Northern Ca
Posted: Tue Jul 25, 2017 6:03 am Post subject: Re: The Stupid Question Thread |
Mr west wrote: |
Id suggest your own build/repair thread! _________________ 70 Karmann Ghia Vert
67 Beetle deluxe
62 Single Cab
70 T2 Model 221 *CARR FIRE Victim
70 T2 Model 231 *CARR FIRE Victim |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Tue Jul 25, 2017 8:26 am Post subject: Re: The Stupid Question Thread |
You turn the engine to tdc with #1 on the compression stroke,the rockers on #1 should both be loose,then you adjust the valves on # 1 ,then you turn the engine to bring the next cylinder to tdc and adjust that cylinder,
Do a search,lot of info here on valve adjustment. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Tcash Samba Member
Posted: Tue Jul 25, 2017 12:03 pm Post subject: Re: The Stupid Question Thread |
Mr west wrote: |
You do not need to move the 0 TDC (top dead center) mark that is on the pulley. 7.5* BTDC (before top dead center) is the static ignition timing. |
Tcash Samba Member
