The Stupid Question Thread
Page: Previous  1, 2, 3 ... 339, 340, 341 ... 355, 356, 357  Next
CanStan
CanStan is offline
PostPosted: Thu Sep 07, 2017 6:08 pm    Post subject: Re: The Stupid Question Thread Reply with quote
It's just cardboard tubing. The same stuff used on the engine from the fan shroud to the heater boxes only a smaller diameter. Maybe this would work?
http://store.concept1.ca/Preheat-Hose-26MM-ID-211255359-WW/
I recall it's just slipped inside the metal vent piece, and over top of the round metal tube at the other end. No clamps or anything that I can recall
busdaddy
busdaddy is offline
PostPosted: Thu Sep 07, 2017 6:14 pm    Post subject: Re: The Stupid Question Thread Reply with quote
26mm sounds too small, I recall digging through the universal preheat hose assortment at my FLAPS to find the correct size (90's GM IIRC), it exists, but it's not a VW part.
You are correct that there's no clamps, the valve jams into the nipple in the floor and the vent bolts down, the hose is just a slip fit between the two.
CanStan
CanStan is offline
PostPosted: Thu Sep 07, 2017 7:52 pm    Post subject: Re: The Stupid Question Thread Reply with quote
You're right! My mistake. I just went and measured some and they are actually 42mm ID.
hiwaycallin
hiwaycallin is offline
PostPosted: Mon Sep 11, 2017 1:13 pm    Post subject: Re: The Stupid Question Thread Reply with quote
How do I remove the distributor from my stock '78 bus? Is it as simple as loosening the clamp at the bottom all the way and pulling up? Or is there more to it? Thanks in advance!
busdaddy
busdaddy is offline
PostPosted: Mon Sep 11, 2017 3:25 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Leave the clamp on and remove the nut securing the clamp to the case, then pull up.
Tcash
Tcash is offline
PostPosted: Mon Sep 11, 2017 3:47 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Spray the hole under the clamp with some wd40, it will lube the oring and make it easier to slide out.
When the dist. is out. Don't rotate the engine CCW (counter clock wise) it can spit the dist. drive gear out and loose its timing.
Good luck
Tcash
hiwaycallin
PostPosted: Mon Sep 11, 2017 3:58 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks guys!
Convoy
Convoy is offline
PostPosted: Tue Sep 12, 2017 7:36 am    Post subject: Re: The Stupid Question Thread Reply with quote
Is the 78 metal filler hose (the long version that goes from filler neck to gas tank) interchangeable on a 74 bus that originally has the shorter metal filler hose?
busdaddy
busdaddy is offline
PostPosted: Tue Sep 12, 2017 7:37 am    Post subject: Re: The Stupid Question Thread Reply with quote
Yes.
Tcash
Tcash is offline
PostPosted: Tue Sep 12, 2017 10:27 am    Post subject: Re: The Stupid Question Thread Reply with quote
Fuel tank filler hose FAQ
Convoy
Convoy is offline
PostPosted: Tue Sep 12, 2017 12:38 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks. My intent is to buy a used longer filler tube from a later model so I may get a EFI return line welded into it (closer to the tank inlet). I know its a no go on welding on my gas tank but is is safe to weld on a used filler hose?? other route would get exhaust tubing, like in the link, and get a return fitting welded on that instead.
secretsubmariner
Champagne Wrangler
secretsubmariner is offline
PostPosted: Wed Sep 13, 2017 8:40 am    Post subject: Re: The Stupid Question Thread Reply with quote
Will a 32/36 dfav Weber progressive carburetor work with the distributor bearing the part number 021 905 205 P?
asking for a friend Embarassed
-Tony
1978 Champagne Edition II (Mar)
1978 Champagne Edition II (Feb - sold)
1978 Champagne Edition II (Jan - sold)
1978 Westfalia Auto Deluxe (sold)
78Kombi wrote:
dude but im a nigerian prince
Wildthings
Wildthings is offline
PostPosted: Thu Sep 14, 2017 4:55 pm    Post subject: Re: The Stupid Question Thread Reply with quote
The 021-905-205P and the 022-905-205S would be the preferred distributors.
telford dorr
telford dorr is offline
PostPosted: Sat Sep 16, 2017 2:09 pm    Post subject: Re: The Stupid Question Thread Reply with quote
If it's removed from the bus, should be no problem. Welding is good for steel to steel joints. I brazed my return tube on. Remove the tube zinc coating in the braze area with some hydrochloric acid. When brazing is complete, paint the outside with some zinc-based paint for rust prevention.
'71 panel, now with FI
To steal ideas from one person is plagiarism; to steal from many is research - Steven Wright
All models are wrong; some are useful - George Box
More VW electrical at http://flowcon.us/td/ (available 9am to 9pm PST)
Wasted youth
Wasted youth is offline
PostPosted: Sat Sep 16, 2017 11:30 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Friend of mine has a California fuel injected bus. I have never peeked inside the engine compartment, so I will take his word on what his set up is. He is complaining that he's burned up two different condensers and last three weeks and is convinced that these new parts are garbage. I agree with that thought to a large extent, but what I am concerned with is that he has burned up condensers.
Outside of leaving the ignition on, what would cause that?
1968 Double Cab truck, 1973 Auto trans bus, 1978 Auto trans Sunroof bus with A/C and a 1987 Auto trans Westfalia.
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Sun Sep 17, 2017 12:37 am    Post subject: Re: The Stupid Question Thread Reply with quote
I used to think that hooking up the coil backwards (switch positive and negative) could do that, but BusBoyTom had his backwards for the better part of a decade and routinely saw 19mpg before he corrected it……
3 of the 5 new Bosch condensers were bad out of the box for me and customer cars in the last two years. When they got hot, my ignition cut out. After cooling, the car would run normally.
Differential diagnosis: Car ran for 10 minutes from cold start before bucking. Car would buck 1-2 minutes after hot start. After leaving the distributor in the freezer all night, installing, and immediately firing up, car ran for 25 minutes without bucking.
Robbie
Three rules of troubleshooting:
1. Do the easiest thing first.
2. Don't rely on the guy before you. He was not able to fix the problem.
3. 90% of problems are between the driver's seat and the steering wheel.
Wildthings
PostPosted: Sun Sep 17, 2017 2:27 am    Post subject: Re: The Stupid Question Thread Reply with quote
I don't run any new Bosch tune up parts any more, they are the worst junk out there.
williamM
williamM is offline
PostPosted: Sun Sep 17, 2017 2:30 am    Post subject: Re: The Stupid Question Thread Reply with quote
Robbie
Geesz- Robbie- get some ice cream and some pot pies at least.
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
SamboSamba22
SamboSamba22 is offline
PostPosted: Sun Sep 17, 2017 6:34 am    Post subject: Re: The Stupid Question Thread Reply with quote
Something!!
I bet there's beer on the other side...
Invention is the tool of the adventurer - Jacques Cousteau
Sinning led me to become a saint, which I then learned I wasn't qualified. -Samuel Heath Belcher
2017 Golf GTI
1974 Brilliant Orange Westfalia Deluxe
1965 Ruby Red Standard Beetle - SOLD
1959 Dove Blue Single Cab
ISO Rebuild kit APG Fuel Pump (Type 4/72-74
Bus)
Tcash
Tcash is offline
PostPosted: Sun Sep 17, 2017 7:47 am    Post subject: Re: The Stupid Question Thread Reply with quote
Condenser Failure in Conventional Ignition Systems
Steve Maas
http://www.nonlintec.com/sprite/cap_failure/
Testing condensers
https://www.smokstak.com/forum/showthread.php?s=91...amp;page=2
Page 340 of 357
