The Stupid Question Thread
Page: Previous  1, 2, 3 ... 355, 356, 357 ... 377, 378, 379  Next
Danwvw
Danwvw is offline
PostPosted: Mon Feb 05, 2018 4:11 pm    Post subject: Re: The Stupid Question Thread Reply with quote
A good vacuum will hold, till you let up on the brake the first time with the engine stopped.
1971 VW Sundial Camper:
Build Sheet: Type 1 1679cc & W-100 Cam, Type1 1800cc's Webcam 118 and 1.25:1 Rockers, Type 1 1800cc with Webcam 163 my current daily driver.
busdaddy
busdaddy is offline
PostPosted: Mon Feb 05, 2018 4:33 pm    Post subject: Re: The Stupid Question Thread Reply with quote
A Mightyvac can't produce the volume to keep up with a booster in action, if you can get someone to hold the pedal down while you pump the mightyvac you may be able to pull a vacuum on it in the depressed position before your hand cramps up.
AircooledHome
AircooledHome is offline
PostPosted: Mon Feb 05, 2018 5:53 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Ok got it.
Third stupid question of the week, does it matter where the oil filter return hole on the inside of the external oil filter mount is oriented? I ordered the wrong oil filter mount (ports facing wrong way) and had to made a bracket to bolt the thing upside down.. Now I see that the hole for return oil is on the TOP of the bracket, will oil return through it without issue?
'71 Deluxe Bus - http://www.thesamba.com/vw/forum/viewtopic.php?t=659421&highlight=
busdaddy
busdaddy is offline
PostPosted: Mon Feb 05, 2018 6:01 pm    Post subject: Re: The Stupid Question Thread Reply with quote
It doesn't matter, the whole cavity is filled with oil when in use.
I would have made the bracket so the filter faced down myself, or faced the filter towards the front. Wink
AircooledHome
PostPosted: Mon Feb 05, 2018 6:23 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Why's that? Curious.
The filter is tall, it's a Bosch ST3500 It would hang low if it pointed down.
Wildthings
Wildthings is offline
PostPosted: Mon Feb 05, 2018 7:06 pm    Post subject: Re: The Stupid Question Thread Reply with quote
*X*X*X*X* Supply should be on the outside of the element and the return should be up through the nipple in the middle. *X*X*X*X*
busdaddy
busdaddy is offline
PostPosted: Mon Feb 05, 2018 7:10 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Ahhh yes, never looked that closely, from the pump on the outside, to the engine bearings in the middle.
tonysantacruz
tonysantacruz is offline
PostPosted: Mon Feb 05, 2018 7:18 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Looking at pictures I noticed that the silver thingy to the right of the swing lever arm, the bottom one, has no wires connected to the push-on connector. Question is: what is connected to the one that has wires and what should be connected to the bottom one (if anything should be). Iíve looked in the wire diagrams and the Muir books and I canít find it. Heck, took me a while to find the English name for ďswing lever.Ē
busdaddy
busdaddy is offline
PostPosted: Mon Feb 05, 2018 7:30 pm    Post subject: Re: The Stupid Question Thread Reply with quote
That's your brake master cylinder, the silver thingys are the switches to operate the brake lights. Some systems only have 1 switch, when the optional "brake system warning light" is added to the dash 2 switches are required to operate it, does your bus have a small circular red (often yellowed or faded to clear) light on the speedo cluster that's labelled "B" somewhere between the speedo and heater levers?
tonysantacruz
PostPosted: Mon Feb 05, 2018 7:43 pm    Post subject: Re: The Stupid Question Thread Reply with quote
It has the hole for what I think could be that, yeah. Cool, that takes care of that question.
Could you help me with another one? What was bolted here, on the arm/base to the left? And what is the middle cilinder abive the disconnected parking brake lever?
busdaddy
busdaddy is offline
PostPosted: Mon Feb 05, 2018 8:12 pm    Post subject: Re: The Stupid Question Thread Reply with quote
The cylinder directly behind and above the parking brake is the front end of the shifter tube.
The brackets on the inner side of the RH frame rail aren't something you find on German made buses, maybe mounts for the rare optional "La Cucaracha" air horn?
tonysantacruz
PostPosted: Mon Feb 05, 2018 8:15 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Hee hee. Thanks for helping filling in the gaps. The shifter had some serious play, hopefully the mechanic took care of that. Iím leaning towards a short shifter (?) Ďcause I donít want to rap my knuckles every tie I shift to third.
Damn, on that bracket, Iíll need to dig deeper.
AircooledHome
PostPosted: Mon Feb 05, 2018 8:16 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I don't have that arm/ base on the left. Nothing connected there.
Well, that is where your parking brake lever connects through the floor..
tonysantacruz
PostPosted: Mon Feb 05, 2018 9:12 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Looks like my lever is missing the bottom part.
busdaddy
busdaddy is offline
PostPosted: Mon Feb 05, 2018 11:29 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Looks like you two have earlier model buses Wink
Wildthings
PostPosted: Tue Feb 06, 2018 12:59 am    Post subject: Re: The Stupid Question Thread Reply with quote
Make sure that the coupler between the shift rod and the tranny is good. Don't know what you may have available to you down south, but there are good couplers and cheap worthless couplers being sold up here in the states. You can always bend the shift lever a bit if necessary to keep the knuckles away from the dash/parking brake handle.
tonysantacruz
PostPosted: Tue Feb 06, 2018 8:20 am    Post subject: Re: The Stupid Question Thread Reply with quote
Well, today I learned that there used to be a cover for that bracket that I found.
Apparently, it's pretty rare:
Tolva Cubre-Pedales, known as "pedal-covering funnel/hopper".
busdaddy
busdaddy is offline
PostPosted: Tue Feb 06, 2018 8:30 am    Post subject: Re: The Stupid Question Thread Reply with quote
Maybe rare in MX, but pedal pans aren't hard to find in the US and Canada.
https://www.thesamba.com/vw/classifieds/search.php...ton=Search
tonysantacruz
PostPosted: Tue Feb 06, 2018 8:34 am    Post subject: Re: The Stupid Question Thread Reply with quote
Me like. Thanks, busdaddy. So it takes two? One per side? Or is one big enough to cover them?
Wildthings
PostPosted: Tue Feb 06, 2018 10:16 am    Post subject: Re: The Stupid Question Thread Reply with quote
These pans have different shape according to the model year. For your Mexican Combi you should find another of the same year and get a picture and some dimensions. Without the cover if you can snag the steering on a rock, fallen tree limb, or other road debris and get your arms ripped apart.
Page 356 of 379
