busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jan 01, 2020 5:08 pm Post subject: |
lintbrush wrote: |
Wondered if Westfalia removed factory installed headliners when doing the conversion? If so maybe they were empty, but with headliners? |
Not if it was spec'd on the M plate for conversion before delivery to a dealer (what's your's say?), I've seen some that were brought to Westfalia for work after purchase, but those left the headliner in place as they had special cabinets designed for those jobs. The sheet metal part that vinyl is peeking out from under is only found on panelvans, Kombis and early Westfalias (any bus that didn't leave the factory with upholstery in the cargo area), it's a sound insulator and it's filled with fuzzy stuff.
Since the rivets securing it to the body aren't painted I suspect someone has had it off, maybe they put some old headliner scraps under it to stop a rattle?, the material looks like the 75+ stuff, not the perforated kind used in 1970. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
lintbrush Samba Member
Joined: October 10, 2013 Posts: 269 Location: Campbell, California
Posted: Wed Jan 01, 2020 5:29 pm Post subject: Re: The Stupid Question Thread |
My M-code shows as factory-prepared for Campmobile interior (M 517). I’ll take a closer look. It looked interesting since it’s neatly in-place and the same on both sides. Production date is September 17, 1970.
Under Exterior, the M-Code translator shows “Remarks: Westfalia” too. _________________ 1970 Westfalia Campmobile - SF Bay Area
https://www.instagram.com/campishome/ |
Posted: Wed Jan 01, 2020 6:06 pm Post subject: Re: The Stupid Question Thread |
lintbrush wrote: |
It looked interesting since it’s neatly in-place and the same on both sides. |
They got painted after assembly back there, why isn't the exposed vinyl red? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Jan 01, 2020 6:25 pm Post subject: Re: The Stupid Question Thread |
I was thinking maybe there was a headliner that was in, but removed by Westfalia? Which didn’t make sense since I assumed VW would not have installed a headliner if it was headed over for campmobile conversion. I’ll see if I can remove it to get a better look.
busdaddy wrote: |
lintbrush wrote: |
They got painted after assembly back there, why isn't the exposed vinyl red? |
Posted: Wed Jan 01, 2020 6:42 pm Post subject: Re: The Stupid Question Thread |
I see what you mean about the clean, unpainted rivets on both sides. I’m thinking you’re right that vinyl was used to shim and prevent rattling as it was riveted together? I was able to pull this out for a closer look.
Clementine79 Samba Member
Posted: Fri Jan 03, 2020 3:56 pm Post subject: Re: The Stupid Question Thread |
1979 bus has two holes rusted through in the battery trays, I know this is a common spot for rust due to the moisture and lead acid batteries.
What I'm wondering is will the engine still cool itself as it should or will the warm air come up through the holes that would otherwise be sealed off? The biggest hole is maybe 1-2 inches long right now. |
Posted: Fri Jan 03, 2020 4:38 pm Post subject: Re: The Stupid Question Thread |
McintoshType2 wrote: |
It would be better if you sealed them up somehow, perhaps some thin sheet metal?, whatever you use make sure it doesn't trap moisture and can't end up in the fan. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jan 03, 2020 6:03 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
It would be better if you sealed them up somehow, perhaps some thin sheet metal?, whatever you use make sure it doesn't trap moisture and can't end up in the fan. |
Wire brush the loose rust away, top and underside of the tray, and then treat the questionable areas with something like Osphos that will convert the remaining rust and seal the metal. Then apply a layer of fiberglass and resin to the box running the glass up the sides of the box a bit. Be sure to cover the Osphos on the underside of the box with resin as well and clean up any drips. You can use multiple layers of glass where the holes are if you think it is necessary.
You of course will have to slit the fiberglass so it will fit over the stationary battery hold down and somehow plan in the hole for the hold down bolt. You can use balloons partially filled with sand to hold the glass down tight to the metal in the corners. |
metz Samba Member
Posted: Sun Jan 05, 2020 10:54 am Post subject: Re: The Stupid Question Thread |
I got an early bay with the stock 5x205 rear drum brakes. Does anyone have experience with converting to either disc brakes or T1 drum brakes to reduce the track width? The goal of this obviously being to fit wheels that would normally touch the wheel arches. I'm prepared to do quite a lot of modifications/fabrication, but I need to stick with 205 PCD and also not cut the torsion housing to achieve the narrowing. _________________ 68 panel
64 ghia coupe |
maz-o Samba Member
Joined: February 21, 2017 Posts: 79 Location: Helsinki, Finland
Posted: Mon Jan 06, 2020 2:02 am Post subject: Re: The Stupid Question Thread |
best way to remove old glue and headliner residue from the tintop, without damaging the metal?
adhesive removal and scrapers didn't seem effective at all.
nylon brush on the angle grinder does it but rips the paint off and makes a mess.
thanks!
wcfvw69 Samba Purist
Posted: Mon Jan 06, 2020 7:08 am Post subject: Re: The Stupid Question Thread |
maz-o wrote: |
thanks!
Acetone worked removing carpet glue. I've also used Goof off with success. _________________ Contact me at [email protected]
The Samba member since 2004.
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Mon Jan 06, 2020 12:50 pm Post subject: Re: The Stupid Question Thread |
I have a "D" Pulley and am running an alternator. With the alternator belt and the belt looks too small as it sits pretty low on the alt pulley.
Anyone have this issue? _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Mon Jan 06, 2020 2:30 pm Post subject: Re: The Stupid Question Thread |
Nothing wrong with it sitting low in the pulley as long as you have enough shims to be able to torque up the nut properly. The lower it is the faster the fan spins, what bus doesn't want a little bonus cooling? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jan 06, 2020 2:35 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
Nothing wrong with it sitting low in the pulley as long as you have enough shims to be able to torque up the nut properly. The lower it is the faster the fan spins, what bus doesn't want a little bonus cooling? |
Thanks, ill give it a whirl. _________________ Your Vanagon sucks, Stop waving at me.
Kabasue Samba Member
Posted: Mon Jan 06, 2020 10:12 pm Post subject: Re: The Stupid Question Thread |
Some one near by is selling a DZ code diesel vanagon transmission. Can I use it in my 73 if I swap out the bell housing, and the nose cone? Also would it be beefy enough to handle 2.0 or a 2.5 liter engine? _________________ Remember to get your VW spayed or neutered
71 SB convertible (Finally Finished!)
73 Transporter (next project)
73 Westy with a 411 engine (Finally Finished) |
Mispeld Samba Member
Joined: April 29, 2018 Posts: 355 Location: Jacksonville - Coastal NC
Posted: Tue Jan 07, 2020 6:41 pm Post subject: Re: The Stupid Question Thread |
My bus is a 77 with faded blue seats that are in poor shape and do not match the green interior. I picked up a beautiful set of black seat covers made by TMI from a guy about a year ago for an awesome price. Horsehair pads arrive tomorrow and I was sizing things up and these seat covers are not going to work. They appear to fit over frames with hooks style and not wedged into the frame like mine are. There are no part numbers on the covers so maybe they go to a different year? All I have is what is written on the box in sharpie. So I guess I will just end up getting the proper green plaid ones that belong which is fine.
Are Westy seat frames different/unique or are they the same for all other busses of the same year(s)?
Does anyone know potentially what year seats I currently have? I want to ensure new green ones will fit these frames I have.
The tracks are original and have not been molested so I assume any late seat cover would fit?
_________________ Tom
1977 Westy. 2.0 Fuel Injected. |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Wed Jan 08, 2020 5:24 am Post subject: Re: The Stupid Question Thread |
Oh my goodness... how did I not see that? Thank you Kent. _________________ Tom
oldfield626 Samba Member
Posted: Fri Jan 10, 2020 2:30 pm Post subject: Re: The Stupid Question Thread |
New VW owner here. Long story short, when I bought a 69 baywindow about 2 years ago, my ex picked it up and housed it until I had the room to take it (stupid idea, I know). I'm still in the dark about the title, they said they had it but then said there never was one. I don't even know how to contact the person I bought it from in the first place. There's a very unlikely chance I'll be getting an original title. So I looked for the vin and chassis but I couldn't find it anywhere, however I do have the original engine and engine code. I was wondering if there was a way I could register/get a title or anything I can do with just the engine code?
I really appreciate any feedback, thank you! |
Posted: Fri Jan 10, 2020 2:58 pm Post subject: Re: The Stupid Question Thread |
That doesn't sound promising, have another look for a VIN in the locations shown below:
Слава Україні! |
