NorCalWeekender Samba Member
Joined: April 13, 2000 Posts: 6531 Location: East Bay, CA
Posted: Thu Nov 26, 2020 9:31 am Post subject: Re: The Stupid Question Thread |
Are front door handles interchangeable? Will a passenger side one work on the driver's side and vice-versa? _________________ 9th Owner of a 1971 Tintop Westy
"Eventually, we sold to a guy for $500 who towed it away to live in it in his parents' driveway. We didn't think it would ever avoid the junk heap on that day." -The 3rd Owner, 1995 |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Thu Nov 26, 2020 11:01 am Post subject: Re: The Stupid Question Thread |
NorCalWeekender wrote: |
Are front door handles interchangeable? Will a passenger side one work on the driver's side and vice-versa? |
Yep, they’ll work fine. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Thu Nov 26, 2020 11:25 am Post subject: Re: The Stupid Question Thread |
airschooled wrote: |
Yep, they’ll work fine. |
Good to know! I need to suss out why my passenger side likes unlocking more than my driver's side. _________________ 9th Owner of a 1971 Tintop Westy
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Nov 26, 2020 11:52 am Post subject: Re: The Stupid Question Thread |
Good to know! I need to suss out why my passenger side likes unlocking more than my driver's side. |
Does it stay locked if you push the inner lock knob closed and shut the door?, if so then you are missing the spring which also aids unlocking from the outside: https://www.thesamba.com/vw/forum/viewtopic.php?t=476461
A fully functional latch won't let you lock the keys inside. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Nov 26, 2020 11:54 am Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
A fully functional latch won't let you lock the keys inside. |
Yes, it locks and stays locked just fine. It occasionally unlocks just fine. Sometimes I have to turn the key down and then up. And sometimes nothing happens. _________________ 9th Owner of a 1971 Tintop Westy
Posted: Thu Nov 26, 2020 12:33 pm Post subject: Re: The Stupid Question Thread |
Rod length (bend) adjustment is critical on the 69-73 setup with the “flapper” locking tab instead of the 68/74-9 “post” style lock. Also, the black plastic finger guard in the handle should be removed for testing. (It can interfere with the locking tab, especially if aftermarket.)
Swapping the handles side to side would be a good differential diagnosis. Don’t over-tighten the hex screws, the handles strip easily. _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Thu Nov 26, 2020 12:36 pm Post subject: Re: The Stupid Question Thread |
Swapping the handles side to side would be a good differential diagnosis. Don’t over-tighten the hex screws, the handles strip easily. |
Roger that. No idea if any part of the setup is aftermarket. But this all gives me some solid stuff to look at maybe this weekend. Hope you all have rad Thanksgivings. _________________ 9th Owner of a 1971 Tintop Westy
Posted: Thu Nov 26, 2020 1:16 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
Yes, it locks and stays locked just fine. It occasionally unlocks just fine. Sometimes I have to turn the key down and then up. And sometimes nothing happens. |
Then it's broken, take the latch unit out, clean it well and fix the spring, you'll be rewarded with effortless key action. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Nov 26, 2020 4:33 pm Post subject: Re: The Stupid Question Thread |
Okay, so the kids needed some time outside before dinner and I figured I'd pull the door panel to see what my issue is.
Yes, that little spring is definitely missing from the latch mechanism. Where can I get one?
Before the door handle is pulled.
After the door handle is pulled (note it definitely doesn't spring back into place).
But I also found that part of the latch is hitting and rubbing on the window guide.
So I loosened it up a bit until the latch moved more freely. Still going to need the spring and a proper clean'n'lube.
Also noticed that if I pull the key out a fraction of an inch before turning it, it has a better chance of unlocking it. _________________ 9th Owner of a 1971 Tintop Westy
Posted: Fri Nov 27, 2020 7:21 am Post subject: Re: The Stupid Question Thread |
Ah, I see Wolfsburg West has the spring. That's that sorted.
Still curious why the window guide would be rubbing on the mechanism. _________________ 9th Owner of a 1971 Tintop Westy
Posted: Fri Nov 27, 2020 9:18 am Post subject: Re: The Stupid Question Thread |
Still curious why the window guide would be rubbing on the mechanism. |
It looks like the outer skin of the door has been caved in, accident damage?, or maybe too many hip checks to get it closed? The plate that reinforces the outer handle looks slightly curved in from here.
Слава Україні! |
Posted: Fri Nov 27, 2020 9:20 am Post subject: Re: The Stupid Question Thread |
Yeah, I pretty sure it is. Not sure if it was accident damage or just what, but with that screw out that holds the handle in place, you can see some separation between that and the door skin. _________________ 9th Owner of a 1971 Tintop Westy
Posted: Sat Nov 28, 2020 3:40 pm Post subject: Re: The Stupid Question Thread |
Well, this project just added a new dimension. I guess all that testing didn't help, but I suspect this was in my future regardless.
Any good tips on replacing a lock cylinder?
Posted: Sat Nov 28, 2020 3:49 pm Post subject: Re: The Stupid Question Thread |
No kidding! You reckon I'm better off going with a used handle rather than just a lock cylinder? _________________ 9th Owner of a 1971 Tintop Westy
Posted: Sat Nov 28, 2020 3:52 pm Post subject: Re: The Stupid Question Thread |
No kidding! You reckon I'm better off going with a used handle rather than just a lock cylinder? |
Can you buy just the cylinder?, if so (and it's not made in China) then do it, but a used German one is sure to fit, many sellers will almost give away handles with blemished chrome, the parts you need will still be good. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Nov 28, 2020 3:54 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
Can you buy just the cylinder?, if so (and it's not made in China) then do it, but a used German one is sure to fit, many sellers will almost give away handles with blemished chrome, the parts you need will still be good. |
Fair point. All the cylinders I've seen so far are NOS. Duly noted and thank you! _________________ 9th Owner of a 1971 Tintop Westy
Jim Bear Samba Member
Joined: March 25, 2006 Posts: 670 Location: Watkinsville, GA
Posted: Mon Nov 30, 2020 8:40 am Post subject: Re: The Stupid Question Thread |
This is a general question related to selling and payment options for my beetle I am selling. This is "stupid" because it is a shameless plug for my thread in the General Chat section. See question here. _________________ "You're either on the bus, or you're off the bus." ~kk
'85 Vanagon Westy - George In the Stable 2020-?/'74 Weekender - Ophelia In the Stable 2007- ?/'69 Beetle Convertible - SOLD 2017-2020/'67 Beetle - September SOLD 2013-2016 /'67 SO42 Westy - Sage SOLD 1996-2001 /'69 Transporter - Baby Blue SOLD 1995-1995/'72 Westy - Nelly - SOLD 1990-1995--STOP FRACKING |
Terminatez Samba Member
Joined: June 07, 2015 Posts: 340 Location: Sun Valley, CA
Posted: Tue Dec 01, 2020 9:10 pm Post subject: Re: The Stupid Question Thread |
Does the engine tin matter from years 72-78 heat exchangers?
Pretty sure my bus has engine tin from different years put together minus 79.
Wondering if I can just get early 72-74 heat exchangers and it'll work? _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
I don't think I've ever seen an engine in worse shape. |
Posted: Tue Dec 01, 2020 9:32 pm Post subject: Re: The Stupid Question Thread |
Terminatez wrote: |
Wondering if I can just get early 72-74 heat exchangers and it'll work? |
The sled tins and other lower tins need to match the exhaust, but with some cutting and bending it is possible to mix and match tins from various years. There are some differences in over cylinder tins from year to year, and two styles of alternator tin. The front tin above the engine has all sorts of variations over the years, but all can be adapted to use for other years if need be. |
