Posted: Mon Mar 08, 2021 7:08 pm Post subject: Re: The Stupid Question Thread |
Aircooled.net list several as does The Type 4 Store. I would think Busdepot and the CB Performance likely would as well, I am sure there are others. |
TrollFromDownBelow Samba Member
Joined: January 04, 2005 Posts: 414 Location: Metro Detroit
Posted: Tue Mar 09, 2021 8:59 am Post subject: Re: The Stupid Question Thread |
From the research I've done, this manufacturer (link below) is supposed to be a source of some of the best quality camshafts for Type IV's. I put a stock grind along with their lifters in my Type IV rebuild.
Do some google shopping to find the best deal.
http://www.webcamshafts.com/
Regards,
Mike _________________ 1976 Westy (aka Tripod)
2.0 liter FI solid lifters
212k miles |
mike77777 Samba Member
Joined: May 13, 2009 Posts: 119 Location: portland or
Posted: Tue Mar 09, 2021 2:13 pm Post subject: Re: The Stupid Question Thread |
webcam with new lifters went in mine. trouble free, good power, stock grind. quick shipping. follow their directions regarding initial breakin.
_________________ patience and putty |
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Sun Mar 21, 2021 10:38 am Post subject: Re: The Stupid Question Thread |
Real basic question - does the heater fan run all the time or is it somehow switched? The electric one that mounts to the roof of the engine bay.
My bus didn't come with any of the cabin heating parts so I've never seen them in action. _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51146 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Mar 21, 2021 10:46 am Post subject: Re: The Stupid Question Thread |
Thrasher22 wrote: |
My bus didn't come with any of the cabin heating parts so I've never seen them in action. |
It's switched by the heater lever in the dash, runs when the lever is down and the engine is running (some later models don't need to have the engine going for the fan to come on).
https://www.thesamba.com/vw/archives/manuals/75bus.php
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Mar 21, 2021 10:59 am Post subject: Re: The Stupid Question Thread |
Thrasher22 wrote: |
The heater booster fan only supplements the air flow at or near idle and does almost nothing when the engine is revved a bit. If you do not have the fan just block off the tubes coming up from the heat exchangers so you don't waste your precious heated air.
Posted: Sun Mar 21, 2021 11:33 am Post subject: Re: The Stupid Question Thread |
Thanks guys! I didn't realize there was an electric switch attached to the heat lever in the dash. I've tracked down all the parts, just figuring out how it all ties together.
Super excited to have even a tiny amount of heat. _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
Posted: Sun Mar 21, 2021 11:51 am Post subject: Re: The Stupid Question Thread |
Thrasher22 wrote: |
Super excited to have even a tiny amount of heat. |
Search out the Blumaxx thread, it is possible to get many times the heat into the cab as a stock system puts out. |
brandt Samba Member
Posted: Mon Mar 22, 2021 9:27 am Post subject: Re: The Stupid Question Thread |
I have a type 4 cam and lifters that have been mixed up and need to be resurfaced. Would this be something any common local machine shop should be able to do or do they need to go to a VW specific machine shop? And is it just the lifters or the cam too? |
Posted: Thu Mar 25, 2021 8:12 pm Post subject: Re: The Stupid Question Thread |
Back with another stupid heating system question!
How hot do the heater/blower pipes that come in and out of the exchange heater get?
To be more specific, do they get hot enough to need high-temp paint? There's lots of airflow, but they also connect to the exhaust.
I'm referring to the parts painted black in this photo:
Posted: Thu Mar 25, 2021 8:31 pm Post subject: Re: The Stupid Question Thread |
Maybe 400°F on a long hard pull. |
maz-o Samba Member
Joined: February 21, 2017 Posts: 79 Location: Helsinki, Finland
Posted: Sat Mar 27, 2021 1:31 pm Post subject: Re: The Stupid Question Thread |
1973 late bay. (production date 11/72) late style ATE calipers.
so here's a REALLY stupid question: Which caliper goes on which side?? I'm finding conflicting information wether the "shoulder" bolt should be in the upper or lower hole?
photo of the right hand side, is this correct? (shoulder bolt on the lower end)
Angus II Samba Member
Joined: June 01, 2016 Posts: 708 Location: Mammoth Lakes Ca. 93546
Posted: Sat Mar 27, 2021 2:38 pm Post subject: Re: The Stupid Question Thread |
Hello,
As per Bentley. The "locating (lower) bolt" goes in first.... |
NorCalWeekender Samba Member
Joined: April 13, 2000 Posts: 6531 Location: East Bay, CA
Posted: Tue Mar 30, 2021 7:24 am Post subject: Re: The Stupid Question Thread |
Can the rear (left side, in this case) vent window and rubber be replaced without replacing the rubber of the fixed window next to it? Or is the only good way to get the vent window portion in is to have the fixed window out? _________________ 9th Owner of a 1971 Tintop Westy
"Eventually, we sold to a guy for $500 who towed it away to live in it in his parents' driveway. We didn't think it would ever avoid the junk heap on that day." -The 3rd Owner, 1995 |
Posted: Tue Mar 30, 2021 8:41 am Post subject: Re: The Stupid Question Thread |
NorCalWeekender wrote: |
Can the rear (left side, in this case) vent window and rubber be replaced without replacing the rubber of the fixed window next to it? Or is the only good way to get the vent window portion in is to have the fixed window out? |
The vent can be removed separately, Bentley describes the procedure well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Mar 30, 2021 8:42 am Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
The vent can be removed separately, Bentley describes the procedure well. |
I'll dig out my Bentley. Thanks!! _________________ 9th Owner of a 1971 Tintop Westy
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1958 Location: Manitowoc, WI
Posted: Fri Apr 02, 2021 10:37 am Post subject: Re: The Stupid Question Thread |
Ceckert64 wrote: |
. We’re right hand carbs mistaken for single carbs? |
Plausible, when I worked at a Japanese wrecker years ago buyers for mass rebuilders would come by and purchase piles of calipers, starters, carbs, etc.. for cores, maybe they were the "non oddball" looking ones and went into the heap with the rest of them? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Fri Apr 02, 2021 12:38 pm Post subject: Re: The Stupid Question Thread |
How did late late bays attach the rear armrests? I have a 77 here with holes in the panels but no attachment points like Bentley shows... Fgure 6-6, body and frame.
Thanks!
www.airschooled.com |
