vw_bud Samba Member
Joined: March 23, 2008 Posts: 265 Location: Bradford, PA
Posted: Fri Nov 26, 2021 11:12 pm Post subject: Re: The Stupid Question Thread |
I heard someone say you can use a doghouse oil cooler on a type 4, is this possible with the 2 rows less on the cooler than the type 4? |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3330 Location: 802 The Pointless Forrest
Posted: Sat Nov 27, 2021 8:18 am Post subject: Re: The Stupid Question Thread |
Did baywindow busses ever come with double side panel doors , like the split buses? _________________ "Albatross"! |
busdaddy Samba Member
Posted: Sat Nov 27, 2021 8:56 am Post subject: Re: The Stupid Question Thread |
vw_bud wrote: |
It'll fit, but there will be a gap, and less cooling. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Nov 27, 2021 8:59 am Post subject: Re: The Stupid Question Thread |
calvinater wrote: |
Did baywindow busses ever come with double side panel doors , like the split buses? |
If you mean hinged doors no, except for Brazil where the whole ass end of the bus behind the B pillars is a splitty body.
Bays were available with double sliders from Germany though. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
D/A/N Samba Member
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2332 Location: Southeast Kentucky
Posted: Sun Nov 28, 2021 7:55 pm Post subject: Re: The Stupid Question Thread |
Looking for a Fluid Control Thermostat that's adjustable? If no such thing, is there something with less than a 180f opening Temp? _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Sun Nov 28, 2021 8:29 pm Post subject: Re: The Stupid Question Thread |
D/A/N wrote: |
Does anyone know part numbers, suppliers, or Home Depot (or similar) replacements for #’s 9 and 13 in the diagram below? |
#9 is Honkin' Big Rubber Bushing, VW #211-415-637B, 68-71 bus.
#13 is just a widish rubber band, used to cover 3 little holes in column tube, no p/n that I know of.
I just use a little strip of black electrical tape. _________________ '67 bug: seized by the authorities
D/A/N Samba Member
Posted: Mon Nov 29, 2021 8:30 am Post subject: Re: The Stupid Question Thread |
kreemoweet wrote: |
D/A/N wrote: |
I just use a little strip of black electrical tape. |
Cool, thanks. I asked because I have the equivalent of a widish black rubber band that seems to have slid out from somewhere in the ignition housing and I’m trying to figure out what it is. _________________ '69 Fuel Injected Squareback. "B" D-jet. 1600 with balanced rotating assembly and lightened flywheel. Full flow and external filter.
'70 Riviera. 1904cc w/ 40mm Dellortos, 019 distributor, Steve Tims “super stock” 37x32 heads, Web Cam 218, Vintage Speed SS143 Super Speed exhaust, 1 1/2” heater boxes |
brandt Samba Member
Posted: Thu Dec 02, 2021 9:16 am Post subject: Re: The Stupid Question Thread |
Anyone know where to get these little heater cable tube parts? Or know part numbers? It seems they are not being reproduced or at least not in the US market. I'm guessing Busted Bus.
germansupplyscott Samba Member
Posted: Fri Dec 03, 2021 4:13 pm Post subject: Re: The Stupid Question Thread |
BusOK has the plastic bits for the heater cable aft ends.
(I realize you asked about North America but...) _________________ SL |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sat Dec 04, 2021 6:39 am Post subject: Re: The Stupid Question Thread |
germansupplyscott wrote: |
(I realize you asked about North America but...) |
BusLab in Calif carries a lot of BusOK's parts.
If they can't be found on BusLab's website, give them a call.
They don't put everything in stock on their web pages.
https://www.buslab.com/Transporter-68-79-s/273.htm _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Ulu Samba Member
Posted: Thu Dec 09, 2021 7:26 pm Post subject: Re: The Stupid Question Thread |
On a 73 ball joint beetle beam, LHD, with all stock everything:
What is the absolute minimum disassembly required to remove
only the lower front torsion bar, From the “easiest” side? _________________ SS100 kit kar
1600cc DP |
Koeppler Samba Member
Joined: April 21, 2011 Posts: 481 Location: Aging gracefully
Posted: Fri Dec 10, 2021 7:24 am Post subject: Re: The Stupid Question Thread |
If a steering box is centered and alignment is good but the steering wheel isn't centered when I hook the drag link back up can I just shorten or lengthen the drag link to center the steering wheel or do I have to do something else? |
Posted: Fri Dec 10, 2021 7:33 am Post subject: Re: The Stupid Question Thread |
Move the steering wheel, fiddling with the drag link will put the box off center. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Ulu Samba Member
Posted: Fri Dec 10, 2021 9:23 am Post subject: Re: The Stupid Question Thread |
Oh crap . . . I thought this was the general stupid question thread. I guess this is the bus Stupid question thread. _________________ SS100 kit kar
1600cc DP |
Posted: Fri Dec 10, 2021 10:33 am Post subject: Re: The Stupid Question Thread |
Ulu wrote: |
Oh crap . . . I thought this was the general stupid question thread. I guess this is the bus Stupid question thread. |
Lucky for you there's a similar thread on the late Beetle forum: https://www.thesamba.com/vw/forum/viewtopic.php?t=591285 _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
NorCalWeekender Samba Member
Joined: April 13, 2000 Posts: 6531 Location: East Bay, CA
Posted: Sun Dec 12, 2021 2:55 pm Post subject: Re: The Stupid Question Thread |
Okay, I've gone through a few threads on the rear vent wing installation and am stuck with two questions as I attempt this on my bus.
1) Do the two tabs on the leading edge of the frame sit on the inside (meaning inside of the bus) of the pinchweld or should the pinchweld be split so that the tabs go between both sides of the pinchweld?
2) Does the upper tab (see below) sit fully inside the pinchweld or does it sit between both sides of the pinchweld? My bus has a gap into which the upper tab wants to go, but it also seems to be preventing the frame from sitting as forward as possible to allow the other window to go in. See how it doesn't sit flush with the forward edge of that gap (also assuming it should).
Thanks, guys.
Here's the upper pinchweld.
Here's the edge where the tabs engage. I assume there shouldn't be gaps into which the tabs go.
_________________ 9th Owner of a 1971 Tintop Westy
"Eventually, we sold to a guy for $500 who towed it away to live in it in his parents' driveway. We didn't think it would ever avoid the junk heap on that day." -The 3rd Owner, 1995 |
Posted: Sun Dec 12, 2021 3:18 pm Post subject: Re: The Stupid Question Thread |
All tabs go on the inner (passenger compartment) side of the pinchweld, new rubbers are super stiff and make the job challenging, keep trying.
There shouldn't be any gaps between the layers of the pinchwelds, has rust swollen them up and split them? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Dec 12, 2021 3:22 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
There shouldn't be any gaps between the layers of the pinchwelds, has rust swollen them up and split them? |
Okay, that's very helpful. Surprisingly little rust in this part of the bus. I'll clamp that upper part and get the metal back in shape (once it stops raining). Don't have new rubber on the vent wing (old stuff is pliable enough).
I'm wondering if it's better to start the stationary window at the edge of the vent frame instead of the bottom. _________________ 9th Owner of a 1971 Tintop Westy
Posted: Sun Dec 12, 2021 3:42 pm Post subject: Re: The Stupid Question Thread |
NorCalWeekender wrote: |
busdaddy wrote: |
I'm wondering if it's better to start the stationary window at the edge of the vent frame instead of the bottom. |
If the main window has new rubber it's going to be a struggle regardless of where you start, I'd consider beginning at the back and working evenly forward on the top and bottom, that way you have a flat edge left to pound on or pry with a wide flat thing to get the window back enough in the opening. Prying there also seats the vent forward so it's a 2 fer 1 deal. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
