92 SVX into a 86 vanagon
Page: Previous  1, 2
Olympia SVX
Olympia SVX is offline
PostPosted: Sat Jun 04, 2011 4:03 pm    Post subject: Reply with quote
Hello,
I have been working on the wiring harness. Are these the conectors that i need that end up on the ecm side of the harness. I think they are : B59, B60, B61, B62, B35, B36, B52,and B51.
Am I missing any?
prhoades
prhoades is offline
PostPosted: Sat Jul 16, 2011 3:13 pm    Post subject: Svx in Puyallup Reply with quote
Olympia SVX. I just picked up an SVX to do a conversion on my 90 Westy. You might become my new best friend.
Olympia SVX
PostPosted: Sat Jul 16, 2011 3:44 pm    Post subject: Reply with quote
I found the KEP clutch, adapter plate and Fly wheel used off of a guy that is upgrading his setup to the Bellhousing and RMW exhaust. His gain and my gain. with the money I saved I got some bigger wheels so I can upgrade my brakes in the future.
It looks like there is some wear and tear on the adapter plate. I am going to take it to a local machine shop I know of to see what they think.
Olympia SVX
PostPosted: Sat Jul 16, 2011 3:53 pm    Post subject: Reply with quote
I just got back from the machine shop. They sandblasted the adapter plate and evaluated the flywheel. They gave me some aluminum puddy called DEVCON 4 to fill in the corrosion spots and the fly wheel is just fine. They have a awesome setup. They have a full machine shop (they mostly do heavy machinery) and a hot rod shop in the back. they are called Captial Machine and are located in Tumwater, WA. Anyways, I also talked to them about reversing the coolant manifold and chopping my oil pan.
Olympia SVX
PostPosted: Sat Jul 16, 2011 4:55 pm    Post subject: Reply with quote
I have been documenting the wiring harness process. the diagram I made is from about seven sources i found on the internet. It seems that there are no complete wiring conversion charts on the web. this is what i have so far.
sorry if the pics suck i can't print them out right
axf7228
axf7228 is offline
PostPosted: Thu Jan 15, 2015 10:44 am    Post subject: Reply with quote
Thanks for the wiring harness diagram, should be extremely valuable to anyone doing the conversion in the future.
1982 Vanagon Westfalia
Subaru ej25 conversion into aircooled
Thor-bob Premium Member
Thor-bob is offline
PostPosted: Fri Jan 16, 2015 4:41 pm    Post subject: Reply with quote
Need a set of factory manuals?
I have a set from my old conversion
Thor
1990 Carrot
Page: Previous  1, 2
Page 2 of 2
