Fuel sender access hole, to do or not to do? |
To do |
55% |
[ 37 ] |
Not to do |
44% |
[ 30 ] |
Total Votes : 67 |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8544 Location: Las Vegas
Posted: Mon May 23, 2011 9:59 am Post subject: |
Honestly, I started thinking about cutting the damn hole after replacing the sender when I had the tank out, and having the sender not work properly when it was said and done.
I still think about it from time to time.... _________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
Keeby Swaggz Samba Member
Joined: April 20, 2011 Posts: 433 Location: Clarkston, WA
Posted: Mon May 23, 2011 10:11 am Post subject: |
I say do it, ONLY if you're gonna take the time to do a nice job of it... I'm gonna do both my Buses... _________________ you can find me under a Dub...
'73 Transporter 1700 "Papa Smurf"
'74 Westy Weekender 1800 out and apart "Great Punkin"
'70 Std. Bug 13B Rotary pending
'72 Karmann Ghia coupe "Cindy Lou Who" |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Mon May 23, 2011 10:26 am Post subject: |
I use a 2" hole saw, then lay out the rectangular hole, cut it with a jig-saw, file the rough edges, die grinder might throw a few too many sparks, cut a piece of metal it is either 20ga or 22ga, set it over, hammer/dolly to fit, put some 3M body caulk down, then secure with some #10 self drilling screws, easy breezy. Suppose I could paint it white, but then - Why? |
Zelten Samba Member
Joined: September 16, 2008 Posts: 1335 Location: Issaquah
Posted: Mon May 23, 2011 11:37 am Post subject: |
I lived with a Jeep fo 10 years that I could not get the sending unit for the gas guage to work. I could live with my bus the same way. So far though, my sending unit appears to be working rather well. I wouldn't cut a hole but that's just me. I would just ensure that I kept it full of gas. _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
Dead 1 Samba Member
Joined: October 31, 2005 Posts: 1374 Location: Burning shores of Lake Michigan
Posted: Mon May 23, 2011 12:56 pm Post subject: |
Why not do it? Sure beats taking out the engine then the gas tank to find out you forgot to attach a wire. _________________ "I reject your reality and replace it with my own"
"The American Dream - true enough because you gotta be asleep to believe it"
71, 1776 cc. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Mon May 23, 2011 1:06 pm Post subject: |
I guess my problem with it is the quality of the mod. If a guy could fabricate a nice cover plate that wasn't an eye sore then I'd be more inclined to cut the bus. The ones I've seen have been pretty badly done though. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
MadMax78 Samba Member
Joined: May 26, 2007 Posts: 511 Location: The Netherlands
Posted: Mon May 23, 2011 1:08 pm Post subject: |
I wonder how often it was done by a VW workshop. I have never seen a picture of the job done by VW with the official VW cover plate. Did any of you ever see one?
About the poll, I voted yes, do it. Why not? It won't decrease the value of the bus if it is done properly, as with a lot of things. I wouldn't use these marine cover plates, they look out of place on a bus imho. You can tell right away it's a boat part and it shouldn't be there.
I'd sure give this solution a thought if my sender were to fail. I replaced the sender when the engine was out and we were changing the fuel lines when we first got the bus. _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply , Busted Bus, Aircooled Technology & DIYAutoTune
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 27.000km
http://www.oranjetrophy.nl
Camper Special Club Member |
wihr Samba Member
Joined: August 15, 2010 Posts: 344 Location: PORTLAND, OR
Posted: Mon May 23, 2011 2:22 pm Post subject: |
"Van Ordinaire" was built in June 1970. It has been in my family since new and has never had a "sender" go bad. No cuttie! _________________ WIHR
1970 Campmobile "Van Ordinaire"
2009 Lincoln Town Car "Behemoth"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc |
3nero Samba Member
Joined: April 19, 2008 Posts: 171 Location: Dublin ,Ireland
Posted: Mon May 23, 2011 2:24 pm Post subject: |
I pulled my engine to replace my sender and it worked fine until everything went back in. then it stopped working
No way i was pulling the engine again, so out with the dremel and 20 mins later i had the now burnt out sender replaced with another new one. Which is now also kaput
sender number 3 is in the mail as i type
Save yourself future nightmares and just cut it _________________ 1974 RHD 412LS Daily driver
1977 LHD Bay (stealth camper) |
NoBudgetVWGarage Samba Member
Joined: November 27, 2008 Posts: 755 Location: Quartz Hill,CA
Posted: Mon May 23, 2011 2:53 pm Post subject: |
I voted no. Just my opinion cause you asked;) _________________ 1969 Transporter
1968 Ghia
1959 Ghia Hot VW Drag Car |
Lettuce Samba Member
Posted: Mon May 23, 2011 3:02 pm Post subject: |
hell, do it this way
Posted: Mon May 23, 2011 3:09 pm Post subject: |
I like that, when you do not know where to cut, make it big enough to cover all bases, clean cover job! Plus you can do all the vac lines from on top!
I have seen two bays in wrecking yards that had the factory access hole for sender replacement, unfortunately the cover was already gone, where do you think I got the idea to cut twenty years ago. |
maximan1 Samba Member
Joined: January 07, 2008 Posts: 1354 Location: Anaheim, California
Posted: Mon May 23, 2011 3:15 pm Post subject: |
If you're gonna do it, do it right. It's not hard to drop an engine. Even more so on a early bay. I prefer to have an intact bus and do some more work than to cut into good metal. Just me though. _________________ 1978 Transporter, 2.0L FI |
Posted: Mon May 23, 2011 3:18 pm Post subject: |
Lettuce wrote: |
That looks good. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
kruton Samba Member
Joined: March 27, 2011 Posts: 230 Location: Titusville, FL
Posted: Mon May 23, 2011 4:40 pm Post subject: |
aeromech wrote: |
Lettuce wrote: |
That looks good. |
Yep, if you're going to do it, make it big enough to work freely! _________________ Eric
FlowerPowered Samba Member
Joined: December 22, 2005 Posts: 389 Location: Montana
Posted: Mon May 23, 2011 6:25 pm Post subject: |
Had mine replaced by an ACVW shop while rebuilding my engine. 2 weeks later it was dead. I'm cutting... this is way sweet.
_________________ 76 Westy "Sunset" |
Zelten Samba Member
Posted: Mon May 23, 2011 7:10 pm Post subject: |
Lettuce wrote: |
This gives me second thoughts. _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
kruton Samba Member
Posted: Tue May 24, 2011 2:59 am Post subject: |
Yeah that looks good- the poll is now almost even, I think I'm going to start figuring out a game plan for the hole! _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=460364
Florida Licensed Solar Contractor
NABCEP Certified Solar PV Installer |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
Posted: Tue May 24, 2011 6:25 am Post subject: |
That is nice. Wish the PO had done mine that way.
Cleaning that up is one of my long list projects. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
