jismay Samba Member
Joined: February 02, 2010 Posts: 219 Location: Norco, CA
Posted: Wed Jun 24, 2015 10:11 am Post subject: |
I found an inexpensive 1" memory foam topper.
What I did is shove it inside a duvet cover.
What we found on our cross-country trip is that it was very easy to just roll up the topper + sheets + blankets, and then put our chairs and miscellaneous other things in front of and on top.
Then, when it was time to make the bed we just moved the chair, etc and unrolled the entire bundle. Kept everything clean, even if the chairs had sand,dirt,gravel on them.
At home the entire bundle can be rolled up and fastened closed and then shoved into a closet until the next camping trip. _________________ 1970 Squareback with 1915cc dual 40idf
1979 Beetle Convertible
1980 Vanagon Westfalia
1989 VW Cabriolet |
Nimbus'87 Samba Member
Joined: January 03, 2013 Posts: 125 Location: Murrieta, Ca.
Posted: Thu Jun 25, 2015 9:27 am Post subject: Mattress topper... |
Purchased 2"-2.5" Gel topper from Overstock.
Cal. King cut will fit both top & bottom. Cost was the same as king/queen.
Top was trimmed to 44" to allow for tent @ sides. Only one sleeps atop.
Folded into 3'rds, with top/bottom sheet & light blanket, all fit/compress with no issues up top, behind folded Westy mattress. Pillows are tossed below.
2" Gel compresses to approx. 3/8"
For weight and circulation issues, top is removed when not needed. Stored in trash bag and tossed into garage attic for storage.
Bottom stays folded behind seat with pillows and quilt ready at moments notice.
Huge bonus in comfort. Below 40deg. Gel is stiff till body heat molds to fit and again very comfortable. Seems to work well in keeping cool in summer too.
_________________ '87 Wolfram Grey Westy. '92 2.2 Subie, KEP/Calif. Reg. |
MaineVagabond Samba Member
Posted: Mon Aug 24, 2020 6:01 am Post subject: |
"... the upper bunk cover is grippy and the foam is sticky and it was a real workout without a cover on the foam."
Yup. That's how I destroyed my original foam over 3 years of use. (Trying to pull it forward as I rolled it up, it would stick on the "grippy fabric" and cause the foam to tear.)
I bought new foam and created — enough for a single version and a double version — and had a seamstress create washable covers with sleeping bag zippers. If I'm travelling solo, I bring the single, if I'm not, I bring the double. |
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2239 Location: Olympia, Washington
ledogboy Samba Member
Joined: September 19, 2005 Posts: 578 Location: Scappoose, OR / Oakland, CA
Posted: Mon Aug 24, 2020 8:23 pm Post subject: Re: Mattress topper up top on bunk??? How do you fit it? |
This is what we do, and we are super happy with it. The one thing I dislike was having to inflate it via the bag, but now I have a compressor on board and the job is done in no time! (And yes, this is an example of extreme laziness!) _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
pbrown Samba Member
Joined: July 15, 2008 Posts: 443 Location: Seattle, WA
Posted: Mon Aug 24, 2020 10:16 pm Post subject: Re: Mattress topper up top on bunk??? How do you fit it? |
I just bought one. I've been looking for a solution for the upper bunk. Thanks. _________________ Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF |
Westaru Samba Member
Posted: Tue Aug 25, 2020 9:26 am Post subject: Re: Mattress topper up top on bunk??? How do you fit it? |
The ALPS Mountaineering Lightweight Series Air Pad - Double also fits well:
https://www.amazon.com/gp/product/B004QCJVT4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I had 2x Klymit but eventually went to the Alps as I got sick of pumping them up and deflating every night. Comfort is similar between the two.
FWIW, if anyone is looking I have an extra of the Alps linked above. I purchased 2 of them but we only use 1 on the bottom bunk as the kids don't need the other upstairs. Used only 1x, feel free to send me a PM if you are looking. _________________ 1984 'Westaru' Vanagon Westfalia EJ22
@UtahWestfalia on IG |
JungleJamJohn Samba Member
Posted: Tue Sep 01, 2020 2:16 pm Post subject: |
having read most of this thread, I have a couple observations/questions:
1. How about using a shorter topper that just goes down past your hips. This would use less room, fold and store easier and use less weight, yet you'd have all of the additional cushion you need where it counts.
2. Could a modified hinge be designed and installed to accommodate thicker replacements of the original mattress pads? If so, seems like an opportunity for some motivated engineer to create a kit and make dozens of dollars! |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4352 Location: United States, Iowa
Posted: Tue Sep 01, 2020 2:28 pm Post subject: Re: Mattress topper up top on bunk??? How do you fit it? |
Not at all sure of how it was accomplished, but I have SEEN the top bunk open AND the top down. There's your space, IMHO. I have not tried this. But when I commented to the person about the bunk being deployed and the top down with "I didn't know you could do it" he replied "It's yours, you can do whatever you want!" _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
slapin Samba Member
Posted: Mon Sep 14, 2020 8:45 pm Post subject: Re: Mattress topper up top on bunk??? How do you fit it? |
I am curious how this ancient thread died before the one person who was doing some serious product testing and engineering came up with a solution? Have there been any updates to this age old question? |
pdm777 Samba Member
Joined: August 06, 2012 Posts: 348 Location: Clovis, CA
Posted: Tue Sep 15, 2020 10:46 am Post subject: Re: Mattress topper up top on bunk??? How do you fit it? |
KLYMIT Double V Sleeping Pad.
Light, quick to inflate, very comfortable.
Highly recommended.
replaced a mattress topper that was a pain in the arse. _________________ 1990 Westy Full Camper |
valvecovergasket Samba Member
Posted: Tue Sep 15, 2020 11:13 am Post subject: Re: Mattress topper up top on bunk??? How do you fit it? |
x2
ive been camping in our van the last week while we have house guests and its been incredibly comfortable.
they pack down tiny for storage, and are really quick and easy to inflate using the storage bag as a pump. i like this better for van camping versus some of the self inflating foam sleeping pads we use for ground camping, since typically when we turn the van into "sleep mode" there isnt enough time for those foam pads to fully inflate and i find them a chore to manually blow up. _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
CessnaJon Samba Member
Joined: August 15, 2008 Posts: 677 Location: Senoia,GA
Posted: Tue Sep 15, 2020 11:46 am Post subject: Re: Mattress topper up top on bunk??? How do you fit it? |
I have a Klymit double that I’d gladly swap for a topper. I Love that it is easy to inflate and packs up so small, but I find it uncomfortable. _________________ 1973 Westy (shared birthday)
1990 Westy Multivan
2015 Passat TDI 6sp
2015 Sportwagon TDI 6sp
LR-JET, Gulfstream 159 |
wbailey2112 Samba Member
Joined: October 02, 2015 Posts: 483 Location: Grove City, OH
Posted: Tue Sep 15, 2020 1:00 pm Post subject: Re: Mattress topper up top on bunk??? How do you fit it? |
We carry two of the Klymit Double V inflatable mattresses too. Pack up very small and fit under the bench seat for storage. Dimensions are an exact fit. The key is to also carry a couple of deep full size fitted sheets and use them to hold the air mattresses to the foam mattresses on both the top and bottom beds. Not as nice as memory foam for sure but easy to pack away and much better than sleeping on just the stock foam. _________________ '74 Thing
'83 Westfalia |
Rorke Samba Member
Joined: August 04, 2016 Posts: 255 Location: Traverse City, MI
Posted: Tue Sep 15, 2020 6:20 pm Post subject: Re: Mattress topper up top on bunk??? How do you fit it? |
After 45 consecutive days in the bus, my partner said she needed an upgrade.
We have the Klymit and it is super helpful but loud and bouncy for two.
After reading the description, i had to buy one. I have a few other Fancher"s products. All great. Shipping was fast.
This Should work up top. Only tried down low.
My gal loves it.
https://fanchers.com/shop/ols/products/the-best-me...bric-cover |
Vetterdog Samba Member
Joined: December 23, 2010 Posts: 21 Location: Dirty Jerz
Posted: Thu Oct 01, 2020 9:15 am Post subject: Re: Mattress topper up top on bunk??? How do you fit it? |
Has anyone tried the “Casper Layer”? It’s. 2” mattress topper that is supposed to be fabulous. Originally made for dorm rooms etc so a guest could sleep comfortably on the floor. A twin xl is 37.5 x 79” x 2” and is under $100. I’m considering one since the topper I now use is ok, but only ok. And can I put the top down in my late bay with the bed open? Never tried it! |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu Oct 01, 2020 1:40 pm Post subject: Re: Mattress topper up top on bunk??? How do you fit it? |
We got a 1 1/2" medium density latex foam topper last summer and it has transformed our Westy sleeping experience! I should probably replace the OEM foam in the seat amd mattresses but...
It folds over and stores invisibly on top of the top bunk. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Oct 01, 2020 8:13 pm Post subject: Re: Mattress topper up top on bunk??? How do you fit it? |
FWIW: Any memory foam up to ~2" will still allow you to close the poptop.
Mine was from Overstock.com a few years ago, under $40, cut down slightly
to fit & easily worth twice the price...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Boegrrl Samba Member
Posted: Fri Oct 09, 2020 1:32 pm Post subject: Re: Mattress topper up top on bunk??? How do you fit it? |
Instead of replacing the original pad I simply purchased a Big Agnes self inflating Mattress For a tight and perfect fit. I then added a memory foam that does also get stuffed and tucked away. Best bed ever. _________________ '87 Wolfsburg Weekender |
