dubbified Samba Member
Joined: March 03, 2010 Posts: 1406 Location: Redmond, WA
Posted: Thu Dec 08, 2011 11:09 am Post subject: |
ah, the eurocampers swivel which there were no instruction for..
I snagged two, and cut out the rails from the other seat..
I thought I was being crafty.. and that the seat would sit a tad lower.
DO NOT DO THAT. These swivels mount just as in this thread.
clean install, nice detail on the cover! |
brab Samba Member
Posted: Tue Jan 10, 2012 3:53 pm Post subject: |
How does it fit if you are shorter? Say 5' 3" or so? I would like to put one on the drivers side but don't want my (shorter then me) wife's legs not to touch the peddles.
Brian _________________ Trotro - 87 Syncro Vanagon 40K original miles and starting to count. |
Posted: Tue Jan 10, 2012 4:04 pm Post subject: |
effectively you can move the plate, bolt it where you like..
I moved ours back about an inch or so, as the lady and I are both tall. |
Jedi Samba Member
Joined: October 23, 2007 Posts: 734 Location: Cool California
Posted: Tue Jan 10, 2012 5:08 pm Post subject: |
I have put these in a few of my Vanagons over the years and love the clean install as well. I do not recommend cutting off the cover plate like he did as that is a fire hazard. I like the mount in the rail technique as it can be removed and moved to the next Vanagon if you buy different one. I have noticed that once every year or so the big nut that holds it all together gets loose and needs to be tightened up other than that you can't beat these. I am surprised at how many people here are just now paying attention to this great product
http://www.busdepot.com/details.jsp?partnumber=59500 _________________ 1961 Westfalia SO23 Mango Green/Seagull grey
1961 Westfalia SO34 T/BW
1961 Westfalia SO34 SWR
1964 Westfalia SO33 pearl white
1965 Westfalia SO42 Velvet green
1986 Syncro Wolfram grey with black int GL
1986 Syncro Doka
1987 Syncro Sevana beige Adventurewagen
1987 syncro Sevana beige GL
1973 Pumpkin orange Thing
2 1963 Rag top bug's
1965 Manx
1970 Single cab
1971 combi
1990 Vanagon GL
2007 Audi A4 3.2L quattro |
73thingsale Samba Member
Joined: September 09, 2009 Posts: 103 Location: North Carolina
Posted: Thu Jan 19, 2012 2:03 pm Post subject: This is brilliant... |
An excellent write-up!
That part about turning the seat around and re-installing facing the rear...BRILLIANT!
I just did it in my garage, took under 2 minutes, and WOW, how much space it seems to open up. Our van is a GL, came with the middle 2-person bench. We have removed it since my clan is only 2 adults and 2 kids presently, and holy smoke, how much room is in this bad boy!
Possibly could work out a method to re-install the driver backward, but you'd have to slide it onto the rails from the rear due to the steering wheel and that would require some carpet mods looks like. Hmmm.
Bravo for the post. _________________ Dave
86 GL Hardtop Blue |
lemonspeed Samba Member
Posted: Sun Apr 05, 2015 6:10 pm Post subject: |
Just finished this mod 👍. Took me an hour as I had a time cutting the battery cover and the worst is fiddling with the nuts on the front 2 bolts - trick is to get a skinny flat head under them and hold me up for the bolt to grab .
Also note that this kit from eurocampers has changed from the OG post here and the bolts are all correct length now . All in all pretty happy with it as I missed this feature coming from a Westy ! Happy Easter _________________ Instagram : @overland_van
90 Vanagon Carat "domino"
81 Westfalia (sold) "clemintine"
73 Transporter (sold) "chloe"
80 Vanagon (sold) "brownie" |
katzenjammer Samba Member
Joined: September 22, 2005 Posts: 113 Location: Santa Cruz
Posted: Wed Aug 12, 2015 6:44 pm Post subject: |
I just installed the swivel base from Eurocamper in my multivan. It was tricky getting the two new holes in the rear to line up perfectly with the "two nuts on a plate". I had to drill over-sized holes, but I think that's fine.
As for the battery cover, I just took it off (drilled out the rivets) and let the carpet be the "cover", with the excess tucked under the seat base. I think the positive terminal is well-shielded with the plastic cover.
I like the product, and it's worth it to me not to wrestle with getting the damn seat off the rails and back on every time we arrive at camp (which can be multiple times/camp if we leave for a day trip).
Dan |
Steve O. Samba Member
Posted: Sun Nov 08, 2015 11:13 am Post subject: |
Does anyone have issues turning the driver swivel seat to the rear-facing position? I have an '82 and a previous owner welded the swivel plates. (By the way I do not recommend welding the seats in unless you can do so without closing off the valuable accessory space under the seat.)
The steering wheel prevents full rotation, which renders the upgrade useless. I mean, it's not even close. I have tried every position (lower/raising back rest, forward and back, etc.). _________________ '82 hardtop, factory power with weekend camp regimen. |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Sun Nov 08, 2015 12:43 pm Post subject: |
Steve O. wrote: |
The steering wheel prevents full rotation, which renders the upgrade useless. I mean, it's not even close. I have tried every position (lower/raising back rest, forward and back, etc.). |
My 89 Westy GL has the stock swivels.
Yes the steering wheel interferes with swiveling the eat more than 90 degs facing towards the passenger seat. And even in this position the seat must be very "upright" to fit.
I found it pretty uncomfortable.
I believe the design intent was to allow the driver seat to only rotate to face the table that fits between the passenger and driver seats. For meals?
The arrangement is not very user-friendly.. darn near impossible to get into that seat with the table in its stand.. even of rotated out to gain access.
I have never used it in regular camping.
I did set it up once in the driveway and thought.. "That's not a very comfortable or practical setup.." and from that point forward have never bothered to use the drive seat swivel again.
Others may ave a sweet spot that works for them. I certainly did not. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
kamzcab86 Samba Moderator
Posted: Sun Nov 08, 2015 1:02 pm Post subject: |
j_dirge wrote: |
I believe the design intent was to allow the driver seat to only rotate to face the table that fits between the passenger and driver seats. For meals? |
Well, in the full-camper, even if you could rotate it 180°, it wouldn't be very a comfortable sitting position:
In my van, the left armrest has to be lowered in order to get the full 90° rotation... annoying. When parked, I put my clothes bag on the driver's seat. I haven't swiveled my driver's seat in years.
If you install a smaller steering wheel, you might be able to get the full 180º. _________________ ~Kamz
2016 Golf GTI S
alohah3 Samba Member
Joined: July 31, 2012 Posts: 22 Location: Alexandria, VA
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Jan 07, 2017 6:58 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
Sorry to say, I wouldn't want that big lever sticking out into the aisle between the front seats.
Haven't installed my camper swivel into my Weekender yet, but looking forward to having
the option...plan to get to it this spring...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
mugford Samba Member
Posted: Sat Jan 07, 2017 8:47 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
I just installed the bolt-on swivel adapter on the passenger side and I'm not happy with it impeding access to the battery. I've even installed it 'forward' by one bolt position
using four bolts instead of the supplied eight.
Currently looking for a semi-removable solution that allows the front to be secured with a hinge or tab-in-slot thing so that I can tip the rear of the seat mount up.
The challenge is securing the rear edge without too much chopping & welding. Using wingnuts or the equivalent at the rear would then allow me to retain the original
battery cover tucked under the swivel mount.
I'll definitely post some pics when I come up with a viable approach. |
Slimvest Samba Member
Joined: March 20, 2014 Posts: 431 Location: Portland, OR
Posted: Thu Aug 10, 2017 2:01 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
RE: http://www.eurocampers.com/Vanagon-Swivel-Adapter-_p_605.html
Anybody have this and it squeaks loudly whenever a passenger is seated and driving over bumps? When my wife is sitting shotgun, the creaking is driving me nuts.
Saw someone noting the main bold needs tightening every so often, but I'm wondering if there is a hack to put in the plastic slides similar to GoWesty's to keep things more stable.
http://www.gowesty.com/product-details.php?id=23883 _________________ '87 GL w/ Reimo top |
laroche.chris Samba Member
Joined: April 27, 2013 Posts: 16 Location: United States
Posted: Thu Feb 22, 2018 4:37 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
I just got my swivel seat adapter plate and thought I’d read up before putting it on.
I am concerned about accessing the battery. Someone out there must have done it in a way the battery can be accessed? (Then again, how often do I access that battery...).
I’m also a little confused about the parts to attach it, specifically the two pieces that are about 2” long and have the holes in them. Where do these go and how do you get them there?
Otherwise it seems pretty straight forward... |
Aryana Samba Member
Joined: November 09, 2015 Posts: 568 Location: Southern CA
Posted: Fri Feb 23, 2018 3:03 am Post subject: Re: Bolt-on Swivel Seat for Vanagons |
Swivel seat installed in my tintop with access to the battery via a remote quick connector out the front of the pedestal. It’s very easy to reach in under the seat and plug it in. If you wanted to, you could cut out the front wall of the pedestal to give you even more access to the connector from the front (like the OP of this thread showed).
If you don't like that setup, you can always cut a hole and mount the plug on top of the pedestal just outboard of the battery cover. You'd have to cut a hole in the cover to allow the cables to pass through outside of the pedestal. I have a young child and preferred having the connector hidden away.
Aryana Samba Member
Posted: Fri Feb 23, 2018 3:07 am Post subject: Re: Bolt-on Swivel Seat for Vanagons |
laroche.chris wrote: |
The nut plates slide inside your original seat rail and the bolts go through the swivel base, then through a hole in the rail, and into the nut plate. When you tighten the bolt it sandwiches everything together securing the swivel base.
If you didn't have the nut plates, you'd have to try and slide a nut inside the rail, somehow line it up with the hole that the bolts will be coming down through, and then you'd have to somehow jam it from rotating as you tighten the bolt. The nut plate solves all those problems. It's quite evident how it all works when you have the kit in hand. |
pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Fri Feb 23, 2018 7:55 am Post subject: |
mackaymanx wrote: |
jbart wrote: |
I am planning to add a swivel too, but my concern here is your exposed terminals in relationship to the swivel bracket. the photo looks like they are touching. possible short coming in the near future?
He is missing the proper plastic cover for the battery terminal |
Should probably glue a layer off semi rigid plastic or rubber on the underside of the cut-down cover. The cut made it more flexible, so treatment - both the battery terminal cap and the insurance of a non-conductive material on the underside of the cover. |
takeiteasy Samba Member
Joined: August 11, 2016 Posts: 169 Location: New York, NY
Posted: Sat Jun 23, 2018 5:07 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
Just want to confirm - you cannot remove the battery when this installed ? _________________ '85 Weekender 1.9L
"With your past and your future precisely divided.
Am I at that moment? I haven't decided." |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Fri Jan 04, 2019 10:34 am Post subject: |
oorwullie wrote: |
just a wee tip for people who want to be able to have a rear facing passenger seat at absolutely no cost whatsoever: you simply slide the seat forwards and off the rails and re- install it facing backwards. |
i was reading up on swivel bases for my tin top GL and found this bit of "secret knowledge"
thank you oorwullie for this post, you saved me from myself.
i love cool things that cost nothing. _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
