inorganic Samba Member
Joined: September 26, 2016 Posts: 60 Location: Portland, OR
Posted: Wed Jan 23, 2019 11:58 am Post subject: Re: Bolt-on Swivel Seat for Vanagons |
Aryana - this is a really smart build. I have a small electric leak some where which means I access the battery to charge somewhat frequently. A couple of questions =
(1) Where did you get that connector?
(2) It looks like your negative/ground to the connector goes from the terminal (via braided copper wire) to a nut bolted to frame - is that correct?
Aryana wrote: |
Swivel seat installed in my tintop with access to the battery via a remote quick connector out the front of the pedestal. It’s very easy to reach in under the seat and plug it in. If you wanted to, you could cut out the front wall of the pedestal to give you even more access to the connector from the front (like the OP of this thread showed).
If you don't like that setup, you can always cut a hole and mount the plug on top of the pedestal just outboard of the battery cover. You'd have to cut a hole in the cover to allow the cables to pass through outside of the pedestal. I have a young child and preferred having the connector hidden away.
_________________ '86 SYNCRO Weekender |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12007 Location: Santa Cruz, CA
Posted: Wed Jan 23, 2019 3:31 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
That is a Anderson SB connector or some copy of it.
I shortened the plate and welded reinforcement on it to make battery access and removable possible. |
Posted: Wed Jan 23, 2019 4:23 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
Thanks for the info about the cord.
Your approach sounds interesting. Can you share any photos of it? I have a welder and plenty of steel to over engineer solutions!
syncrodoka wrote: |
Aryana Samba Member
Joined: November 09, 2015 Posts: 568 Location: Southern CA
Posted: Wed Jan 23, 2019 8:59 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
1.) I bought the cord from the Samba famous, Terry Kay
Scroll near the end of this page to “Vanagon Permanent Mount 12 Volt Jumper Cable Plug & Cables”. Make sure you’re really polite and don’t ask too many questions or else he can get a bit upset and may start to blow you off even if you want to buy something.
http://vanagonwestfaliaaccessories.com/
2.) Yes, the ground strap is bolted to the chassis as you describe. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Thu Jan 24, 2019 4:37 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
Aryana wrote: |
1.) I bought the cord from the Samba famous, Terry Kay.... Make sure you’re really polite and don’t ask too many questions or else he can get a bit upset and may start to blow you off even if you want to buy something.
_________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Aryana Samba Member
Posted: Thu Jan 24, 2019 7:16 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
LOL!
Exactly |
floodwood Samba Member
Joined: October 22, 2017 Posts: 164 Location: Cambridge, MA
Posted: Tue Dec 15, 2020 10:41 am Post subject: Re: Bolt-on Swivel Seat for Vanagons |
Has anyone installed this swivel converter recently?
A quick call to bus depot informed me that the swivel base will hang over the battery cover by 1-2", and that the easiest solution is to disconnect the battery box hinge, essentially allowing you to slide the cover off rather than "hinge" it off.
Does anybody have any pictures of their install so I can ensure the swivel base won't interfere with my battery terminals as well?
Link to busdepot product: https://www.busdepot.com/59500
Cheers! |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1890 Location: Montreal
Posted: Tue Dec 15, 2020 4:16 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
That connector is a typical forklift connector. |
DuncanS Samba Member
Posted: Tue Dec 15, 2020 4:41 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
And you can also mount it at 90º without a swivel. Had a turntable once, but got rid of it as it eliminated the under seat storage--at least for my usage. Careful grinding is all it takes, but you can't drive with it sideways. Not secure enough, but fine for lounging. |
Slimvest Samba Member
Joined: March 20, 2014 Posts: 431 Location: Portland, OR
Posted: Tue Dec 15, 2020 5:12 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
floodwood wrote: |
Cheers! |
Had mine for a number of years. Fine for what it is. Does it's job but has some drawbacks. It's very tight getting jumper cables on the battery terminals. I have an OEM swivel I'm meaning to weld in at some point. _________________ '87 GL w/ Reimo top |
Squidfish Samba Member
Posted: Tue Dec 15, 2020 9:05 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
floodwood wrote: |
I did mine last week and you will need to modify your lid to work. I removed my hinge years back and would agree, sliding it out is the best method to work with. The terminals are quite close to the edge of the swivel base/covering them halfway; I like the idea of the quick connect terminal as shown in the thread above, especially under the seat (I have children too that it would dangerous to have out). _________________ 1985.5 - Vanagon Westfalia Weekender Wolfsburg Edition - LH8U - "Penny"
- 2.6i 5-Cylinder 10v (2004) |
jimf909 Samba Member
Posted: Tue Dec 15, 2020 10:28 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
vanagonjr wrote: |
Aryana wrote: |
Here's how that's done..
_________________ - Jim
Abscate wrote: |
Aryana Samba Member
Posted: Wed Dec 16, 2020 11:40 am Post subject: Re: Bolt-on Swivel Seat for Vanagons |
jimf909 wrote: |
vanagonjr wrote: |
Aryana wrote: |
Belushi, Murray, and Aykroid were pure magic together! 👍🏼 |
Posted: Thu Dec 17, 2020 3:06 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
Thanks all for the advise.
Would it be possible/advisable to simply cut out the portion of the swivel that gets in the way - cutting in-between the rail portion? Crappy drawing below.
Posted: Fri Dec 18, 2020 7:25 am Post subject: Re: Bolt-on Swivel Seat for Vanagons |
Of course. I thought that's what everybody did. I did. Worked fine. The extra carpet can flap in the breeze just fine. It doesn't need supporting. Or cut that too if you like. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Fri Dec 18, 2020 9:03 am Post subject: Re: Bolt-on Swivel Seat for Vanagons |
You asked about cutting the swivel base plate so the full cover door can open. Cutting the battery cover door is preferable in my book. That is what I do when I install a front seat swivel assembly. The door hinge is held to the van by a few pop rivets. Drill the heads off the rivets, cut the door to fit, pop rivet it back where it was. Cut slightly more than what you think, so the carpet flap has room to flip too.
Mark
floodwood wrote: |
.....Would it be possible/advisable to simply cut out the portion of the swivel that gets in the way - cutting in-between the rail portion?.... |
Posted: Fri Dec 18, 2020 10:42 am Post subject: Re: Bolt-on Swivel Seat for Vanagons |
crazyvwvanman wrote: |
Mark
floodwood wrote: |
Thanks - my above post was in reference to the actual swivel seat base rather than the battery box.
My concern is more for battery access, whether the cover is removed so it slides off versus cutting the cover, it seems access to the actual battery will still be impeded if the swivel base is on.
This is why I am looking to see if it is feasible to cut into the actual swivel base itself. Is this possible without destroying the function of the swivel base? |
Posted: Fri Dec 18, 2020 8:56 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
About 6 months ago, a guy sent a bunch of good posts and photos showing how he hinged the swivel base on one side. He had a pull out pin which allowed it to hinge up. This is the only way I would consider putting in a swivel seat. Interior storage is at a super premium and why would you give that up for the few times you want to swivel the seat? Far simpler to just install the seat backwards. If you drill out the pop rivets on the flap, the whole thing will hinge back on the carpet and give clearance for the seat slides so it can go in from the back as well. Remove the tabs which prevent this on the base slides. Also get rid of the spring thingy which keeps the seat from being able to go out the front without releasing it. Why would you ever need that?
IMHO, the swivel isn't worth it. Too expensive, robs stowage, screws up the batter location and raises the seat an uncomfortable inch. And not really needed with the mods I advocate. |
Posted: Fri Dec 18, 2020 9:15 pm Post subject: Re: Bolt-on Swivel Seat for Vanagons |
syncrodoka wrote: |
I lopped off the back and reinforced it with 1/8" angle. The battery comes straight up and out if needed. I don't have factory seat tracks on the swivel base any longer so that may be a consideration, I don't remember how far back those went on the platform.
Posted: Sun Dec 20, 2020 10:19 am Post subject: Re: Bolt-on Swivel Seat for Vanagons |
syncrodoka wrote: |
syncrodoka wrote: |
I lopped off the back and reinforced it with 1/8" angle. The battery comes straight up and out if needed. I don't have factory seat tracks on the swivel base any longer so that may be a consideration, I don't remember how far back those went on the platform. |
Thanks this is what I was looking for. Do you have any other pictures of your swivel?
The tracks come all the way back per bus depot's picture, but since the tracks are on either side of the battery box (battery box fits in between the tracks) - would just be looking to cut the metal between the tracks. |
