Operation X Volksrod
Page: 1, 2, 3 ... 40, 41, 42  Next
VOLKSWAGNUT
Fastest VW Belt Changer
VOLKSWAGNUT is offline
PostPosted: Sun May 29, 2011 7:48 am    Post subject: Operation X Volksrod Reply with quote
New VW project in the works for me the next year. It wlll be called "Operation X".
I aquired a running 65 Corvair 4 carb 140 engine a few years ago. It is all ready reverse rotation, lumpy cam'd, with the VW transaxle adapter, and flywheel, so it's just waiting on me. I have a decent "early" 67 Beetle body soon to be placed on a 65 pan, and it's to be as light as possible. SHHHHHH dont tell the 67 purist. Speak to the hand A "sleeper" version.....somewhat. I am building this on a very VERY low budget, with parts left over from junkers and other projects, so big money parts is only as a neccesity. "One piece at a time". Hey that might make a good song. Laughing
I know I will be stressing the transaxle, and have been told it should be fine as long as I dont "dump the clutch" or try a "burn out". I know myself and my history with Hot Rods....sooooo that's probably in the future. I dont want to be pulling the transaxle after every run or drive.
What should I consider installing in a Beetle transaxle to help the extra stress.
My guess would be a stonger differential carrier is a must. Is there anything else to consder to be on the top of the list.
I dont plan to abuse this, but it will see an occasional blast down the strip.
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
Mooosman
Mooosman is offline
PostPosted: Sun May 29, 2011 8:01 am    Post subject: Reply with quote
How long is the Corvair engine from end to end? It's probably too long for the beetle engine bay... Confused
(o\ ! /o) '69 Beetle---Subaru EJ22 powered---SOLD
VOLKSWAGNUT
PostPosted: Sun May 29, 2011 8:06 am    Post subject: Reply with quote
Its tight and yes it will require mods and cuts to the body sheet metal, but it fits. I may have to move the oil filter, and of course adjust the apron to fit. Probably build a custom apron, and maybe use some stand offs. I'll judge that once it's fully in place. I'm NOT going for a stock looking Beetle anyway. I NEVER do.
I'm going for a nostalgic look and sound with an interseting powertrain that was popular in the era of the car. Good conversation piece at events I really could care less about engine bay aesthetics. Confused
aka Ken {o\!/o}
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Sun May 29, 2011 8:12 am    Post subject: Reply with quote
My 1915 makes more power than a 4-carb Corvair does, I wouldn't worry about the trans.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
VOLKSWAGNUT
PostPosted: Sun May 29, 2011 8:17 am    Post subject: Reply with quote
Really? Do you run a stock swing axle transaxle and occasionally abuse it off the line?
Consider the Corvair engine is heavier....longer... and has a displacement of 2.7L. Good torque down low.
I love VW's and really would rather have a large displacement VW engine...but again it's a very low budget, using what I got in stock at no extra cost.
The Corvair engine looks and sounds pissed off just sitting on the ground. Twisted Evil I gotta use it, just because you dont see that conversion much anymore.
aka Ken {o\!/o}
MinamiKotaro
MinamiKotaro is offline
PostPosted: Sun May 29, 2011 8:41 am    Post subject: Reply with quote
Dad's got a 4-carb 140 Corvair in his '72 Super. Had to eliminate the rear apron and it still sticks out pretty far.
At least get a 4-spider diff for your trans. A stock 1600 can waste a stock diff after a couple of hard launches.
1967 VW Beetle
2276cc
MegaSquirt-extra v3.57
Check out my ongoing story.
VOLKSWAGNUT
PostPosted: Sun May 29, 2011 8:47 am    Post subject: Reply with quote
Yep my thoughts exactly.
aka Ken {o\!/o}
volken65
volken65 is offline
PostPosted: Sun May 29, 2011 10:20 am    Post subject: Reply with quote
You should get a modified generator mount for remote oil filter system. That'll help fit it under the hood better.
VOLKSWAGNUT
PostPosted: Sun May 29, 2011 10:34 am    Post subject: Reply with quote
By the measurements the Generator is not an issue under the lid. (I may be wrong). It may be close. If I have to ad stand offs I will as a last resort. I will cut the upper portions out of the apron leaving only enough area to catch the edge and lower tear drop of the 66 louvered decklid I am using. The oil filter will most likely interfere with the apron, so I may change it to a remote. Time will tell.
I am not concerned at all about fitting. I can make it work. It will be a few months before I can actually start wrenching on it. Ill update and keep this going a long the way. I wanted to hear the thoughts on the transaxle mainly.
aka Ken {o\!/o}
miniman82
Samba Swamp Donkey
PostPosted: Sun May 29, 2011 11:04 am    Post subject: Reply with quote
Yes, and I abuse it off every line. Cool
OLD VW NUT
OLD VW NUT is offline
PostPosted: Sun May 29, 2011 6:40 pm    Post subject: Reply with quote
Years ago someone made an engine cover for that conversion. It was called the Bustle-Bomb IIRC. You might try running an ad in the classifieds and see if anyone comes up with one for your car.
I love the old Corvairs nearly as much as I love the ACVWs. I had a few of them - my favorite was a 65 with the 140 motor. It was fast! Don't be too tempted to change out the 4 carbs for something centered like the 390 4 barrel Holley. Not that it doesn't work great but if you live in an area where it gets cold and rainy you'll have carb icing. There is no way to get heat into the manifold other than routing air off the motor to heat the air intake - not the best solution. There is a way to mount a pair of 3 throat Weber carbs on the Corvair motor if you are willing to hack the intake manifold up but thats part of the head - screw that up and you scrap an expensive head.
Here's an article about the Crown conversion:
http://www.beachbuggyclub.com/article.php?article_id=5
71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2012 Nissan Leaf SL EV
Check out my 71 Ghia for sale ad.
vaughn bros.
vaughn bros. is offline
PostPosted: Sun May 29, 2011 6:50 pm    Post subject: Reply with quote
vugbug68
vugbug68 is offline
PostPosted: Sun May 29, 2011 6:57 pm    Post subject: Reply with quote
they make an adapter to run dual webers on a 140 vair motor, I was very tempted to that on my homegirls covair engine i just built. She has a 66 4 door vair Very Happy but decided she would get into trouble with that much power, so i put 110 heads on a 140 block with stock dual carbs and called it good. runs great but i can only imagine what the 140 heads with 44 webers would have done... it already has a corsa 4- speed tranny
71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin
OLD VW NUT
PostPosted: Sun May 29, 2011 7:35 pm    Post subject: Reply with quote
The 140 motor was identical to the 110 motor - same cam etc - just add the 140 heads and you have a 140. Both are 164 cubic inch. The 140 heads added the two secondary carbs plus the larger valves for another 30 hp.
miniman82
Samba Swamp Donkey
PostPosted: Sun May 29, 2011 7:43 pm    Post subject: Reply with quote
PG equipped cars had a different camshaft, giving slightly more HP. Swap a PG cam into a stick, instant upgrade! Course if you're gonna change the cam, why not spring for an Isky 280 right?
I redid my 180 turbo motor a year or so back, did bearings, Isky turbo grind cam, new springs, new turbo, open exhaust and a crank trigger ignition. With a stock carb it was way faster than guys with q-jets, though the q-jet may be another bone of contention...
BugMan114
BugMan114 is offline
PostPosted: Sun May 29, 2011 8:09 pm    Post subject: Reply with quote
I've done plenty of burnouts on my stock tranny with my stroker motor, and several hard launches, and i haven't had any problems yet. Not sayin its going to last forever, but at the same time, stock tranny's are a lot stronger then most people give them credit for. I do run solid mounts, which seems to eliminate damaging wheel hop (no
In my opinion, if you are going to drive it daily, with the occasional burnout, or hard launch, i'd say a stock tranny will do for a while, especially if your on a budget, like 99% of the people on this site (not like the 1% who tell you to just order a $4K rancho trans, lol) Laughing
1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!!
VOLKSWAGNUT
PostPosted: Mon May 30, 2011 7:03 am    Post subject: Reply with quote
As far as the cam.. I know its not original as it's reverse rotated, and judging by the overlap at idle, its a lumpy grind.
I was actually fortunate to talk to the wife of the engine/car bulider. She knew quite a bit, and said her husband (now deceased) had built it from scratch. She knew about it being reversed, with a mild cam grind as well as a fast powerplant for the Dune Buggy I had purchased. She said in the 70's it was the fastest Buggy in her area.
Budget yes low budget.
The most I'd probably go for is a super diff, but I may just wait to see how long a stock one lasts. Like I said I have plenty of swing axles.
Solid mounts will be a definite, plus an added support at the rear to hold that flat 6 monster in place.
aka Ken {o\!/o}
VWporscheGT3
VWporscheGT3 is offline
PostPosted: Mon May 30, 2011 8:07 am    Post subject: Reply with quote
be prepared to flip the ring gear on the diff. my dad had a turbo vair with a foot and a half cut out the middle and welded back together. he said the car liked to snap stub axles. and in true 70's fashion it had a dragon painted on the hood with flames going down the nose and around the sides... and on the back painted in gold leaf was "the nothing" thats as close to volkswagens as my dad ever got.... lol
-Trevor
Schnell, Schnell!!!
VOLKSWAGNUT
PostPosted: Mon May 30, 2011 8:27 am    Post subject: Reply with quote
Once again for the nose bleed seats. Laughing
My engine is converted to reverse rotation.
No ring gear flip is required.
It spins the same diection as a VW engine now.
aka Ken {o\!/o}
VWporscheGT3
PostPosted: Mon May 30, 2011 9:26 am    Post subject: Reply with quote
dont get your panties in a twist Laughing not everyone is as keenly attentive as you are Rolling Eyes
Schnell, Schnell!!!
Page 1 of 42
