Blix Samba Member
Joined: August 12, 2009 Posts: 131 Location: Fort Collins, Colorado
Posted: Sun May 29, 2011 4:18 pm Post subject: Replacing cigarette lighter receptacle |
Hey everyone, I have a satellite radio for my main car. It plugs into the cig lighter for power. This is the only option it has for power. The problem is the Vanagon receptacle is a little shorter than the modern cig receptacles that this is made for. So while it works it doesn't snap in like it should and just falls out if you let go if it.
What would be a solution for this? replace the receptacle with a newer one? if so could someone kind of walk me through the process or point me to a diy thread?
I also have an auxiliary battery installed with an inverter, so maybe there is a plug to cig receptacle device?
any help is appreciated and thanks _________________ When I say whas up, you know where I'm from.
84 Westy |
snowesty Samba Member
Joined: September 06, 2005 Posts: 189 Location: Nelson, BC
Posted: Sun May 29, 2011 4:34 pm Post subject: |
I've done two things. One, I replaced the cigarette lighter with a proper power port. Every thing fits better, and has a little rubber cover. Big improvement. I have a number of them around the van. All run off the house battery. Two, I installed a female power port on a pigtail that just sits inside the dash. My tablet (Samsung Galaxy Tab, percent size for the dash btw...) has a charger that runs through the ash tray and stays permanantly plugged in. That way there are no cables having down from a device that spends alot of time there... _________________ Fritz - '86 Syncro Tintop, Camper interior
Toaster - '91 Multivan Westy, 4sp. |
Blix Samba Member
Posted: Sun May 29, 2011 4:47 pm Post subject: |
snowesty wrote: |
I've done two things. One, I replaced the cigarette lighter with a proper power port. Every thing fits better, and has a little rubber cover. Big improvement. I have a number of them around the van. All run off the house battery. Two, I installed a female power port on a pigtail that just sits inside the dash. My tablet (Samsung Galaxy Tab, percent size for the dash btw...) has a charger that runs through the ash tray and stays permanantly plugged in. That way there are no cables having down from a device that spends alot of time there... |
Hey sounds great man, any chance you could break down the process for installing a new one for me? Do i need to remove the dash to get the receptacle out? Thanks _________________ When I say whas up, you know where I'm from.
84 Westy |
wjjr Samba Member
Posted: Sun May 29, 2011 5:00 pm Post subject: |
Blix wrote: |
Do i need to remove the dash to get the receptacle out? Thanks |
Nope, just pull the glove box and go in through there _________________ '90 Vanagon Carat auto x2
'87 Vanagon Gl Syncro
'85 Vanagon Wolfsburg Weekender (poptop) |
Posted: Sun May 29, 2011 5:02 pm Post subject: |
Ripping the old one out took all of two minutes with a pair of pliers. Of course there isn't much left of the old one when you are done. But who cares, right? Join in the wires, afix the new plug, done. Ten min job. All good.... _________________ Fritz - '86 Syncro Tintop, Camper interior
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9770 Location: Mt Lemmon, AZ
Posted: Sun May 29, 2011 5:05 pm Post subject: Re: replacing ciggarette lighter receptacle |
Blix wrote: |
...What would be a solution for this? |
I have been known to jam half of a spring-type clothes pin in alongside the plug to keep it from falling out. A popsicle stick works to.
Have you consdered using the 'silver plug' outlet for the radio? That would side step the problem and also leave the lighter outlet available ofr other use. |
Blix Samba Member
Posted: Sun May 29, 2011 5:59 pm Post subject: Re: replacing ciggarette lighter receptacle |
Ahwahnee wrote: |
Blix wrote: |
good idea about the plug. i always wondered what that plug was for. how do i adapt it? is there an adapter readily available?
also i just went to flaps and they had like ten different replacements to choose from so i came home to take the receptacle i have out so i can match it up correctly when i go back...
found this guide
http://www.vanagonauts.com/Cigarette-Lighter-R&R211.htm _________________ When I say whas up, you know where I'm from.
84 Westy |
Posted: Sun May 29, 2011 6:34 pm Post subject: Re: replacing ciggarette lighter receptacle |
Blix wrote: |
...good idea about the plug. i always wondered what that plug was for. how do i adapt it? is there an adapter readily available? |
Lookee here:
http://www.ratwell.com/technical/SilverSocket.html |
Sir Sam Samba Member
Joined: July 19, 2009 Posts: 1669 Location: Fort Collins Colorado!
Posted: Sun May 29, 2011 6:45 pm Post subject: |
I grabbed a couple of these with the last gowesty order:
http://www.gowesty.com/ec_view_details.php?id=4482&category_id=&category_parent_id=
You used to see lots of "surface mount" 12V outlets, not so much anymore, I searched around online quite a bit looking for a cheaper alternative but couldn't easily find one similar. _________________ '91 Carat Westy
87' Syncro + '87 Westy conversion coming soon |
dplumtree Samba Member
Joined: October 23, 2010 Posts: 68 Location: Alberta,Canada
Posted: Sun May 29, 2011 8:10 pm Post subject: |
just did it. taking the ashtray out and the glove box out you can get at it with 2 angles. if you have a stock VW lighter they say you can twist them apart. mine was frozen shut so the pliers job as stated above did the trick. it does make a mess of it though so you are committed to replace it. mine, a 1990 camper had a plug on the end and wasn't complatible with the canadian tire one i bought to replace it. so i snipped the plug off and crimped some spade connectors on and i was good to go. make sure you disconnect your battery. good luck and expect some grazed knuckes. |
outwesty Samba Member
Joined: June 06, 2006 Posts: 1074 Location: Tahoe City
Posted: Sun May 29, 2011 9:21 pm Post subject: |
Go to a napa and check out there book behind the counter. They have many more styles available than what is on the shelf. I found one that was almost identical to the original with the outside illuminated ring. Sorry I don't have the part #. _________________ www.outwesty.com Vanagon / Syncro Repair in Tahoe City, CA |
a914622 Samba Member
Joined: July 29, 2004 Posts: 835 Location: Westend of HWY2 , Wash
Posted: Mon May 30, 2011 10:01 am Post subject: |
I changed my stock 87 one for a subaru "powerport" flip cap. I did it during a CD swap out. I took my time getting the stock one out. Dont make that mistake. Its going in the garbage!! The Subaru have a scew back. Iv also been working on putting in a pop out one from a 99 audi wagon in the back.
jcl _________________ 87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru |
plummerdesign Samba Member
keving Samba Member
Posted: Thu Jun 02, 2011 7:57 pm Post subject: |
WOW! I've been wondering what the heck that was in my '84 since I got it. Thanks! _________________ 84' Westy |
BillM Samba Member
Joined: June 18, 2004 Posts: 1381 Location: Stonington,CT
Posted: Fri Jun 03, 2011 2:53 am Post subject: |
I just replaced my front stock outlets with one from West Marine. The new outlet comes screwed to a large mounting plate. I removed it from the plate. Made a two inch pigtail that plugs directly into the factory plug. It took a little bit of force but it fits very tight in the factory hole in the dash. Locked it down with the supplied nut from the back and it's rock solid. The gps,cell phone charger,etc. all plug in very nice. Plus it has a nice cover that keeps the little ones from sticking coins into it. (I have a Ford that has a outlet in the rear that the kids have dropped a coin into before and it is a bear to get it out after the fuse has blown of course). The West Marine outlet set I got came with two outlets so I will replace the one I have in the rear with the new extra one so the front and fear plugs match. Total cost was just under 20.00 for two quality marine grade outlets. Even came witha few push on crimp connectors.
Bill |
iliketowalk Samba Member
Joined: April 29, 2011 Posts: 614 Location: Northern CA
Posted: Fri Jun 03, 2011 10:14 am Post subject: |
Just installed two of these: http://www.amazon.com/Marinco-12V-Receptacle-Blk-P...mp;sr=8-11 -- $15
Front mounting plate is optional, comes with screws and (2) 10-12 gauge terminals.
One in the dash to replace the old one (it's a tight fit but you can actually thread it in without having to enlarge the hole), and one under the back seat. |
K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Sat Jun 04, 2011 3:19 am Post subject: |
The Parts Express version is a knock-off of the Marinco design. It does not offer the same quality of materials (rear casting of housing not as resilient and the rubber cap doesn't fit as well), but it should serve its function fine for the in-dash application. Digi-Key sells this same socket for $3.00 http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=AS212-ND
I would personally spend the extra money for a real Marinco or a Blue Seas power socket. If you have a decent boating supply store near you, it might turn out to be about the same price to buy the real deal rather than paying shipping for a single small item like this. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
BillM Samba Member
Posted: Sat Jun 04, 2011 5:12 am Post subject: |
These are the plugs i used from West Marine. I bought the double but have only installed the one so far. Seems to be of reasonable quality.
http://tinyurl.com/6bexoxn
I am satisfied with it and so far has held every plug tight.
Bill |
K58 Samba Member
Posted: Sat Jun 04, 2011 12:06 pm Post subject: |
Did I mention mine shipped free.....no worries Mate |
