Ethan5150 Samba Member
Joined: September 01, 2010 Posts: 294 Location: Los Gatos, CA
Posted: Mon May 30, 2011 7:42 pm Post subject: DIY Window Tinting |
I've seen a few threads on The Samba about window tinting but none seem to focus on the DIY type. Has anyone had experience with the DIY tinting? What brand did you use? How was installation? Etc. I'm thinking about taking this on but I'm trying to determine if I should just pay a shop to do it. Thoughts anyone? _________________ "It is no measure of health to be well adjusted to a profoundly sick society" - Krishnamurti |
Zeitgeist 13 Samba Member
Posted: Mon May 30, 2011 7:47 pm Post subject: |
I attempted to apply window tint on my Mercedes wagon at one point, but gave up in abject failure within moments of beginning. After that, I felt really good about spending the $245 to have it done professionally. I think you want the high quality 3M stuff which doesn't turn purple on you after a couple years. I may have my van done this year to help assist the AC to do its thing. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Mon May 30, 2011 7:50 pm Post subject: |
DIY window tinting is like a toupee.
Pretty easy to spot and seldom looks good.
Of course maybe I have looked at a DIY tint job and it was so good that I didn't realize that was what it was. Same could be true for the toupees.
Nah, I don't think so. |
ProvoCyclist Samba Member
Joined: December 07, 2004 Posts: 593 Location: Murray, Utah
Posted: Mon May 30, 2011 7:51 pm Post subject: |
Seconded. I did a DIY job on mine, but I never was super happy about it. After about a year, it was quite faded, not purple, but it was still pretty faded. I had a local tint shop do mine, and it is perfect. _________________ Clark
Current: 1986 Tintop GL 2wd, stock 2.1L, manual trans, Flash Silver LP7Y.
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A |
a914622 Samba Member
Joined: July 29, 2004 Posts: 840 Location: Westend of HWY2 , Wash
Posted: Mon May 30, 2011 7:53 pm Post subject: |
The prev-owner of mine tried to use the cheap stuff from walmart. It is crap.
There is a Foam Store on 196th in Lynwood that sells the real auto tint for like 2.90 a foot in 40 inch wide. Clean the windows with soft scrub, fiberglass safe, to get all the oils off the glass. go slow and fallow directions.
jcl _________________ 87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru |
srmpf Samba Member
Posted: Mon May 30, 2011 7:54 pm Post subject: |
get the best tinting foil you can get (3M brand). The two back side windows are easy with a little bit of practice. I still have to do the sliding windows (need to figure out how to get the glass out). the rear window is a PITA - I gave up after wasting the foil two times. this window is not flat as the other ones and you have to heat shrink the foil.
In summary: check yelp for a good professional window tinter and save a lot of time and energy. |
Posted: Mon May 30, 2011 8:19 pm Post subject: |
Wow, excellent info! Sounds like the pro job is the way to go. Thanks everyone! _________________ "It is no measure of health to be well adjusted to a profoundly sick society" - Krishnamurti |
Crankey Samba Member
Posted: Mon May 30, 2011 8:20 pm Post subject: |
if you have the skill, all you need is the good tint material. like others have said, not the cheap crap at shucks etc. go to a tint shop and see if they will sell you the material. |
r39o Samba Polizei
Posted: Mon May 30, 2011 9:32 pm Post subject: |
Do NOT do it yourself.
http://www.tintdude.com _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
vanjoe Samba Member
Joined: December 25, 2009 Posts: 606 Location: Santa Maria
Posted: Mon May 30, 2011 10:09 pm Post subject: |
Good tint and A LOT of patience and practice. I have tinted windows in the past and it is fun to try to do. When you finally get it down and do a good job it does feel good. I practiced on the drivers side rear yesterday and it came out good. I am going to go ahead and do the rest. I am going with a 2 1/2% which is very dark. I will post the pics when I am done. The hardest part is getting it trimmed at the rubber seal of each window. It you don't trim it good it will look like crap. Sqweeging the air bubbles is easy if it is trimmed properly. A tint shop I went to wants $430. _________________ 1990 VW Vanagon tin top weekender Carat
1998 Mercedes S420
"Why is there never time to do it right the first time, but there is always time to do it twice?"
"Back to the basics!" |
Posted: Tue May 31, 2011 12:52 am Post subject: |
probably not a bad price. it's fussy work. |
srmpf Samba Member
Posted: Tue May 31, 2011 8:52 am Post subject: |
vanjoe wrote: |
I practiced on the drivers side rear yesterday and it came out good. |
wait for the rear window - i promise, you'll be happy to spend the $430
The side windows are flat but for the rear you need to heat shrink the foil. I gave up after trying two times. |
unibagel Samba Member
Joined: December 02, 2004 Posts: 529 Location: Bflo, NY
Posted: Tue May 31, 2011 9:00 am Post subject: |
I did mine myself and it turned out pretty good, you can't tell if you are 10 feet away.
(LOL). I bought the tint from ebay, 5% (Limo tint) for the back 3 and 20% for the rest. I have a weekender and was against taking the rear cabinet out so I made a tool using an old credit card gorilla taped onto a long ice scraper to get the bubbles out. It actually worked pretty well. It's not waht the pros would do, but I am happy with it. The rear window was a b*tch! I used 2 pieces and put the sems horizontally on top of one of the Rear Defroster lines.
Here's how I did it:
Clean all windows inside and out with dish soap & water. Figure out which side is the tint and which side is the clear backing. Spray the outside of the window with your soapy water to make it stick to the window. Lay your tint on the outside of the window to be tinted remember that the tint goes on the INSIDE of the window so the
Clear Backing should be closest to you. Cut the tint to be close to the right size (I did the final trimming from the inside). Spray the inside of the window, peel off the clear backing while spraying with soapy water. Put tint on inside of window, for out the bubbles fro mthe center out (up & down and side to side only), trim to perfect fit.
Remember to use plenty of soapy water! And a nice sharp exacto knife! The haze will disappear after a day of so, DO NOT open the windows for 24+ hours. Have many cold German Beers while waiting for them to dry....
It does make a big difference in temperature with the tint on. It's also much, much more private at the drive in and for tailgaiting at concerts, etc... |
windnsea Samba Member
Joined: May 07, 2008 Posts: 424 Location: Pasadena, CA
Posted: Tue May 31, 2011 9:41 am Post subject: |
I need to redo mine, and I'm driving over to Phoenix to have it done - they do so many cars in Arizona that the prices are super competitive, even for the best guys!
Going to have the windows pulled out and the new gaskets put in place at the same time. |
vanjoe Samba Member
Posted: Tue May 31, 2011 10:25 am Post subject: |
Unibagel thats a lot of good info. If the people search you tube and other sites it will confirm what you are explaining. Some of them tell you to use "special spray" but the dish soap and water works great and will save people $10 on something they don't need. _________________ 1990 VW Vanagon tin top weekender Carat
1998 Mercedes S420
r39o Samba Polizei
Posted: Tue May 31, 2011 10:42 am Post subject: |
My tint job with some extra primo deluxe film with a multiyear (10 year?) warrenty was like $200 for the 5 rear windows. I forget the details and have the receipt in the van. I got a great job as I had the windows out of the van for paint. 5 years later they still look and work great.
I think you get what you pay for in this case.
This is a job for the pros, me thinks. Plus it is a MAJOR PITA to do in the van! _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
