69autobug Samba Member
Joined: August 11, 2008 Posts: 60 Location: San Diego
Posted: Tue May 31, 2011 12:26 pm Post subject: oil filter |
OK maybe a dumb question, but when changing an oil filter, do the holes on the filter have to be exactly like the filter being replaced? I have on that is supposed to work but the one coming off has just four and the new one has more. |
69 Jim Samba Member
Joined: September 27, 2004 Posts: 6264 Location: Chickengeorge's Neighbor
Posted: Tue May 31, 2011 12:29 pm Post subject: |
Probably not. What brands are they? |
Randy in Maine Samba Member
Posted: Tue May 31, 2011 12:38 pm Post subject: |
No Bosch oil lifters please.
Stay with the Mahle/Mann or WIX /NAPA Gold. Far better quality. |
Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Tue May 31, 2011 12:53 pm Post subject: |
I use Volkswagen oil filters. The adapter on my air cooled engine uses the same filter as a New Beetle gas engine. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
69 Jim Samba Member
Posted: Tue May 31, 2011 12:56 pm Post subject: |
I've had great performance from the Bosch 72150. |
Max T. Samba Member
Joined: September 18, 2009 Posts: 186 Location: So Cal
Posted: Tue May 31, 2011 1:04 pm Post subject: |
Randy in Maine wrote: |
^^^ x2. These filters are far better quality. Don't ask me how I know, do the search first. |
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Tue May 31, 2011 6:31 pm Post subject: |
the Fram HP1(not the ph8 or what ever its called)and the K&N are also good. _________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods! |
dreadpiraterobert Samba Member
Joined: January 17, 2010 Posts: 269 Location: Richmond, VA
Posted: Tue May 31, 2011 7:29 pm Post subject: |
Filters don't always look the same. For my Fox, Mann are the heaviest I've had, and the openings look different from Purolator, etc. The main thing is having it fit properly.
This is probably a question for your parts provider. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Tue May 31, 2011 8:06 pm Post subject: |
Four points to consider when selecting spin-on oil filter for fit...
Size of center threaded hole. This is the attachment point as well as part of the inlet/outlet system.
The diameter of the O-ring. This is the outer seal and needs to mate with the flat sealing surface. Get this wrong and it will leak.
Whether there is an internal by-pass valve to prevent over pressure when filter is dirty (not for high oil pressures from the pump).
Physical size of the filter housing. Big is good as it usually means more filter surface area so it can last longer. Too big, and it won't fit into the space available for the filter.
Most filter adapters seem to use a Ford style PH-8A mounting. Common size for racing filters. Fram HP-1 is high performance version of PH-8A and supposed to handle more pressure.
Since most "full flow" oil filter systems send the full pressure of the pump to the filter, you want a better than stock filter. Cold oil pressures can exceed 100psi !
Those drain holes don't really matter. Just the center hole and it's threading are key to mounting your filter mounting correctly. _________________ AshMan40
Drag0nHart Samba Member
Posted: Thu Jun 02, 2011 3:29 pm Post subject: |
Found this while "trolling the net", thought it would demonstrate the differences in filters even when they FIT the same mounting:
http://www.aircooledtech.com/oil_filter/
NOTE: The Fram HP1 and the Empi HP1 oil filters may NOT be the same thing. In any case, my favorite is the K&N or Wix. _________________ AshMan40
