0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Thu Jun 02, 2011 12:09 pm Post subject: shift linkage |
hi all,
I replace the shift linkage with the Shift Linkage Repair Kit from Van Cafe (at gear box). And now there is a whining noise when in gear that wasn't there before.
(89' Syncro WBX)
What I did wrong? Please help..
thanks in advance, |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Thu Jun 02, 2011 1:15 pm Post subject: |
Can you make the noise go away by moving the shifter knob around a little while under way?
(left to right or vice versa)
May just need adjusting at the base plate under the boot. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Posted: Thu Jun 02, 2011 1:28 pm Post subject: |
yes..
the pitch and the volume of the sound change when I move the shift lever around..
I will try that tonight
thanks Jim |
zippyslug31 Samba Member
Joined: July 20, 2007 Posts: 799 Location: Central Oregon
Posted: Thu Jun 02, 2011 3:32 pm Post subject: |
Might be left field, but "at the gear box" to me means that you had to mess with that protective tube for the linkage. I know if I don't have mine lined up just right that the linkage can get bound up... which might be adding some pressure on the selected and thus a strange sound. _________________ previous:
'80 westy
current:
'90 syncro westy 2.5L subi, triple knob, 16" wheels.
'84 sunroof van, 2.1L motor. |
chimivee Samba Member
Joined: September 23, 2009 Posts: 741 Location: Orange, CA
Posted: Mon Apr 30, 2012 6:33 pm Post subject: |
0to60, did you ever solve this problem? I am experiencing the same thing after overhauling my shifter components.
Yesterday I replaced the shift ball/arm at the trans, the rear rod support bushing, front fork ends, all parts at the base of the shift lever, and lots of grease. Afterwards, shifting was slightly off, and I adjusted the linkage a fraction (at the front/rear rod junction) to get it back to good. I did not adjust the shift lever base plate, although re-installing it might have moved it a hair from it's previous position.
The noise I hear is a very low whine that I'd describe more as a "whrrr." It is present in every gear, but loudest (or at least most noticeable) in 1st and 2nd. Pressing gently side-to-side on the shift lever will make the noise increase/decrease but not disappear.
Advice. Thanks. _________________ -James
86 Syncro Westy, etc |
Posted: Mon Apr 30, 2012 7:02 pm Post subject: |
hi James,
PM sent |
VanOnTheRun Samba Member
Posted: Tue Jul 28, 2015 1:56 pm Post subject: |
0to60in6min,
Really wish you would have posted rather than PM'd! I'm having this same problem and don't feel another thread is necessary. Did either of y'all figure out what needed to be adjusted?
Cheers,
Mikey _________________ 1987 Syncro Westfalia EJ22
2008 Ural Patrol 2WD |
