KillerTux Samba Member
Joined: June 21, 2005 Posts: 434 Location: Odenton, MD
Posted: Mon Jun 06, 2011 9:35 am Post subject: Crankshaft Pulley |
A noise started about two days ago that sounds like loose valve. I did a search here and found it could be the crankshaft pulley. When the engine runs, the crankshaft pulley is rotating but it isn't even. I took the v-belt off thinking maybe the belt is too tight, the pully still looks it it is warped while rotating. What could be the issue? It is a 1200cc 40hp _________________ 1964 Beetle Convertible |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Mon Jun 06, 2011 9:43 am Post subject: |
Could be loose or bent. I'd block it, put it in gear, then torque it down. If that doens't fix it (which is probable), shop for an unbent original. Stay away from aftermarket "power pulleys" but a well-built, original size, new pulley with timing marks will also work well. |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Mon Jun 06, 2011 3:38 pm Post subject: |
Hold on there. A crank pully does not wobble on it's own unless it's a after mkt alum piece.
I'm leaning towards a broken crank since it's a 1200 40hp engine that are known in the past to break when being lugged down.
Anyone with me on that? |
DDub Samba Member
Joined: January 06, 2005 Posts: 307 Location: central pa.
Posted: Mon Jun 06, 2011 4:08 pm Post subject: |
HRVW wrote: |
Yup, I'm with ya. I drove a '65 with a broken crank. Take the belt off, put trans in first gear, and try to move the pulley back and forth. If it's very loose the crank is broken. |
