camelcrash Samba Member
Joined: February 11, 2011 Posts: 55 Location: Nor Cal
Posted: Tue Jun 07, 2011 11:26 pm Post subject: Unknown 3X3 Trailing Arms Please Help |
I got a set of 3X3 trailing arms with the purchase of my frame. Someone cut out the ends and welded in an unknown housing. Here are some pics. If anyone could help me find out what thay are out of that would be great.
The small hole in the middle is left over from the original housing plate.
_________________ Project in process. All I need is more CASH.
Chenowth Explorer 4 Seater, 1835, 091 Trans
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Wed Jun 08, 2011 5:33 pm Post subject: |
Those might be for "micro stub" stub axles, I think they start off as Chevy S-10 parts but I dont know alot about them. Some body should chime in soon.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
DWP Samba Member
Turborail Samba Member
Joined: June 12, 2005 Posts: 5 Location: West Valley City Utah USA
Posted: Fri Jun 10, 2011 5:48 am Post subject: |
I wouldn't spend too much time trying to figure out what someone else created. Focus on replaceing the unknown with the proper flange. www.tabzone.com look in their catalog and get the correct flange for your bearing housing. _________________ Sandrail, Aftermarket VW based 2276cc , Turbo, Homebrew EFI, Type 1 Trans Aftermarket components |
Jman125 Samba Member
Joined: February 20, 2011 Posts: 1 Location: vista,California
Posted: Fri Jun 10, 2011 11:32 am Post subject: |
hey does anyone know what the difference between 3x3 and 3x1 trailings arms. would the 3x1 trailing arms still give me more travek the stock bug trailing arms and give me more length ? |
Posted: Fri Jun 10, 2011 4:10 pm Post subject: |
Turborail wrote: |
I wouldn't spend too much time trying to figure out what someone else created. Focus on replaceing the unknown with the proper flange. www.tabzone.com look in their catalog and get the correct flange for your bearing housing. |
Thanks for the info.
I'm not in a hurry and have limited cash so i'm trying to use what I have.
If all else fails I'll pick up the flanges from the company you suggested.
Thanks _________________ Project in process. All I need is more CASH.
Chenowth Explorer 4 Seater, 1835, 091 Trans |
77charger Samba Member
Posted: Fri Jun 10, 2011 4:18 pm Post subject: |
those are set up for micro stub.If you got to buy all new parts for the rear then go with these.If you already have all the rear parts then buy some other arms set up for VW.
You can get more travel out of the micro stub too which is an advantage. _________________ Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine |
Posted: Sun Jun 12, 2011 10:24 pm Post subject: |
77charger wrote: |
You can get more travel out of the micro stub too which is an advantage. |
What micro stub housing would bolt to these arms?
No parts yet. Need to figure out what kind of bearing housing bolts to them and what kind of stub axles I need then I can start to put the rear end together. _________________ Project in process. All I need is more CASH.
Posted: Tue Jun 21, 2011 1:21 pm Post subject: |
Finally! I got ahold of a guy who called a guy and talked to the PO!
The only info I could get is that the flange is off the front of a 4x4 nissan. Wooo Hooo! Now I need to figure out how to use it. _________________ Project in process. All I need is more CASH.
