highlandmurf Samba Member
Joined: April 08, 2010 Posts: 296 Location: Hudson Valley, NY
Posted: Sun Jun 12, 2011 6:34 pm Post subject: How to make an engine dolly |
So, I get a lot of really good info off of this site, and decided that as a way of saying thanks, I could put up a tutorial that revolves more around my area of expertise.
I found the plans for this engine dolly on the Type2 site here:
http://www.type2.com/library/engineg/vw-engine-dolly-hartranft.pdf
It is designed to allow the jack to get under the engine easily.
So, here we go, First the parts list:
Qty Size
1- 2 x 12 x 18"
1- 2 x 4 x 13” *
2- 2 x 6 x 16 ½”
1- 2 x 6 x 18” *
2- 2 x 4 x 18”
12- Lag bolts ¼” x 3”
12- ¼” washers
16- lag bolts ¼” X 1”
4 - 2” Casters
All in all, it was about $40 in supplies.
I got everything including the casters from Home Depot
First off, I bought a 2x 12 x 12' because, you can cut down all of the other narrower parts from it. More cutting, but if you have a tablesaw, it saves some $$.
Saftey First!! I guess, I should say, that you shouldn't use any power tools without proper instruction. It's up to you to make sure that you work safely, and I am not advocating any method of work in the following photo series. IT is for general info only.
That said, The first thing you want to do with your lumber is to check it for staples on all 6 sides ( 2 edges, 2 ends, 2 faces) The ones that were on the outsides of the bundle can be riddled with them.
Take 'em out!! Not only can they give you a pretty good cut, if they get hung up on your saw, you may find yourself in a pretty dangerous position. You can use a hammer and an awl and or some lathing pliers to remove them.
Next, I marked and measured for th crosscuts. I chose to crosscut first, because, I needed to get the one 2 x 12 piece, and I figured it would be easier to rip the remaining pieces if they were shorter.
Please note- the 2 parts in the cutlist marked with an asterisk *. The dolly is designed to allow 11" of space between the sides. if your jack requires more space you may have to make these parts longer.
Check your saw depth for the cut before plugging it in!
Parts roughed out:
The plans call for a 1/4" groove (called a dado in the woodworking world) to be made down 2 of the boards. This adds a little strength, I don't know if it is entirely nessesary, but It is on the plans, so here we go.
I did them on a tablesaw by making a series of cuts. (my routers and dado heads were in storage.)
Find the center of the board, and measure out 1 1/2" off of center to mark your 1st cut. Lay a piece of material against it to check that your measurements are correct.
Next set the saw for the 1/4" depth:
Set the saw fence to the marks on the boards. Make sure that your sawblade it to the inside of the line. Spin the board around to make the cut on the other side. It's a good Idea to check the width again before commiting to the 2nd cut.
Then, move the fence one sawblade width to the right. You can get 2 cuts per position by spinning the board around. Make sure you cut both pieces before moving the fence.
This will take several cuts. this is where your Aircooled VW patience kicks in!
If those pieces look a little wider than yours, It's because they are 2 x 6's. I forgot, and took 'em down to 2 x 4 after grooving them.
Here they are finished:
THe design requires that the ends of these pieces are notched on the ends to recieve the cross piece. This is illustrated in the height difference in the next photo.
I suppose you could just rip the cross piece down, but we are following the plans here so....
The height on the saw is already set for the sholder of the notch.
Layout the pieces like they will be assembled, and mark the sholuder (side) of the notch.
Next, set your fence for the depth of the notch. Make sure the blade is on the correct side of the cut.
Get out your saw's mitre square. It is dangerous to attemt this cut with out one. Check it for 90° and tighten it down.
No need to move the fence. just pull the wood away from the fence by the width of a sawblade and continue cutting and moving, cutting and moving untill the entire end of the piece is notched out.
Next fit the pieces together and check how they fit.
Assembly is done by means of bolting the parts together with the 3" lag bolts. use a 3/16" bit to drill a pilot hole for the bolts. you may have to go back and drill out the portion of the hole closest to the head, if the bolt has a straight shank (not threaded portion)on it.
Lastly, bolt the casters on to the bottom.
And we're done!
Note that I did not make the circular cut out on the top board for the oil sump clearance. This is not needed on the type IV engine. If you need this space, I think it would be easier to add some strips of plywood to the top.
Now back to the auto repair part of the job! _________________ 1976 Westy Marigold Yellow
2.0 stock FI
My M-Plate
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Sun Jun 12, 2011 6:54 pm Post subject: |
great write up!!... I'm a carpenter and disagree with your picture of your blade being 1/4"...
just messin witcha.... _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
Posted: Sun Jun 12, 2011 8:27 pm Post subject: |
Ahhh, ya got me.
That pic was pre saw adjustment.
I guess I'll get back to thinking about my fist engine pull.
If it decides to stop raining sometime this week....... _________________ 1976 Westy Marigold Yellow
2.0 stock FI
My M-Plate |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Sun Jun 12, 2011 9:44 pm Post subject: |
Looks good. Thanks for posting the layout and build process. One point I would like to make, and I, too, am a carpenter by trade, is that there is likely no need for the dadoes on the bottom rails. A butt joint, some quality glue, and a few screws would suffice for that purpose.
I may have to build one soon. It appears that it would be quite handy. _________________ nothing |
19super73 Hardcore Stock Nazi
Joined: October 18, 2007 Posts: 4351 Location: Cité Soleil
Posted: Mon Jun 13, 2011 3:09 pm Post subject: |
If I knew where to get a 1000lb dolly for 20 bucks there might be some memory left on my camera right now!! _________________ 1976 Westy Marigold Yellow
2.0 stock FI
My M-Plate |
Randall Samba Member
Joined: October 03, 2004 Posts: 1403 Location: Orange County, Alta California, El Norte
Posted: Mon Jun 13, 2011 7:37 pm Post subject: Hello Dolly! |
Here are pics of the dolly that I made from plans found in an August 1996 Hot VWs article.
https://www.thesamba.com/vw/gallery/pix/817257.jpg
https://www.thesamba.com/vw/gallery/pix/817258.jpg
As you can see, mine uses steel channel and aluminum angle brackets. If the wood gets broken or termites weaken it, it's not much of a task to unscrew the bolts and put in new 2X4's.
On a related topic, there is an article in the April 2000 Hot VWs about how to build an engine lift assist that allows one person to lift an engine from floor level up to a rolling engine stand using only a hydraulic jack. It's kind of hard to describe without photos and drawings (and I have never built one). Briefly, two boxes are used in a "stepping stone" fashion. The engine is placed on the jack, then it is lifted atop the first box. Next, the first box is lifted on top of the second box. With the second box resting on the floor the engine is at the right height so that the engine stand can be pushed into place to accept the yoke attached to the engine. This plan is of use if you don't have a friend around to lend a helping hand or if your woman isn't up to the task of lifting half the weight of an engine.
You can see the cover of that Hot VWs issue at this link. http://www.hotvws.com/images/Back%20Issues/2000%20...0Cover.htm
At the bottom of that page click on "Contents Page" to see the article titles. Page 70 is the one I'm talking about.
Here's where you order back issues.
https://www.nsfsmagazine.com/secure/hotvwstore/backissues.html
Here's a link to a site with useful information on the same topic.
http://www.ratwell.com/technical/EngineSupport.html#dolly |
Posted: Mon Jun 13, 2011 10:27 pm Post subject: |
highlandmurf wrote: |
If I knew where to get a 1000lb dolly for 20 bucks there might be some memory left on my camera right now!! |
Harbor Freight has them on sale with some regularity. _________________ nothing |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Tue Jun 14, 2011 12:20 pm Post subject: |
I saw on your plans that you take a piece of 1/2" inch plywood the size of your top 2X12 and cut a hole in it to clear the oil sump plate. This will help spread the load across the bottom of the engine. You could go one step further and also install a piece of 1/2" plywood on the bottom with a hole cut out the size of your floor jack cradle. This will keep the engine from sliding off the floor jack when raised up in the air. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
VWKDF Samba Member
Posted: Tue Jun 14, 2011 1:26 pm Post subject: |
vwracerdave wrote: |
I saw on your plans that you take a piece of 1/2" inch plywood the size of your top 2X12 and cut a hole in it to clear the oil sump plate. This will help spread the load across the bottom of the engine. You could go one step further and also install a piece of 1/2" plywood on the bottom with a hole cut out the size of your floor jack cradle. This will keep the engine from sliding off the floor jack when raised up in the air. |
Good Idea,
I don't need the dolly but I do think I will make a board like you described to make it safer for me to lower engines. |
Collie Samba Member
Joined: April 03, 2006 Posts: 1285 Location: Virginia
Posted: Wed Jun 15, 2011 3:39 am Post subject: |
Just to add to the topic, here is a dolly I had made about a decade ago. It does pretty much the same job but its metal.
anthracitedub Samba Member
Posted: Wed Jun 15, 2011 4:59 am Post subject: |
Yep, I made a steel one too, about the size of a shoe box…no wheels, my small floor jack slides right in the middle…you drop the engine on it and wheel it out with the jack, then pull the jack out…engine sits firmly on the steel box. |
Posted: Thu Jul 07, 2011 2:20 pm Post subject: |
Success!
Just got my bus back together after using the dolly to pull the engine and trans.
Just a heads up, you have get the vehicle up fairly high to account for the height of the dolly. It was on the last notch of my 3 ton jackstands.
I pulled the engine and trans together. At the last minute I decided to turn the 2 X 12, 90° to catch the transmission as well. This balanced nicely, except it left me scrambling for another piece of 2X to bridge the span between the dolly frame.
All in all, I think it made a considerable convinience. _________________ 1976 Westy Marigold Yellow
2.0 stock FI
My M-Plate |
ilustr8tor Samba Member
Joined: November 07, 2010 Posts: 426 Location: Maryland
Posted: Tue Dec 12, 2017 4:42 pm Post subject: Re: How to make an engine dolly |
here is one you can make for 12.00:
https://www.youtube.com/watch?v=qzuLrZqzfWI _________________ I love this analog addition to my over digitzed life. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Tue Dec 12, 2017 5:41 pm Post subject: Re: How to make an engine dolly |
Or buy, $40 https://www.ebay.com/i/132010139021?chn=ps
I just lowered my engine using the floor jack and used an inexpensive mover's dolly from HF to move the engine around and take off heat exchangers, etc., then lifted it for my bench-mounted engine stand.
But I may try to make that HF dolly into such engine dolly https://www.youtube.com/watch?v=qzuLrZqzfWI see below
I mean, these specialized things are cute and look useful, but it's not like I currently R&R VW engines every year or three....and everything one buys or makes, he has to store !!!
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
mark tucker Samba Member
Posted: Tue Dec 12, 2017 7:05 pm Post subject: Re: How to make an engine dolly |
I have a hole in mine for the sump plate. also good idea to add some straps to hold it firm. I made a plywood unit to go on my ATV lift..well i made 2 of them for the ATV lift, both have holes for the sump plate to go through. one is for engine removal&instlation. the other one is for engine and trans removal&installation. works great.. you can also go the the swap meats ( non vw) and buy new engine dollys for $15& up and do a little extra for use with vw engines. just remember whatever you make it needs to be solid and hold the engine good by the bottom of the sump or bottom of the case with no rocking.or it may end up on the floor in a mess.also those pushrod tubes are kinda delicate. you also dont want to hold it up by the heads. by hand that may be ok, but not by a fixture that is "hard" that may damage the head seal, cylinders, pushrod tube seals or whatever.hands are soft&giving wood and or steel isant. just slap your self with you hand then again with a 2x4 and see witch knocks out the most teeth |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue Dec 12, 2017 7:11 pm Post subject: Re: How to make an engine dolly |
Or a moving dolly and some boards.
_________________ Glenn
Member #1009
#BlueSquare |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Tue Dec 12, 2017 8:55 pm Post subject: Re: How to make an engine dolly |
I use a harbor freight wooden roller. They are about $7.
I have to dance with the engine on a jack for a little while. Just don't let it slide off and especially if you have removed the sleds. _________________ www.vwnos.com [email protected]
Posted: Thu Dec 14, 2017 10:58 am Post subject: Re: How to make an engine dolly |
kawfee wrote: |
I have to dance with the engine on a jack for a little while. Just don't let it slide off and especially if you have removed the sleds. |
I have 3 of those!!!but I dont use them for install or removal, just storage and or moving around. I also bought one and wacked it up to make a real nice rolling base for my band saw. cheeper than just the wheels and you get wood too |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Mon Dec 25, 2017 3:39 pm Post subject: Re: How to make an engine dolly |
It is designed to allow the jack to get under the engine easily. |
I like it! Every other contraption the other posters showed I also have, and they all suck because I have to lift or dick around with the engines weight.
Nice Job! _________________ Good Luck
Al |
