menchi Samba Member
Joined: February 17, 2011 Posts: 13 Location: San Diego
Posted: Mon Jun 13, 2011 10:46 am Post subject: Installing a clock in 1966 Deluxe |
Hi All, I just got a replacement clock for my 66 deluxe. The clock was taken out when I bought it so I had to hunt a replacement to fill that hole in the dash. Problem is, I bought just the clock and not the housing to hold the clock in the dash. Does anybody have any idea if there is a part that I can buy that will seat the clock in the dash hole securely? I have tried to zip tie it from the back to hold it in place and that doesn't work. Thanks |
quartermilecamel Samba Member
Posted: Mon Jun 13, 2011 12:15 pm Post subject: |
If you have the full clock and securing nuts then all you need is the 2 L shaped pieces of metal that fit over the studs on both sides. The nut tightens down on the L brackets that clamp the clock in place by pressing on the back side of the dash. You could make some if you dont need OG ones. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
menchi Samba Member
Posted: Mon Jun 13, 2011 1:07 pm Post subject: |
Thanks Guys. Helps a lot to know how it was held in! |
OG Velvet Samba Family Man
Joined: February 24, 2003 Posts: 2168 Location: Portland, OR
Posted: Sun Feb 17, 2019 6:41 pm Post subject: Re: Installing a clock in 1966 Deluxe |
Hi there, reviving a dead thread.
Any source for clock brackets these days?
Thanks _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Feb 17, 2019 7:48 pm Post subject: Re: Installing a clock in 1966 Deluxe |
I bought a clock at an antique store a few weeks ago and it was mounted in a custom wood box. I believe the brackets they used were altered headlight aiming "hooks"- bent and drilled to pull the clock into the box. Crude, but its' a start while you look in every swap box at every bus show... _________________
EverettB wrote: |
FU#5 |
Posted: Sun Feb 17, 2019 8:20 pm Post subject: Re: Installing a clock in 1966 Deluxe |
I have some of those. I’ll see what I can come up with.
No repops? I’ve looked at the usual sources with no luck. ISP sells a repro clock, I may call and see if they sell just the brackets _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Mon Feb 18, 2019 11:46 am Post subject: Re: Installing a clock in 1966 Deluxe |
Will these help you?
You can have them if you PM me your address. |
Posted: Wed Feb 20, 2019 2:39 pm Post subject: Re: Installing a clock in 1966 Deluxe |
BarryL wrote: |
PM sent. Thanks!! _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
BarryL Samba Member
Posted: Wed Feb 20, 2019 5:01 pm Post subject: Re: Installing a clock in 1966 Deluxe |
OK, I hope they work. They are 6 volt. |
