Vert seat bolts help
Karzapart55
Karzapart55 is offline
PostPosted: Mon Jun 13, 2011 3:04 pm    Post subject: Vert seat bolts help Reply with quote
I bought my vert dissasembled,having fun trying to put her back together. Anyone have a pic of the bolts that hinge the rear seat back? I bought a set of bolts here on the Samba, but the thread is too small. Arethey different than a hard top Bug?
julrich366
julrich366 is offline
PostPosted: Mon Jun 13, 2011 4:49 pm    Post subject: Reply with quote
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111885591
Mine were pretty chewed up when I went to reupholster rear seat...these fit.
- John
'74 Vert ..lot's to still do.
kburg12
kburg12 is offline
I bet you are putting them in the seat belt holes (like I did at first). there are 2 holes around the back seat, 1 for seat and 1 for seat belts. Hope this helps
A terrible mind is a beautiful thing to waste!!!
68 Convertible Beetle
09 Tiguan
09 Beetle
Karzapart55
PostPosted: Tue Jun 14, 2011 2:42 am    Post subject: Reply with quote
I see only one hole on either side that lines up with the tabs of the rear seat, top section. they line up with the cut-out corner of the rear panels. According to the Wolfberg ad, all verts are the same!
kburg12
kburg12 is offline
PostPosted: Tue Jun 14, 2011 12:10 pm    Post subject: Reply with quote
There are 2 sets I promise you. They are different sizes and 1 is for seat belts the other is for seat and if you are trying to put them in the seat belt section the seat will also not reach all the way across. try looking up just a bit from where I think you might be and see if there is another hole. I will try and get a pic of the back seat in my vert tonight if I can and show you what I mean.
09 Tiguan
09 Beetle
julrich366
PostPosted: Tue Jun 14, 2011 12:48 pm    Post subject: Reply with quote
On my vert ('74), there's only one hole/side. The seatbelts go on that same shoulder bolt, with a plastic/nylon washer on either side of the seatbelt assembly...but they are on the shoulder bolt that pivots the rear seat back.
- John
Karzapart55
PostPosted: Tue Jun 14, 2011 2:46 pm    Post subject: Reply with quote
Thanks John, I guess im not going crazy. My vert is a 75, and the pivit point is the same thread as the seat belt bolt. Ive searched for hours, cant get a pic or the right answer
julrich366
PostPosted: Tue Jun 14, 2011 3:47 pm    Post subject: Reply with quote
I'd gladly send you a pic but:
1. I'm at work and the car isn't
and
2. The back seat isn't in right now... sitting on sawhorses ready to
be reupholstered.
(That's how I knew about "1 hole"...just took the rear seat out last week).
- John
