crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Sun Jun 21, 2020 8:38 am Post subject: Re: Radiator Fan Won't Shut Off |
If your van came with factory A/C then the fan high speed relay is mounted separately to the body of the van above and to the left of the fuse/relay panel.
It is hard to see it.
Mark |
damagd Samba Member
Joined: March 11, 2015 Posts: 246 Location: Lancaster, PA
Posted: Sun Jun 21, 2020 8:56 am Post subject: Re: Radiator Fan Won't Shut Off |
Yeah, I think I found it. I can access it through the dash vent, but I have been pulling and wiggling it and can not get it to come out. I'll give it another try. |
Posted: Sun Jun 21, 2020 9:03 am Post subject: Re: Radiator Fan Won't Shut Off |
You can borrow the "18 relay" from the main relay panel as a test replacement for that fan relay.
The power feed to that relay socket is live all the time, so careful!
Disconnect the battery ground cable when working in that area.
Mark |
damagd Samba Member
Posted: Sun Jun 21, 2020 9:38 am Post subject: Re: Radiator Fan Won't Shut Off |
Well, I did get the fan to shut off by taking off the driver side headlight and unplugging the green tube thing back there, the name escapes me. The alternator problem is solved. When I looked at it I discovered a wire had broken. Reconnected that and it's charging fine now. Certainly I cannot use the 18 relay and drive with it in place of the fan relay, right? Even if I can get the fan relay off, which I am still struggling with. What about pulling the switch at the bottom of the radiator behind the lower grill and cleaning it? Someone suggested to me that it sounded like a stuck switch. |
damagd Samba Member
Posted: Sun Jun 21, 2020 9:49 am Post subject: Re: Radiator Fan Won't Shut Off |
The resistor? I think that's what the green thing is called. Anyway I just plugged it back in and the fan is not running. But, once the fan kicks on again is it going to stay on again? |
Posted: Sun Jun 21, 2020 12:14 pm Post subject: Re: Radiator Fan Won't Shut Off |
You said that unplugging the temp switch low on the radiator didn't turn off the fan.
That means the temp switch isn't the problem.
Mark |
pdm777 Samba Member
Joined: August 06, 2012 Posts: 348 Location: Clovis, CA
Posted: Wed Jun 24, 2020 11:24 pm Post subject: Re: Radiator Fan Won't Shut Off |
wild stab --- if the AC pressure is too high,
the fan will remain 'on' after shutdown. For very long time.
Trinary AC presure switch might be sending bad signal. _________________ 1990 Westy Full Camper |
pbooth59 Samba Member
Joined: September 08, 2014 Posts: 2 Location: Philadelphia
Posted: Thu Dec 31, 2020 1:25 pm Post subject: Re: Radiator Fan Won't Shut Off |
Hi all, new owner here. I'm having the same issue with the fan not turning off. Pulling the fan switch turns it off, as does pulling the #1 fuse. What does this mean? - Thanks! |
pdm777 Samba Member
Posted: Thu Dec 31, 2020 1:34 pm Post subject: Re: Radiator Fan Won't Shut Off |
if your AC pressure is too high,
For very long time.
Enough to kill your battery.
Put a set of AC gauges on it and see.
I recall unplugging the AC pressure switch
behind the rear cabinets would turn off the fan.
Lowering the AC pressure got it fixed,
On hot days, climbing hills, the high speed fan
should stay on for no more than 5 minutes after shut down.
Using a refrigerant like EnviroSafe (hydrocarbon AC alternative)
will lower pressures and cool much better than 134. _________________ 1990 Westy Full Camper |
fxr Samba Member
Joined: December 07, 2014 Posts: 2321 Location: Bay area CA
Posted: Thu Dec 31, 2020 1:36 pm Post subject: Re: Radiator Fan Won't Shut Off |
pbooth59 wrote: |
Fan switch faulty - same happened to me. Cheap, easy quick swap-out. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Thu Dec 31, 2020 1:38 pm Post subject: Re: Radiator Fan Won't Shut Off |
Awesome thanks, it does have factory A/C but I haven't used it yet and the problem wasn't there when I first bought the Van. I'll look into that fix and the switch and report back.
*Update* Got the new switch in, and it seems to be working! Thanks! |
chrowe Samba Member
Posted: Mon Sep 06, 2021 11:51 am Post subject: |
My fan came on high and would not shut off unless I disconnect the battery.
Based on this thread I pulled out what I think is the high speed/3rd stage relay (see attached photos). Is there any way to test it to see if it has actually failed?
I have an 89 Syncro with no AC so I guess it is normal to have no relay in position 5. Is there a low speed/2nd sage relay somewhere else in my van?
It looks like those links to autohausaz no longer work. The current one is 70 Amps. I assume that is what is needed.
Maybe this one https://www.hansautoparts.com/357906381BRelay.aspx but it looks different.
or https://parts.vw.com/p/Volkswagen_1989_Vanagon/Relay/48302346/4H0951253A.html
or https://www.busdepot.com/8d0951253my (but it doesn't say the amps)
or https://www.busdepot.com/8d0951253 (but it has that extra metal tab)
crazyvwvanman wrote: |
All 89 vans should have the relay in position 5 unless they are Syncros without A/C. That relay you linked to is not the right one for position 5, as far as I know.
In any case the missing position 5 relay isn't causing this problem. The high speed relay is up inside the dash area at the left end. It is hard to see without removing something. Look at Bentley page 87.5 and the drawing on the upper right shows the relay behind the left dash vent. That is the highest speed rad fan relay, 3rd stage.
chrowe Samba Member
Posted: Fri Sep 10, 2021 7:16 am Post subject: Re: Radiator Fan Won't Shut Off |
I tested the relay and it seems to make a connection when power is supplied to it. Does anyone know what activates the relays? It seem like in my case that might be the broken part? |
Posted: Fri Sep 10, 2021 8:24 am Post subject: Re: Radiator Fan Won't Shut Off |
MarkWard wrote: |
First step would be to unplug the radiator fan temp switch and see if the fan shuts off. You need to remove the "LOWER" grill. If you haven’t done this, you need to learn. Report back. |
chrowe Samba Member
Posted: Mon Sep 13, 2021 11:20 am Post subject: Re: Radiator Fan Won't Shut Off |
Ya, I already tried that and it makes no difference.
I talked to a mechanic who thinks it is the resistor but I can't seem to find one online.
MarkWard wrote: |
Posted: Mon Sep 13, 2021 12:53 pm Post subject: Re: Radiator Fan Won't Shut Off |
The resistor can't really make the fan run all the time.
When the resistor fails it keeps the fan from running on the lower speed(s).
If the lower speed doesn't work that can make high speed run a lot so that is something that can result from a bad resistor.
Mark |
