BD Steering Column Floor Plate - Only early 51 part?
Capriacci
Capriacci is offline
PostPosted: Thu Jun 16, 2011 6:21 pm    Post subject: BD Steering Column Floor Plate - Only early 51 part? Reply with quote
Have you seen this kind of BD Steering Column Floor Plate? Pics taken of a 1951 Barndoor, model 24A, which is being restored. It seems to be original factory.
Can you help with some information?
EA57RHD
EA57RHD is offline
PostPosted: Fri Jun 17, 2011 8:53 am    Post subject: Reply with quote
My guess would be that its not original. I have never seen that part on any BD that I have owned. I also looked at pictures that I have of other 51 BD's and that part is not there. It does seem to have the same patina though, Kind of strange.
What purpose would it serve? And keep in mind that it would also have had a modified floormat which I also have never seen before.
Have you removed it and looked for a part number?
----VW's in my garage----
March 1959 Mango Standard
November 1958 Single Cab
********WANTED********
Whittier Lee Wood VW dealer license plate frame
Capriacci
PostPosted: Fri Jun 17, 2011 3:30 pm    Post subject: Reply with quote
EA57RHD,
thanks for your considerations.
No part number...
However, i´m sure this is not a handmade part. This is a great mistery for me. Look more pics:
Jake Martinez
The VW Kid
Jake Martinez is offline
PostPosted: Fri Jun 17, 2011 4:02 pm    Post subject: Reply with quote
maybe off a prototype model then fitted to a later production model? anyone got pics of the prototype barndoor floor area
58 euro vert
63 bug ruby
64 sunroof notch
65 bug
67 standard
zombie wrote:
buslife wrote:
10 inch narrowed beam
Congrats, that's going to look like shit.
campingbox Premium Member
campingbox is offline
PostPosted: Sat Jun 18, 2011 9:11 am    Post subject: Reply with quote
Lets see pictures of the rest of this '51 24A bus. Some overall shots and shots of the VIN tag and chassis numbers would be cool.
sub-hatchtim
sub-hatchtim is offline
PostPosted: Sat Jun 18, 2011 2:44 pm    Post subject: Reply with quote
whats the floor look like where its mounted
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
Rick
Rick is offline
PostPosted: Sat Jun 18, 2011 4:56 pm    Post subject: Reply with quote
I think that looks factory. How big is the hole in the floor under it?
Capriacci
PostPosted: Sat Jun 18, 2011 8:52 pm    Post subject: Reply with quote
Good questions. Look the pics. The hole is not handmade too.
andre b
andre b is offline
PostPosted: Sat Jun 18, 2011 9:01 pm    Post subject: Reply with quote
Like campingbox said..let's see some more of the bus!!
Bergepanzer
Bergepanzer is offline
PostPosted: Sun Jun 19, 2011 2:55 am    Post subject: Reply with quote
Hi Capriacci,
your cover plate is original - but your steering column is not! Very Happy
VW mounted a certain ZF steering box type (don´t know the part number now) with separate steering column and flexible rubber joint in between for a short period. I have the remains of these parts lying in my shed; they came off a May 1951 microbus I uncovered in a forest in 1996.
But until today I didn´t know how the cover plate even looked like as everything was heavily rotted and I didn´t pick up all the scrap metal ... Thank you very much for the pictures!
My steering column tube still has the fragments of the spot welded "ball" cover around at the bottom. Does your part show any signs of cracked spot welds on the inside of the upper flange?
The whole action was stopped for unknown reasons, maybe it was too expensive - and the construction finally entered serial production with the baywindow type in August 1967!
The shown steering column is Barndoor but the usual type we all know. It must have been replaced at some point in the car´s life.
sub-hatchtim
PostPosted: Sun Jun 19, 2011 10:09 am    Post subject: Reply with quote
berge lets see some pics of this unusual linkage you have
76 911S
Capriacci
PostPosted: Sun Jun 19, 2011 2:54 pm    Post subject: Reply with quote
Hi, friends,
very interesting information.
I never see this "ZF steering box type...with separate steering column and flexible rubber joint" too. Bergepanzer, I´m curious...pics will be welcome Very Happy
About the question, I don´t find any signs of cracked spot welds on the inside of the upper flange.
I suspected that my steering box was not the original, because I have a original "Spare Parts List" from 1951, March, that show another kind of steering box:
Very grateful for all information shared!
Scotty
Scotty is offline
PostPosted: Mon Jun 20, 2011 12:56 am    Post subject: Reply with quote
Just so you know, the type of steering column bergpanzer is talking about is different from the type in the workshop manual pics you posted above. The one above is the standard set up until late 52 (not sure exactly when it changed to one piece).
Capriacci
PostPosted: Mon Jun 20, 2011 5:20 am    Post subject: Reply with quote
Yes, "separate steering column and flexible rubber joint ". Let´s wait for some pics...I´m very curious!
Rick
Rick is offline
PostPosted: Mon Jun 20, 2011 6:41 am    Post subject: Reply with quote
"flexible rubber joint" sounds scary! Would this be something similar to the a rear shift rod coupler? Early form of steering dampening? All really cool information nonetheless.
Scotty
Scotty is offline
PostPosted: Mon Jun 20, 2011 9:18 am    Post subject: Reply with quote
I imagine it'll be just like a beetle set up which isn't scary
Capriacci
PostPosted: Mon Jun 20, 2011 6:29 pm    Post subject: Reply with quote
Beetle set up? Like this? Question
Scotty
Scotty is offline
PostPosted: Tue Jun 21, 2011 12:58 am    Post subject: Reply with quote
That's what I'm guessing
Bergepanzer
PostPosted: Tue Jun 21, 2011 12:33 pm    Post subject: Reply with quote
Hi,
you were faster than me Smile
The shed is 300 kms away so pics will have to wait. But the photos you posted clearly show the setup. To 90 per cent I´m sure VW used this split bug steering linkage. For the remaining 10 per cent I have no explanation.
Supposingly VW mounted the parts A, B, C and D on some early BDs, maybe as an additional shock absorber for rough road conditions abroad.
For this the steering column had to be made a bit shorter inside the column tube.
@Capriazzi: I guess the hole in your cover plate is 40 mm in diameter? That´s the diameter of pre 53 steering column tubes. And the steering column tube later mounted in your 24A has a diameter of 32 mm?
Tonny_Larsen
Tonny_Larsen is offline
PostPosted: Tue Jun 21, 2011 1:07 pm    Post subject: Reply with quote
Bergepanzer wrote:
Hi,
It could explain why this steering wheel on this 51 is so close to the pod. I Was asked about this last time in Bad Camberg.
Chassis number 20-018817
-Tonny
