duderanchero Samba Member
Joined: October 25, 2008 Posts: 166 Location: el paso, tx
Posted: Fri Jun 17, 2011 7:49 pm Post subject: radiator bleed screw size? i've searched already! |
it's not m8 x 1.25! i have a behr radiator. it's definitely smaller than m8, because i've already tried.
van cafe sells the washer, but not the screw. wtf.
thanks,
james |
whip618 Samba Member
Joined: October 16, 2002 Posts: 761 Location: Albuquerque
Posted: Fri Jun 17, 2011 9:43 pm Post subject: |
I just checked my spare radiator which is the original to my syncro and it's an 8x1.25
Phil _________________ Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307 |
Posted: Fri Jun 17, 2011 10:07 pm Post subject: |
argh. yo no comprendo. |
240Gordy Samba Member
Joined: May 15, 2008 Posts: 2354 Location: Vancouver, BC
Posted: Fri Jun 17, 2011 10:26 pm Post subject: |
duderanchero wrote: |
Too bad yours isnt 8x1.25, i have 49 of those,
I would mail you one.
Except our post office is on strike:| _________________ Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR |
Posted: Fri Jun 17, 2011 11:10 pm Post subject: |
thanks for the offer, "m8"! (haha?) i am totally sure this isn't an m8 x 1.25. it's smaller than that. the only part number i can find on the rad that looks vw-like is 376 713 631. i got this one from van cafe. do i somehow have the wrong radiator?
Bercilak Samba Member
Posted: Sat Jun 18, 2011 1:19 am Post subject: |
Go to the hardware store.
Find a nut that screws onto your current radiator screw
Get a bolt that fits the nut, and is the same length as your radiator screw
Use a tool to incise the bleed cut in the radiator screw
Install screw
Repeat as necessary
B. |
Posted: Sat Jun 18, 2011 1:40 am Post subject: |
thanks. that would have been the obvious route if i had a bleed screw to take to the hardware store. unfortunately, it's now lost inside the radiator. |
?Waldo? Samba Member
Posted: Sat Jun 18, 2011 3:32 am Post subject: |
Yuh huh. It is to an m8.
I've dealt with many ranging in years from '82 (diesel) to late waterboxer and they have ALL been 8x1.25 (12mm long). |
Posted: Sat Jun 18, 2011 4:13 am Post subject: |
okay, okay--it's an m8! now that i finally have the original screw to compare it to (and several sambistas saying so--thanks, as always), i can be fairly sure of it. problem is, the plastic hole must have contracted drastically during my last overheat, and i couldn't pound an m8 through there with a hammer if i tried (i won't). my right brain is coming up with mostly comical solutions at this point, so i think i'd better shut my eyes and pick it up tomorrow. |
Posted: Sat Jun 18, 2011 6:50 am Post subject: |
I assumed from your insistence that it wasn't an M8 that you were holding the top half of the screw.
Apologies.
B. |
Posted: Sat Jun 18, 2011 1:39 pm Post subject: |
bercilak, i had only the head and the unthreaded, topmost portion of the screw, which is much narrower than m8. plus, looking at the hole atop the radiator, i knew there was no way i was getting an m8 in there. i still have no idea how i'm gonna do it.
i'm wishing i still had access to a metalworking shop, because jb welding the screw back together (the two pieces fit back together perfectly) strikes me as the kind of dumb idea that usually gets me in trouble. i wonder why van cafe sells the washer, but not the screw? i'm guessing because the likeliness of anyone busting the screw is slim. well, i've done it twice! so there!
but thanks for your tip, which would have been useful if i'd had the screw for comparison. |
Posted: Sat Jun 18, 2011 1:43 pm Post subject: |
Van-cafe doesn't sell the bleeder bolt because every hardware store in the civilized world stocks them and the shipping alone from van-cafe would cose more than the bolt at the local hardware store. |
Posted: Sat Jun 18, 2011 1:54 pm Post subject: |
but the ones from the hardware store won't be narrowed down at the top for smoother bleeding! and i don't have my own dremel.
i'm sure every hardware store in the civilized world (and i remind you, i'm in west texas...) also carries a comparable washer. that's why i find it weird that they'd sell the one and not the other. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Pick up an M8 thread chaser and clean the threads. Use thick grease in the grooves (fill them flush) to catch the plastic bits. Then pull the hoses and force flush with a hose to remove any you miss, though tiny plastic bits aren't much of a threat to things.
I can't see even an extreme overheat changing the dimensions of plastic 12 feet from the Vanagon's engine, BTW.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
BillM Samba Member
Joined: June 18, 2004 Posts: 1381 Location: Stonington,CT
Posted: Sat Jun 18, 2011 1:57 pm Post subject: |
I just checked my radiator from Van-Cafe. It's an 8x1.25 that's in it. It does look like it's threaded into the plastic before it hits the metal. Can you thread the bolt in? Did you perhaps bunged it up while drilling? From the way it sounds you break a lot of bolts. You should invest in a torque wrench and a good set of reverse drill bits. That way hopefully you'll stop breaking them and if you do a better way to get them out.
Bill with a 1/4" 3/8" 1/2" and a set with crows feet torque wrenches... |
jbnova Samba Member
Joined: August 20, 2010 Posts: 118 Location: Ellensburg, WA
Posted: Tue Feb 09, 2016 12:10 pm Post subject: Re: radiator bleed screw size? i've searched already! |
Does anyone know the proper torque for the radiator bleed screw? Or have recommendations on how to proceed cautiously without breaking it? How tight do these need to be?
I ask, because mine doesn't crank down super tight. It gets tight, but then I can keep turning it with effort, and it has that "if I keep turning this bolt, it's gonna snap" kind of feeling. I've been known to snap copper bolts in the past (and CV bolts!).
While searching for a torque spec, I discovered that lots of folks have snapped them.
Once I know the correct torque, I'm thinking I'll go ahead and replace the bolt as I've probably already stressed it out.
Thanks! _________________ 1986 Westfalia Weekender
2wd; Bostig RG3
GoWesty (H&R) 1.5" Lift Springs + 0.5" pad in rear.
Bilstein Shocks
16" Mefros, Cooper Discoverer AT3 (215-70-16) |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Tue Feb 09, 2016 12:30 pm Post subject: Re: radiator bleed screw size? i've searched already! |
No room for a torque wrench. It doesn't need to be very tight. It just plugs a hole. It tightens into brass threads molded into the plastic radiator. It is supposed to have a sealing washer that does the sealing work, not torque.
Mark |
jbnova Samba Member
Posted: Tue Feb 09, 2016 12:50 pm Post subject: Re: radiator bleed screw size? i've searched already! |
That's super helpful. I just go easy on it.
2wd; Bostig RG3
Bilstein Shocks
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
greebly Samba Member
Joined: August 27, 2009 Posts: 966 Location: Here and now
Posted: Tue Feb 09, 2016 1:28 pm Post subject: Re: radiator bleed screw size? i've searched already! |
I have a used radiator here, you are welcome to the bleeder. PM me. |
