Bret Young Samba Member
Joined: August 26, 2006 Posts: 756 Location: Turlock, CA
Posted: Fri Jun 17, 2011 11:23 pm Post subject: Determining what case I have |
Hey guys. Trying to determine what engine case I have on the motor that came with my newly acquired 64 notchback. I was told it was the original 1500 from the guy I bought it from, but he said that it ran but he pulled the heads to re-ring them......and yeah. I didnt get the heads. It is basically a shortblock with the pistons/cylinders on it right now.
Well I took a wire brush and scrubbed along the center of the case today and came up with: U0049621
Can anybody help me decipher what I have got here? I would be stoked if it was a dual relief case, but what confused me is that it has a 6V fanshroud and a 6V generator. Were they interchangable? Later engine/engine case but the earlier shroud would bolt right up? I dont have a problem with the 6V shroud and 6V generator as I havent determined if the car is currently 6V or 12V yet (no battery, no starter motor, no regulator).
Any help is appreciated.
Bret |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Sat Jun 18, 2011 6:58 am Post subject: |
The UO case number means it's at least a 69, possibly a 70 or even 71. If the engine is out of the car, count the number of teeth on the flywheel. 109 teeth is 6 volt, 130 teeth is 12 volt.
Look underneath the case, on the left side, and see if there are 2 big flat blade screws on it (at both ends along that side), or just 1 (rear only). This will tell you if it's a single or dual relief case (2 = dual, 1 = single).
As for the shroud and generator assembly, yes, they do interchange (bolt on). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Jun 18, 2011 7:06 am Post subject: |
Awesome Bob! Thank you. This is my first type 3, so it is a completely different animal to me. Well I guess that is cool, a later case gives me a chance to have a stronger case than I originally thought I had.
Hell, if it is that late of a case, I wonder if the pistons/cylinders are actually 83's like the owner said (probably wrong since he said this was the original motor out of the car), or if they are indeed 85.5's.
Well that is a good place to start. Any other tid-bits you think I should know, feel free to share. Thanks again. |
Posted: Sat Jun 18, 2011 7:38 am Post subject: |
mrblyoung wrote: |
Since the heads are off it, you can kind of polish the top of the piston (scuff pad and laquer thinner work good), and use a magnifying glass to see what size the pistons are by the number stamped into the top of them. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
DHanna Samba Member
Joined: June 15, 2004 Posts: 240 Location: North Richmond, N.S.W Aust.
Posted: Sat Jun 18, 2011 6:09 pm Post subject: |
If the heads are off a simple rule measurement will easily show the difference between 83 and 85.5 bore.
DH |
