pupjoint Samba Member
Posted: Tue Jun 21, 2011 9:55 am Post subject: what trip speedo is this? |
anyone has any idea what trip speedo is this?
whats the best way to lubricate the gears inside before putting it to use? squirt some oil thru the ? |
Jake Martinez The VW Kid
Joined: February 06, 2009 Posts: 2120 Location: Wilmington, NC
Posted: Tue Jun 21, 2011 10:06 am Post subject: |
for a 70's model beetle. _________________ 58 euro vert
63 bug ruby
64 sunroof notch
65 bug
67 standard
zombie wrote: |
buslife wrote: |
10 inch narrowed beam |
Congrats, that's going to look like shit. |
Posted: Tue Jun 21, 2011 10:08 am Post subject: |
ya i just had a closer look and saw 9 72.
however, i thought all late bugs have fuel gauge inside the speedo?
if this is for a late bug, where would the fuel gauge be? |
Posted: Tue Jun 21, 2011 10:11 am Post subject: |
it could have been a speedo built in the 70's then was still optional from dealership for the earlier cars.
im not to sure though. _________________ 58 euro vert
63 bug ruby
64 sunroof notch
65 bug
67 standard
zombie wrote: |
buslife wrote: |
tstracy39 Samba Member
Joined: May 14, 2008 Posts: 3294 Location: Seattle, WA
Posted: Tue Jun 21, 2011 1:12 pm Post subject: |
There wouldn't be enough room to have the fuel gauge inside the speedo with the tripcounter already in there, obviously. By 1972 there were already aftermarket VDO fuel gauges with the same format face and you can still get them, but they will only work on a 10-180 ohm VDO sender not a stock Beetle/Super sender. If the calibration ration (W=0.5) is any indication, this was special ordered for something with very very large wheels, probably a Baja or dune buggy. _________________ Check my classifieds for kewl gauges:
http://www.thesamba.com/vw/classifieds/search.php?username=tstracy39
EverettB wrote: |
I like your fork. |
Posted: Tue Jun 21, 2011 6:01 pm Post subject: |
hmmm ok. thanks. not much of a use for me then. been wanting a correct unit for my 66, but cant afford the asking price yet. |
Posted: Tue Jun 21, 2011 8:06 pm Post subject: |
tstracy39 wrote: |
There wouldn't be enough room to have the fuel gauge inside the speedo with the tripcounter already in there, obviously. By 1972 there were already aftermarket VDO fuel gauges with the same format face and you can still get them, but they will only work on a 10-180 ohm VDO sender not a stock Beetle/Super sender. If the calibration ration (W=0.5) is any indication, this was special ordered for something with very very large wheels, probably a Baja or dune buggy. |
the W0.5 stamped was actually scratched out and hand scratched with W8 roughly to the left.
what does W8 stand for? |
Posted: Wed Jun 22, 2011 1:48 am Post subject: |
pupjoint wrote: |
tstracy39 wrote: |
Either it's a KM/H housing that had a MPH movement installed in it at the factory, or at some point, someone took it to a speedometer service shop and had it recalibrated for stock Beetle size wheels. 66 Beetle speedometers are calibrated to W=0.8, so it's worth trying to install it and seeing how accurate it is with your application. If it's not accurate, you should be able to take it somewhere to be recalibrated. _________________ Check my classifieds for kewl gauges:
EverettB wrote: |
I like your fork. |
Morganwerk Samba Member
Joined: December 30, 2000 Posts: 496 Location: Sacramento Valley
Posted: Sat Jul 11, 2020 3:04 pm Post subject: Re: what trip speedo is this? |
I have one of those, my Dad bought it in the late 70s when he had the engine rebuilt so he could have 0 miles and know exactly how many miles were on the engine. The trip odometer came in handy as he was always keeping track of mpg. It's aftermarket, perhaps it matches a VDO style of that era.
He removed it when it turned over and it spent 25 years stored in a drawer, then the last 15 displayed in my garage. _________________ Gary
1966 1300 Sea Sand
2003 GTi VR6 |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Thu Sep 03, 2020 2:00 pm Post subject: Re: what trip speedo is this? |
tstracy39 wrote: |
This concerns an original VDO speedo with trip function specifically made for the Volkswagen bug, that was only supplied on European emergency response vehicles (for instance VW bug police cars), and then only on special order.
For that reason they had a black face with the white numbers, this color scheme increased readability (kind of a big thing when you are responding to an emergency, and are in the midst of running a red light at high speed with sirens and blue lights on.... you don't want to look at the speedo too long in those circumstances).
Hence also the reason the VW improvements for 1968 model year terminated the needle stripe design of the stock VW speedo's.
Needless to say that only very few of these trip speedo's with black face and white numbers have been produced by VDO, and even less have survived.
They are very rare, as they were not a general accessory available to the general public; they could not be simply ordered by private individuals at their Volkswagen dealer.
That these speedo's were only used in European cars, means that calibration at W0.5 is for a km/h scale.
The speedo of the original poster was converted from km/h over to mph (you can see that the original flat black speedo trim ring was tampered with), someone really did a very nice job keeping the original look.
I've got one in my 1960 car, and it works just like the stock speedo (in km/h).
If you look closely in the picture of my dash, you can see that the design of the speedo is similar to that of my VDO tach and the other VDO gauges.
(I know, I know, a 1960 bug should have a needle stripe trip speedo, but this black with white numbers set-up is way cooler , and for this particular car I couldn't care less for stock appearance obviously )
_________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much!
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Thu Sep 03, 2020 2:41 pm Post subject: Re: what trip speedo is this? |
tisius wrote: |
This concerns an original VDO speedo with trip function specifically made for the Volkswagen bug, that was only supplied on European emergency response vehicles (for instance VW bug police cars), and then only on special order. Needless to say that only very few of these trip speedo's with black face and white numbers have been produced by VDO, and even less have survived.
Do you have to make RRRrrrRRRrrrRRRrrr ambulance siren sounds while you drive? |
tisius Samba Member
Posted: Thu Sep 03, 2020 3:18 pm Post subject: Re: what trip speedo is this? |
KTPhil wrote: |
tisius wrote: |
hahaha, no, I already have a bus that does that, one blue-flashing loud car is enough for me
.... if it ain't dutch, it ain't much! |
