Bohdan Samba Member
Joined: November 21, 2007 Posts: 143 Location: Venice, Florida
Posted: Fri Jun 24, 2011 7:38 pm Post subject: Fan Alignment |
Greetings. I put on my new fan on my new alternator. When I spin it, it looks like a wobbling plate. How much tolerance does this have to have? Is there a way to align it? Thanks |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Fri Jun 24, 2011 7:39 pm Post subject: |
OE or aftermarket fan?
It should not wobble. _________________ Glenn
Member #1009
#BlueSquare |
Bohdan Samba Member
Posted: Fri Jun 24, 2011 7:40 pm Post subject: |
It is a welded and balanced from cip |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Fri Jun 24, 2011 8:02 pm Post subject: |
Bohdan wrote: |
Probably Empi. _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
Glenn Mr. 010
Posted: Fri Jun 24, 2011 8:03 pm Post subject: |
Bohdan wrote: |
Send it back.
CIP sells cheap stuff and it's obviously a poor quality. _________________ Glenn
Member #1009
#BlueSquare |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Fri Jun 24, 2011 9:55 pm Post subject: |
It might be welded but I doubt it's balanced if it wobbles. You would try to balance a tire on a bent rim would you? Likewise if they had run that on a balancer they would have seen it was junk. You can't take something that is prone to gyroscopic forces (like a bent rim or fan) and balance it.....not properly anyway.
RC _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
torsionbar Samba Member
Posted: Fri Jun 24, 2011 10:52 pm Post subject: |
Bohdan wrote: |
why?? it's a crap empi fan and it is not balanced after welding. for only 20 bucks more, you could have bought a gene berg welded and balanced fan made from a genuine vw fan, tig welded, and balanced again after welding. was it really worth saving a measly 20 bucks?? |
puddles Samba Member
Posted: Sat Jun 25, 2011 7:02 am Post subject: |
torsionbar wrote: |
Bohdan wrote: |
well put. wish more people would spend a little more in this hobby to avoid and get rid of the junk that seems to be everywhere. |
Glenn Mr. 010
Posted: Sat Jun 25, 2011 7:47 am Post subject: |
The cheapest is not aways the least expensive _________________ Glenn
Member #1009
#BlueSquare |
