vanjoe Samba Member
Joined: December 25, 2009 Posts: 606 Location: Santa Maria
Posted: Tue Jun 28, 2011 9:18 pm Post subject: Lift your carpet! |
Ok so I am replacing my carpet in the front. Under the padding there was moisture. The drivers side had quite a bit of rust. I sanded and wire brushed it and got all the rust off. I sealed it with some rubberized coating. I am always learning something new about these vans. So my suggestion to anyone new on here or looking to buy a van is LIFT THE CARPET! I feel I am very lucky that the rust was only surface rust. I am excited about what the finished product will be. _________________ 1990 VW Vanagon tin top weekender Carat
1998 Mercedes S420
"Why is there never time to do it right the first time, but there is always time to do it twice?"
"Back to the basics!" |
Bman Samba Member
Joined: April 28, 2005 Posts: 895 Location: South Coast, Oregon
Posted: Tue Jun 28, 2011 10:04 pm Post subject: |
I second that....
I finally started to take care of some of the rust issues under my 89 Westy windshield which led me to lifting my front carpet. years of Oregon rain moisture had left me with a golf ball size rust hole in that front corner of the passenger wheel well. As the wife and kids were scheduled to take the van x-country the next day I had no time to deal with it but to put on a rust inhibitor.
Check around your window seals for those bubbles and deal with it asap!
Check under your carpets, stop those leaky windshields before your looking for a donor van for cut and weld metal!
on the bright side, I'm excited to tackle this project late this summer when its finally bone dry here on the coast. _________________ ~Bryan
1990 Burgandy Tintop (Wife's Daily Driver)
1989 Tiico Westfalia "Taj"
2WD Doka build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=503578&highlight=
FaceHook:
https://www.facebook.com/pages/VW-T3-DokaSinka/129026087217120?ref=hl |
r.e.wing_fc3s Samba Member
Joined: April 16, 2010 Posts: 591 Location: Vanagon Capitol USA: Bellingham, WA
Posted: Tue Jun 28, 2011 10:13 pm Post subject: |
ive noticed this is caused mainly from two thing, apart from water leaks. 1 spills from filling the washer get absorbed and secreted by the pad and 2 condensation forms, especially in the winter from the warm inside metal/air vs cold outside metal/air. i use some absorbent mats under the pad in the winter time. |
carterzest Samba Member
Joined: January 22, 2008 Posts: 3842 Location: Eagle, ID/Sun Valley, ID
Hold Me _________________ Happiness=Portland, Oregon in the rearview mirror! |
madspaniard Samba Member
Posted: Tue Jun 28, 2011 10:34 pm Post subject: |
carterzest wrote: |
Hold Me |
last thing you wanted to hear after all the rust work you are doing... _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
POS Samba Member
Joined: December 27, 2004 Posts: 285 Location: In a bus, down by the river in Boonville MO
Posted: Thu Jun 30, 2011 5:25 am Post subject: Check under your carpet. |
For sure check by your seat belts.
This is what I found.
David
vanjoe Samba Member
Posted: Thu Jun 30, 2011 6:57 am Post subject: |
I was very fortunate that my only rust was surface rust around the gas pedel. I have read post on here about the seat belt rust problems. Sorry to see that about your seatbelt anchor points but fortunately you caught it before someone got hurt. _________________ 1990 VW Vanagon tin top weekender Carat
1998 Mercedes S420
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Thu Jun 30, 2011 9:33 am Post subject: |
While you're at it, you may want to lift the rubber footwell mat too.
A quick way to tidy this up and zap any rust may be found in my post here:
Bedliner in front footwells (with photos)
http://www.thesamba.com/vw/forum/viewtopic.php?t=394760
Cheers,
CJ _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
Posted: Thu Jun 30, 2011 11:27 am Post subject: |
Carpet, you don't want carpet...what you want is an alllllleeeeeeuuuuuhhhhh rrrrruuuuuugggg
http://www.youtube.com/watch?v=zEUrQoG7ED8 _________________ Happiness=Portland, Oregon in the rearview mirror! |
bosruten Samba Member
Posted: Thu Jun 30, 2011 2:14 pm Post subject: |
_________________ '87 Syncro Weekender |
Vanagon Nut Samba Member
Posted: Thu Jun 30, 2011 6:13 pm Post subject: |
I recently inadvertently shoved aside the carpet covering the upper/forward part of DS wheel arch.
Sheesh.
Rust in the seam.
< plugs ears with fingers >
"ahhhh la la la la la don't wanna know ahhhh la la la la la"
1988 West DIY 50º ABA
VE7TBN |
