my 64 air ride project...
Page: 1, 2, 3  Next
bobsbug64
bobsbug64 is offline
PostPosted: Wed Jun 29, 2011 9:51 pm    Post subject: my 64 air ride project... Reply with quote
well here it goes.. pictures are not in order .. i'll keep adding more tomorrow after work..
Nubby
Nubby is offline
PostPosted: Wed Jun 29, 2011 11:42 pm    Post subject: Reply with quote
Looks good man. What sound deadner did you use?
bobsbug64
PostPosted: Thu Jun 30, 2011 3:54 pm    Post subject: Reply with quote
thanks... its fat mat rattle trap.. its not bad to put in but sliced my hands all up.. the silver part is real sharp on the edges..!!
ziptyd66
ziptyd66 is offline
PostPosted: Thu Jun 30, 2011 4:34 pm    Post subject: Reply with quote
looks good I like the way the back bags are done.
63 bug bagged w/1200 sp (0\ l /0)
Reddd
Reddd is offline
PostPosted: Thu Jun 30, 2011 4:46 pm    Post subject: Reply with quote
looks good, i just dont like the use of the torsion cover deal being used as a bolt point for a mount. Id make something little beefier since your putting different stress on it than when it has a torrsion bar and bushings in it
Boom
Boom is offline
PostPosted: Thu Jun 30, 2011 8:03 pm    Post subject: Reply with quote
cool project but why are you using adjusters in your beam if its air ride?
Ovals are Overrated.....Click to view image
67 Chubby White Chic
DŁg BŁg
dLk
bobsbug64
PostPosted: Thu Jun 30, 2011 8:30 pm    Post subject: Reply with quote
honestly i had the beam built for me with air ride in mind.. i didn't know people are running them without adjusters.. do i just take out the bolts?
massimo63
massimo63 is offline
PostPosted: Fri Jul 01, 2011 9:17 am    Post subject: Reply with quote
yes you can, could you give me the size of schocks closed and open?
Thanks
Massimo
pOrk
pOrk is offline
PostPosted: Fri Jul 01, 2011 2:53 pm    Post subject: Reply with quote
You have the body off the pan why don't you install air suspension in the front the right way? Air shocks are NOT air suspension.
touchdowntodd
touchdowntodd is offline
PostPosted: Fri Jul 01, 2011 3:30 pm    Post subject: Reply with quote
id REALLY beef up those rear bottom mount brackets if i were u... those will snap like that
mine - '65 6vt 40hp, 5.5" beam, Spindles, BRMs, etc
project with dad - '62 pan'd manx copy body 6vt 40hp..
pOrk
pOrk is offline
PostPosted: Fri Jul 01, 2011 5:33 pm    Post subject: Reply with quote
Do you have any photos of the lower bag mount on the axle tube? Looks real weird in the one pic
bobsbug64
PostPosted: Fri Jul 01, 2011 6:58 pm    Post subject: Reply with quote
meaning bags up front?
lucille66
lucille66 is offline
PostPosted: Fri Jul 01, 2011 7:03 pm    Post subject: Reply with quote
Reread what u just wrote. AIR shocks. How is that NOT air suspension? I'm gonna love watching you explain this one......
bobsbug64
PostPosted: Fri Jul 01, 2011 7:06 pm    Post subject: Reply with quote
well said
touchdowntodd
PostPosted: Fri Jul 01, 2011 7:36 pm    Post subject: Reply with quote
eric worked for a very well known air ride company for a while, and ive done several installs as well..
air shocks arent air ride due to the fact that they arent designed to be adjustable, they are designed to be a helper to keep a vehicle at a certain height, not to be adjusted consistently ... they are a helper for added load in a truck or car..
they require a higher PSI than you would need in a bag, and there for ride much rougher.. im not goin to say that they cant ride decent, but abag will ride better, perform better, last longer, and have the proper adjustability for a true "air ride" setup..
these are simply not designed to be the only suspension in any part of the car, they are designed to have coil or leaf springs as the actual suspension and load bearing item..
hope that makes sense, im sure eric will chime in... they just arent the right way, only reason it seems people do em on VWs is lack of space for a bag, altho i think there is enough room you just have to be creative and im definetely not talking about a single bag setup, forget that shit... sway is no fun
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sat Jul 02, 2011 2:44 am    Post subject: Reply with quote
bobsbug64 wrote:
So....
shifting with Lucky Number 13 eh? No 8-ball like everyone else! (Well, I have a solid blue 2-ball on my Baja bug... Wink )
-Andy
Miklo
°Chale!
Miklo is offline
PostPosted: Sat Jul 02, 2011 6:02 am    Post subject: Reply with quote
I have to agree with touchdowntodd on both posts.
Its all very nice work but that bottom mount will bust right off. First ride, maybe even first raise.
And an air shock is not considered a "true" air ride for the reasons he mentioned above. They are more of a support for the other suspension... not for the whole weight of a car. Hence they are a little stiffer and not as free floating as an airbag.
I would also patch up that framehead a bit. You don't want ANYTHING getting in there that isn't supposed to be in there.
Wagens Aircooled Squadron
'55 Type1 "Ozma"
'70 Type2 "Hannah"
'66 Type1 "Charlotte" RIP
OG over Aftermarket!
Dr OnHolliday wrote:
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche...
bobsbug64
PostPosted: Sat Jul 02, 2011 10:14 am    Post subject: Reply with quote
any suggestions to beef this up so it won't snap?
pOrk
pOrk is offline
PostPosted: Sat Jul 02, 2011 2:21 pm    Post subject: Reply with quote
Bob, any larger photos? Did you use square tubing to make the mount? Real hard to tell whats going on there, but it looks like the flat steel could bend down without reinforcing it. Maybe weld a piece of 1/4" steel perpendicular to the lower bag bracket to make it more rigid. And a better photo so I can see it better?
Air Shocks were designed to help support heavy / unstable loads, NOT the entire weight of a vehicle. Remember what a shock was designed for, dampening, NOT carrying.
The only reason this kinda works on bugs is cause there is so little weight in the front end of the car. The very high pressure it will take to lift the car is not going to offer a very good ride up front, but then again if your running 145/65's for clearance I suppose ride quality isn't a huge demand anyways?
I know AirKewld has sold a bunch of kits this way and they seem to work ok without snapping the lower shock bolt off of the torsion arm BUT they only reason he sells them is because people buy them.
This has been argued to death on here and it works but it is NOT the right way to add air suspension to a car. This guy appears to be doing the right things with the rear setup so why not do the right things with the front and have a NICE riding reliable suspension setup on all 4 corners?
Airkewld
Location: 3673 South Bullard Ave, Suite 117-118, Goodyear, AZ 85338
Airkewld is offline
PostPosted: Sat Jul 02, 2011 2:43 pm    Post subject: Reply with quote
The axle tube are less that .125" thick. You will tear the mount right off the axle tubes or bend them.
I did something similar in 99', went to chromoly off road tubes and it did the same thing.
TIME, we all need more of it. Purchase #PRObuilt Products from Airkewld and free up time for family and friends. - https://www.airkewld.com/PRO-Built-s/2452.htm
Page: 1, 2, 3  Next
