footdoc Samba Member
Joined: November 01, 2010 Posts: 140 Location: Pittsburgh, PA
Posted: Sun Jul 03, 2011 8:26 am Post subject: Opinions on solid vs rubber motor mounts |
Is one better than the other? What application would call for the solid mount? I need to replace the mounts in my Bug (2276cc) daily driver. Any suggestions? |
Buellistic Samba Member
Joined: February 04, 2011 Posts: 357 Location: Albuquerque, New Mexico
Posted: Sun Jul 03, 2011 9:04 am Post subject: |
On any engine I've had experience with, VW or Motorcycle, solid mounts transfer vibration through the frame and end up breaking something else further down the line. Not to mention is shakes and rattles the car.
I would just go for urethane mounts. They're stiffer than rubber but not TOO stiff. I can't say for sure, but I think they last longer too. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Sun Jul 03, 2011 10:00 am Post subject: |
Thanks for the advice. I'm sure the above mentioned kit is the "cats ass" but could I just change the original rubber? I also have a donor car with a brand new solid mount in it that I was just going to swap out, but now maybe I'll stick with the rubber mounts. |
jsturtlebuggy Samba Member
Posted: Sun Jul 03, 2011 10:16 am Post subject: |
Yes use good quality rubber mounts for transmission.
With the size of your engine you really think about using what dave posted a link to.
Also if you are driving it hard you may want to think about install a Kafer or Mendeola Stiffy bar setup to keep everything in align. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Sun Jul 03, 2011 10:23 am Post subject: Re: Opinions on solid vs rubber motor mounts |
http://www.aircooled.net/gnrlsite/resource/articles/dragsetup.htm
you don't need to replace the stock rubber until 12s. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Sun Jul 03, 2011 9:26 pm Post subject: |
Buellistic wrote: |
the urethane bugpack and energy suspension brand nosecone mounts last about one day. Sometimes two
then they rip in half |
Posted: Sun Jul 03, 2011 11:11 pm Post subject: |
modok wrote: |
Buellistic wrote: |
I'm gonna have to double check the ones on mine then. I think I used Bugpack brand. They've been in there since 2005. Obviously I'm running a basic 1600sp though, so maybe you mean they rip in half when you use larger engines? |
XLR8 Samba Member
Joined: October 09, 2010 Posts: 437 Location: ulverstone, Tasmania, AUS
Posted: Sun Jul 03, 2011 11:51 pm Post subject: |
ive got rhino engine mounts and they are considerably louder on the highway so i'd hate to imagine my combo with solid mount.
but cant say anything for durability yet as i havent done much off-roading since. _________________ "But that parts not user serviceable!"
"Mate, everything's user serviceable." |
modok Samba Member
Posted: Mon Jul 04, 2011 12:17 am Post subject: |
If you drive easy then maybe the urethane will hold, I would not know.
The rhino mounts seem unbreakable, but they are almost as solid as steel, shame about that.
If you put the energy suspension type urethane in the cb housing I bet that would be a pretty good unit........if I may dream
My favorite is to convert to a late 3-bolt nosecone and stock mount that goes with it, then weld a tube across the bottom of the "bell" of the mount, thus making a mid-mount. Only for IRS though, seems like the late mount does play well with swingaxle |
Posted: Mon Jul 04, 2011 6:55 am Post subject: |
I've had my Bugpack Urethane mounts in use since 2005, FWIW. _________________ It's just advice, do whatever you want with it!
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Mon Jul 04, 2011 7:54 am Post subject: |
Buellistic wrote: |
The urethane mounts are shite... just use the HD German mounts...
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
mark tucker Samba Member
Posted: Mon Jul 04, 2011 8:35 am Post subject: |
I use urathane/padded mount fr& rear & stock front mount filled with urathasne(3m 5200) no noise no jiggleing around,no eating of parts,no extra stress areas from soild mounting.and kafer style 3 bar setup. |
Posted: Mon Jul 04, 2011 10:55 am Post subject: |
HD German mounts are unusable when you hit 12s in the quarter (BTDT), even with a KCB, Torque Bar, or Traction Bar. _________________ It's just advice, do whatever you want with it!
slalombuggy Samba Member
Posted: Mon Jul 04, 2011 12:02 pm Post subject: |
Don't forget tires play a big part on your choice of mounts also. Big sticky tires can break stuff in a hurry. I tore the steel from mount off the torsion housing a couple of times on my buggy till I went to a Berg steel mid-mount. 10" wide soft compound road race slicks will grip a lot more than a pair of 165 tires. I will also add that my steel mounts saved me from a complete engine failure. They transmitted an engine knock that I heard in the middle of a run and I had time to kill the motor before it comitted suicide. My Beetle will be getting all steel mounts also. I don't really mind the noise, but like the fact I won't be tearing mounts and trannys up.
brad |
RailBoy Samba Member
Joined: March 10, 2008 Posts: 2904 Location: Virginia
Posted: Mon Jul 04, 2011 4:52 pm Post subject: |
What I did back in over 20 years ago for my street rail was get some trans straps, sandwich two brand new rear mounts on the rear with the trans straps is place. Then went ahead and made a steel mount for the nose cone, all in place, this way everything seated in.....
It has worked fine, everything always lines up when doing removals and now run a 2110..... RB |
MinamiKotaro Samba Member
Joined: July 18, 2008 Posts: 1039 Location: Somewhere in TN
Posted: Mon Jul 04, 2011 5:02 pm Post subject: |
Never had issues with urethane mounts. The same set of urethane mounts lasted in my Bug for over a decade. Plus, it was Papaw's car before I got it and he wasn't exactly easy on vehicles.
Dad ran urethane mounts in his DD Bug for twenty years, they're still in it and in good shape.
*Good* rubber mounts should be durable and quieter. I will never consider solid mounts for a street car ever again. They are unbearable. _________________ 1967 VW Beetle
2276cc
MegaSquirt-extra v3.57
Check out my ongoing story. |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Mon Jul 04, 2011 8:12 pm Post subject: |
I have seen many more broken urethane mounts than I have stock VW mounts.
I ran a 12.51 in my Manx on stock VW mounts with a Moore mid mount and I'm still running the same unbroken, undeformed stock VW mounts. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
modok Samba Member
Posted: Mon Jul 04, 2011 8:44 pm Post subject: |
I've seen a lot of those urethane mounts at car shows, so they work for some people.
point is that the stock nosecone mount used in conjuntion with a berg or moore mid mount, or homeade mid mount, or padded strap, is way superior to a urethane nosecone mount by itself.
The rear mounts are not as critical, you can go solid, urethane+kafer brace, stock and a traction bar, lots of ways that work |
oprn Samba Member
Joined: November 13, 2016 Posts: 12708 Location: Western Canada
Posted: Fri Jun 23, 2017 9:36 pm Post subject: Re: Opinions on solid vs rubber motor mounts |
This is an old thread but a current problem for me.
I just pulled the transmission on my Manx copy to address the front mount holes on the transmission nose cone. I noticed after I bought the car that one nut was missing and I replaced it only to have both nuts bugger off shortly after. The holes in the nose cone bracket are pounded out. I just discovered the left rear mount has failed too.
I have on the junk pile a swing axle with bug suspension that I cut off my sand rail about 8 years ago to make way for a Bus IRS set up - perfect! Spare parts! Uh - not so quick buddy, turns out it has solid mounts and the nose cone bracket has a crack extending from one edge right through both mounting holes!
Questions:
Are these kind of failures common with stock mounts? (stock 1600 DP with Kadrons)
Do solid mounts cause nose cone failure?
If I used the solid mounts, would the noise increase be noticeable in an open buggy?
This buggy will see mostly street use with a mild 1911cc type 4 engine (in the works). Thanks in advance for your replies! |
