Will a 5.43 R/P fit in a 2wd 4spd transaxle...
1621 is offline
PostPosted: Sun Jul 03, 2011 3:59 pm    Post subject: Will a 5.43 R/P fit in a 2wd 4spd transaxle... Reply with quote
And if so, are they difficult/expensive to come by?
Also, how do they compare to 4.86 in terms of strength and reliability?
'85 Westy
Wellington
Wellington is offline
PostPosted: Sun Jul 03, 2011 4:55 pm    Post subject: Reply with quote
Yup, stronger, how much?? debatable.
About $1000 NEW from Weedle.
J Charlton Premium Member
J Charlton is offline
PostPosted: Sun Jul 03, 2011 5:28 pm    Post subject: gearing Reply with quote
What are you trying to achieve with the 5.43?
NAHT hightop availability Feb 14 2020 See website http://canadianhightops.ca for details on current production discount including cut off dates
Distribution plan 2020: Staunton Va 6(5available), Florida 6(4 available), Colorado 6 (5 available), SLC 6 (5 available), Sacramento 6?, Kennewick 6?, GTA (Toronto) TBD
blakeck2
blakeck2 is offline
PostPosted: Sun Jul 03, 2011 5:28 pm    Post subject: Reply with quote
Wellington wrote:
Yup, stronger
I thought there is more teeth on the 5:43 which would indicate them being smaller thus weaker. I could be wrong though Confused
1986 Vanagon Syncro GL, westy interior, GW 2.4 and all locked up
1973 Thing
View user's profile Send private message AIM Address Facebook Classifieds Feedback
Alaric.H
Alaric.H is offline
PostPosted: Sun Jul 03, 2011 6:44 pm    Post subject: Reply with quote
blakeck2 wrote:
Wellington wrote:
Yup, stronger
I believe you are correct
1621
1621 is offline
PostPosted: Sun Jul 03, 2011 7:34 pm    Post subject: Reply with quote
I was playing with an online gear calculator (http://www.rearendparts.com/pages.php?pageid=16) and playing with numbers. Based on my current set-up I think I might benefit from the numerically larger final drive ratio.
I've got a heavy 2wd Westy (about 5000 lbs. before gear and passengers), with a chipped 1.8T (~240 Lb-ft of torque at 3000 rpm, ~210 hp at 5000 rpm), a 0.77 4th gear, and 28" tall tires. This is a great set-up, but when loaded down is not as "peppy" for obvious reasons. I figured if I could increase the RPMs a bit at each gear it would put me squarely in the sweet spot of the power band, 2500-5000 RPMs, earlier, reduce my reliance on high boost pressures, and keep it there longer for my driving style.
Plugging numbers into the calculator, I discovered that my current set-up with a 5.43 almost perfectly matches VWs stock gearing with a 4.86 final drive and 25.7" tires, typically within 100 RPMs or so until 4th gear. It would also lend a bit more low end torque earlier in the range to get that heavy beast moving off the line a bit quicker. I also think it may improve my gas mileage on longer drives somewhat (speculating here) due to higher RPMs and a bit less boost pressure when driving through the mountains - everywhere I go seems to be uphill.
Anyway, just thinking out loud and thought I'd ask if the R&P would even fit before I go any further. Also wondering if it will hold up to the extra power. Any additional thoughts from the gearing gurus here?
'85 Westy
Wellington
PostPosted: Mon Jul 04, 2011 3:00 am    Post subject: Reply with quote
blakeck2 wrote:
Wellington wrote:
Yup, stronger
I stand corrected, the lower the ratio the stronger
for 2wd, available from Weddle.
4.13 strongest
4.57
4.83
4.86
5.43
5.50
5.83 weakest
Weakest is relative, I don't think you will break it, just you will probably wear ALL of them out faster than the rest of us.
jerrydog411
jerrydog411 is offline
PostPosted: Mon Jul 04, 2011 4:07 am    Post subject: Reply with quote
1621 ... why not give Daryl a call .. straight info from the fellow who builds them.
http://www.aatransaxle.com/
To contact:
(425)788-4070
[email protected]
1621
1621 is offline
PostPosted: Mon Jul 04, 2011 8:29 am    Post subject: Reply with quote
To contact:
(425)788-4070
[email protected]
Thanks, I plan to, just throwing it out on the Samba to see if anyone knew if it fits. I'll give him a call this week and see what he has to say about playing with gears.
'85 Westy
Jon_slider
Jon_slider is offline
PostPosted: Mon Jul 04, 2011 9:34 am    Post subject: Reply with quote
Yes, a 5.43 will fit, and yes it is slightly weaker, but I think your problem is your .77 4th
I agree a 5.43 ring and pinion would make your gearing close to stock. Except for your 4th which is a big gap away from 3rd.
But you can get the exact same effect without going to a 5.43, by just going to 25.7" tires, and making no changes to your transmission. I think changing tires is cheaper. You would still have the big gap between 3rd and 4th though.
Ideally, I would just take out the .77 4th and put the .85 back in. You would be fine with your current 28" tire and ring and pinion if you do that. That produces 10% tall gearing accross the board, no big gap between 3rd and 4th. This is probably the best match to your motor.
I look forward to hearing how things work out.
syncrodoka
syncrodoka is offline
PostPosted: Tue Jul 05, 2011 4:33 pm    Post subject: Reply with quote
The 5.43 was available in the 4 speed, 5 speed and Syncro tranny from VW. Keep in mind that the ring gear has 38 teeth and the pinion has 7 compared to the 34 Ring and 7 Pinion of a 4.86 so it is not necessarily "weak".
The 5.83 and 6.17 R&P have less teeth on the pinion shaft making them more prone to failure but with hard use/abuse anything is possible.
GoWesty has them, Weddle supplies them, Albins in OZ makes them, Rancho can get them too.
