slo356 Samba Member
Joined: February 18, 2002 Posts: 365 Location: Central Calif Coast
Posted: Tue Jun 14, 2016 10:00 pm Post subject: Re: Anyone have feedback on the RMW stainless exhaust? |
Really a proper design for one of the only true bolt-on performance choices out there for a Vanagon.
Few questions:
1. There have been a few claim that the cat-muffler-tailpipe assembly is not sitting horizontal or in alignment with the line of the chassis, body, bumper etc. Have there been any revisions to hardware to correct this or any other issue since it's introduction.
2. Is the total system lighter in weight than the total stock system? Any figures available?
3. Most people report performance gains…how about improvements in fuel mileage or range?
4. Anyone have experience with this exhaust system fit and a euro frame mounted trailer hitch?
Would like to get in line for a 10C 2.2 WBXer but that looks like a bit of a wait, so I would like to go forward with this header system for a little performance help. _________________ '65 T1 Sedan
'87 T3 Syncro |
jcolbyc Samba Member
Joined: October 31, 2015 Posts: 36 Location: charlotte
Posted: Wed Jun 15, 2016 6:19 am Post subject: Re: Anyone have feedback on the RMW stainless exhaust? |
slo356 wrote: |
Few questions:
Would like to get in line for a 10C 2.2 WBXer but that looks like a bit of a wait, so I would like to go forward with this header system for a little performance help. |
1. Mine sits perfectly parallel to the Van body. No issues at all.
2. Not sure
3. I didn't notice much maybe 1 mpg, it isn't worse for sure.
4. Not sure |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Fri Oct 25, 2019 8:07 am Post subject: Re: Anyone have feedback on the RMW stainless exhaust? |
Any updates on this thread as far as leaks or anymore claims of cracking? Considering pulling the trigger on one of these but honestly reading thru this thread I have my concerns with the reliability of this system. For the price, the problems some have had kind of scare me. Thanks for any updated info good or bad!
Jason |
jberger Samba Member
Posted: Fri Oct 25, 2019 8:52 am Post subject: Re: Anyone have feedback on the RMW stainless exhaust? |
candyman wrote: |
Jason |
I'll bite.. Let it be known that my syncro does more sitting now than driving. I only have maybe 10K miles on this system. No leaks or cracks. It does like to rattle\squeak a bit till the engine is fully warmed but that may be my Camshaft. If I did not have a performance WBX I would not be running this setup. I would stay with a fully stock system. I also truly do not like the sound of it, preferring the throaty burble of the Dansk muffler.
J |
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Fri Oct 25, 2019 11:15 am Post subject: Re: Anyone have feedback on the RMW stainless exhaust? |
Ours now has one 1,800 mile trip on it from Washington to our home in SE Alaska with no issues or loosening as of yet. A few hundred of those miles were on gravel logging roads and quite jarring (one of our mirrors fell off!). All seems to have held together fine. I will be checking it carefully in the spring before heading out.
Sound is a tad throatier then the stock and honestly the 2.1 seems to run nicer - a lot spunkier. It could be the old rusted up setup was causing issues more than the RMW improved anything but I feel it’s been a great upgrade. Having no place to install myself I had a shop install it - they complained it was a huge puzzle and they removed all the tin which I don’t think was necessary but seem to have put it in correctly. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
Posted: Fri Oct 25, 2019 3:37 pm Post subject: Re: Anyone have feedback on the RMW stainless exhaust? |
jberger wrote: |
candyman wrote: |
Jason |
J |
What performance wbx are you running? I have a stock 2.1 with marco injectors and ratio rockers. Probably going to build up a 2.2 this winter. Im trying to get as many hp/performance as I can with this setup. Curious if this exhaust will make a difference or be an expensive headache. This is going in a heavy syncro westy that lives in the mountains |
spunky goat Samba Member
Joined: July 06, 2014 Posts: 9 Location: Minneapolis, MN
Posted: Fri Oct 25, 2019 5:24 pm Post subject: Re: Anyone have feedback on the RMW stainless exhaust? |
I have the RMW exhaust, Marco's injectors, and Marco's ratio rockers. They were all installed on my 1990 Westy at the same time earlier this year. I have about 2000 miles on it w/ no issues of cracking, leaking, or loosening of clamps. I have an otherwise stock 2.1 WBX w/ about 80k miles, stock 4 speed manual, w/ 15" KO2s. The performance after adding the trio of parts was nite and day, I'm very excited I did it. I can now cruise easily 65-70 and still have some power left to accelerate. The biggest difference I noticed is roll on ability when in 2nd or 3rd gear, I don't need to shift nearly as often as the torque at lower RPM's allows a broader use of 2nd and 3d gear across the RPM range.
My fuel economy is pretty steady at 17-18 with mixed city/highway driving.
I enjoy the throatier growl of the exhaust, although I can say that wifey is not as excited about it as I am; the kids noticed the difference in sound but have not complained about it on long trips. |
tjet Samba Member
Posted: Wed Sep 23, 2020 8:47 pm Post subject: Re: Anyone have feedback on the RMW stainless exhaust? |
slo356 wrote: |
Few questions:
I just installed a used RMW/Vanistan s/s exhaust on my syncro last week, and I just completed a 700 mile road trip. To Answer your questions above:
1 - yes, the used exhaust I bought does tilt down slightly toward the passenger side. I figured it got a little tweaked from the shipping (it was all thrown in a box from the seller, and they only removed the primary pipes). I'm going to adjust mine in a few days with my floor jack. I will get before & after pics.
2 - it's noticeably lighter. I would guess it's 2/3rds (maybe half) the weight of a factory system.
3 - It seems like I picked up 1 MPG in my syncro (2.2 RJE with 31" tires & 4.86)
Can't answer the other questions. The exhaust sound is really nice now, especially when you put your foot in it. It has more of a regular / even throb to it. You can tell it's not some mufler / cat-back only deal. It still keeps that cool flat 4 sound though, it just sounds more tuned and throaty. It did wake up the motor above 3200 rpm. To compare, I think the stock system really choked the engine in the mid to high rpm range. I verified that when my factory exhaust broke at the cat inlet last year. I noticed a jump in power along with the noise.
I recommend this exhaust system if you are looking to replace your exhaust. Couple it with the tencent timing advance procedure, and marco 1.25 rockers. Next on the list is marco's injectors. I think all of the above would be awesome on a RJE 2.3 wbx. |
