GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Thu Jul 07, 2011 6:34 am Post subject: Brake Adjusters |
How far can you safely let the brake shoe adjuster screws out? These are new shoes, and I still feel like I need to bring them out more. Can't imagine what I'll have to do as the shoes wear?
_________________ 1957 Beetle
1966 Bus |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Thu Jul 07, 2011 6:51 am Post subject: |
On quick glance, your work so far looks great. So your drums fit over the shoes as adjusted in this photo? If so, I suspect your drums are pretty worn, perhaps beyond the wear limits. You should have the inner diameter measured and if past the wear limit (I don't have my Bentley with the I.D. wear limit spec handy) you may need to invest in better used or new drums. Those adjusters are pretty far out already.
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Thu Jul 07, 2011 6:58 am Post subject: |
thanks, I never did measure the drums inside. I just went by eye lol. They were nice and smooth, no ridges anywhere.
This is my first time working with a bus, so I wasn't sure if that adjustment length was normal or not.
Time to mic out a drum, the specs should be in a "without guesswork" scan on here right? _________________ 1957 Beetle
1966 Bus |
Posted: Thu Jul 07, 2011 7:03 am Post subject: |
From a '65 Without Guesswork. Should be the same for my '67 Drums.
1966 Bus |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Thu Jul 07, 2011 11:54 am Post subject: |
The problem with having a brake drum that is way over the legal limit is that the piston in the wheel cylinder could pop out (the O-ring seal). _________________ Don't worry; be happy. (Baba) |
bugcollections Samba Member
Posted: Thu Jul 07, 2011 12:17 pm Post subject: brakes |
With drums within specs the adjusters should be almost all the way in. I would suspect that your drums are worn beyond specs or there is something funky about those shoes. |
Posted: Thu Jul 07, 2011 1:08 pm Post subject: Re: brakes |
bugcollections wrote: |
Good to know. Shoes came from BusDepot, I believe they are Canadian made?
Hope to measure some spare drums I have at home tonight! _________________ 1957 Beetle
1966 Bus |
bobrk Samba Member
Joined: March 07, 2002 Posts: 288 Location: Beautiful Downtown San Jose
Posted: Thu Jul 07, 2011 1:41 pm Post subject: |
Campy wrote: |
The problem with having a brake drum that is way over the legal limit is that the piston in the wheel cylinder could pop out (the O-ring seal). |
Yes, this is true. Don't ask me how I know. _________________ 1959 Single Cab “Otto”
1500 single port | 1963 small nut/big brake transaxle | CSP Disc Brakes | dual circuit m/c | Deutsch Polster seats |
Posted: Thu Jul 07, 2011 3:06 pm Post subject: |
bobrk wrote: |
Campy wrote: |
Yes, this is true. Don't ask me how I know. |
Did it come completely out? Is it possible to come out enough to not let fluid dump out, but perhaps take in some air? (doubtful) _________________ 1957 Beetle
1966 Bus |
bobrk Samba Member
Posted: Thu Jul 07, 2011 4:11 pm Post subject: |
GLHTurbo wrote: |
bobrk wrote: |
Campy wrote: |
Did it come completely out? Is it possible to come out enough to not let fluid dump out, but perhaps take in some air? (doubtful) |
Mine dumped fluid. It's been a few years, so I'm hazy on the details, but my brakes were gone when I tried to use them. It was a combination of bad star adjuster clickers, worn out drums and a single circuit master cylinder. My buddy advises replacing with a dual MC, and we have all new NOS brake drums ready to go in. _________________ 1959 Single Cab “Otto”
Posted: Sat Jul 09, 2011 1:33 pm Post subject: |
how can I accurately measure my drums? My dial calipers only go to 6"!
I played with a tape measure, but that's not accurate at all. _________________ 1957 Beetle
1966 Bus |
Campy Samba Member
Posted: Sat Jul 09, 2011 1:45 pm Post subject: |
A measuring tape will at least let you know if the drums are worn out. _________________ Don't worry; be happy. (Baba) |
