Cockpit Fan Mounting
Manfreds78bay
Manfreds78bay is offline
PostPosted: Mon Jul 11, 2011 7:39 am    Post subject: Cockpit Fan Mounting Reply with quote
I bought one of these fans for the cockpit. I like the idea of getting some cooling up front when I'm stuck in traffic which happens a lot in Chicago.
I can't figure a good place to mount this. Has anyone had any success?
http://www2.cip1.com/ProductDetails.asp?ProductCode=C27-J13322
Desertbusman
Desertbusman is offline
PostPosted: Mon Jul 11, 2011 11:27 am    Post subject: Reply with quote
Not the same one but it works. Just set it around in different locations to see where you can get worthwhile air flow. I wouldn't put it on top the dash as some people do. It blocks visability and draws hot air from the windshield area.
71 Superbug
71 Westy
Manfreds78bay
PostPosted: Mon Jul 11, 2011 12:29 pm    Post subject: Reply with quote
I'm with you. I don't want it on the dash either. I have a 78 so your location isn't an option. I was thinking maybe behind the driver, hanging from the roof.
By the way, I like your gauge cluster. Is that wood or just painted? How did you fasten it to the dash if it's wood?
GusC2it
GusC2it is offline
PostPosted: Mon Jul 11, 2011 12:59 pm    Post subject: Reply with quote
I mounted mine under the dash, just right of the Em. Bk. handel. I love it! Cool
75 type 2 http://gusc1.tripod.com/1975vwtype2
Old vices have now been upgraded to bad habits.
http://www.facebook.com/pages/VW-Wild-Weekend-2011-St-Pete-Fl/197064760336111
Randy in Maine
Randy in Maine is offline
PostPosted: Mon Jul 11, 2011 1:13 pm    Post subject: Reply with quote
Why not just install some "ambulance fans". They actually fit.
GusC2it
GusC2it is offline
PostPosted: Mon Jul 11, 2011 1:18 pm    Post subject: Reply with quote
I want to hear 'bout that AC.
GusC2it
GusC2it is offline
PostPosted: Mon Jul 11, 2011 1:21 pm    Post subject: Reply with quote
why would they fit any better? Mine fits fine, and it oscillates! Cost 10$.
chabanais
chabanais is offline
PostPosted: Mon Jul 11, 2011 1:25 pm    Post subject: Reply with quote
Because they are designed for a Bus. Don't cost $10 tho!
"I spud therefore I yam."
Manfreds78bay
PostPosted: Mon Jul 11, 2011 1:26 pm    Post subject: Reply with quote
Good idea. I'll try that out.
guanella74
guanella74 is offline
PostPosted: Mon Jul 11, 2011 4:05 pm    Post subject: Reply with quote
OK, I understand it might make more sense logically to mount it in other locations, but you can't beat the strange, giant, wobbly, sort of loud oscillating-fan-on-the-dash AC for impressing people. Check it ouuuuuuut:
- Travis
1974 Westy CampMobile - the OG!
1979 Transporter
1979 Transporter
1977 Transporter
1974 Transporter
1973 Transporter
1971 Westy
beauxb
beauxb is offline
PostPosted: Mon Jul 11, 2011 4:12 pm    Post subject: Reply with quote
I'd like to hear about that instrument cluster as well. wood? and what size/type plywood did you use for your roof?
beauxb
beauxb is offline
PostPosted: Mon Jul 11, 2011 4:13 pm    Post subject: Reply with quote
GusC2it
GusC2it is offline
PostPosted: Mon Jul 11, 2011 4:14 pm    Post subject: Reply with quote
Thats the same kind I have. Cool
whip618
whip618 is offline
PostPosted: Mon Jul 11, 2011 4:33 pm    Post subject: Reply with quote
I mounted my fan on an 8" diameter aluminum plate that way I can move where I need it like on the passenger seat or on the floor and it is very stable.
Phil
Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307
GusC2it
GusC2it is offline
PostPosted: Mon Jul 11, 2011 7:11 pm    Post subject: Reply with quote
Phil
cool idea!
MalibuLX3
MalibuLX3 is offline
PostPosted: Mon Jul 11, 2011 7:52 pm    Post subject: Reply with quote
I've got one clamped on the passengers side window visor. It can be in the way at times, but it pulls in cool air from the passengers vent window. It's just held up there with one of those beefy clothes line clip type things.
1978 Westfalia
GusC2it
GusC2it is offline
PostPosted: Mon Jul 11, 2011 8:11 pm    Post subject: Reply with quote
That reminds me, how do you guys hold your wing windows open in the wind? Question Confused
Desertbusman
PostPosted: Mon Jul 11, 2011 10:15 pm    Post subject: Reply with quote
Thanks Manfred- It's the formica laminate off of a Westy cabinet. It's hiding a lot of chopping up and reconstruction of the console https://www.thesamba.com/vw/gallery/pix/391361.jpg
Gus- It's an evaporative cooler. Pumps out nice cool air when I'm stopped. But totally useless while driving. While driving the windows have to be closed which ends up a lot hotter than with the windows all open.
beauxb- It's just the normal 1/8" birch ply but stained mahogany red then with satin polyurethane. Pics are misleading but it matches the cabinents fairly well.
https://www.thesamba.com/vw/gallery/pix/827396.jpg https://www.thesamba.com/vw/gallery/pix/827397.jpg
https://www.thesamba.com/vw/gallery/pix/590597.jpg
Gus, tighten the adjustment screw. You have to pull off the door panel. the manual covers it.
71 Superbug
71 Westy
GusC2it
GusC2it is offline
PostPosted: Tue Jul 12, 2011 6:27 am    Post subject: Reply with quote
never too old to learn! Tx DBM, will do it!
Manfreds78bay
PostPosted: Tue Jul 12, 2011 8:21 am    Post subject: Reply with quote
The one I have doesn't have a fancy schmancy clip. Looks like a hard mount...but that doesn't mean I can't make one. I just don't have the time as I'm leaving on a trip on Sat or Sun.
