RBEmerson Samba Member
Joined: November 05, 2011 Posts: 2108 Location: SE PA
Posted: Tue Dec 27, 2011 2:57 pm Post subject: |
Too right! I nailed someone cutting across parking slots in a mall lot and had the immense satisfaction of seeing the guy jump and then hunch down after a blast from my manly Stebel Nautilus horn. BWAHAHAHAHAHA! _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Timwhy Samba Member
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Sat Nov 19, 2016 6:55 pm Post subject: Re: Louder and Hornier |
Found the correct fuse/relay panel connector for the dual horn factory wiring on late model Vans.
Was browsing the Samba and noticed a banner ad for RMW so I clicked on it to see "what's new" and found that they have a section featuring hard to find electrical connectors.
This is the connector needed to plug into position L on the back of the late model Panel.
http://www.rockymountainwesty.com/product_p/171971997.htm
The connector accepts the terminals labeled L on this excellent colour coded dual horn wiring diagram......
http://www.haywood-sullivan.com/vanagon/dual_horns_wiring_diagram.gif
Been looking for that little part for a couple years now.
Thanks RMW ! _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
jimf909 Samba Member
Posted: Sun Apr 19, 2020 7:17 pm Post subject: Re: Louder and Hornier |
Going back in the Wayback machine...
Back in 2011 (the start of this thread) there was a conversation (debate?) going on about whether or not one should seal up a horn relay installed next to the horn if one was driving around in Seattle.
Not knowing that this was science, I installed a cheapo relay (not, NOT one of Jay Brown's dishwasher tested relays, just a cheapo with no sealant of any kind) next to the horn and drove around Seattle for awhile.
It turns out that a relay mounted in that spot will last four years in Seattle before it dies of exposure. It still clicked, but the contact had corroded to where it would no longer make contact. The one below was installed Feb, 2016 and crapped out about a month ago. Don't know if it was the rain or Covid-19, I assume it was the rain.
This time it was replaced with a "waterproof" relay (wires are now tucked away and zip-tied). I'll check back in a few years with more science. Also, the Stebel Nautilus horn is still very loud...
"Waterproof" relay
https://www.amazon.com/gp/product/B074QV54V1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Stebel Nautilus horn...
https://www.amazon.com/Stebel-11690019-Nautilus-Compact-Black/dp/B00CMX20H4
Conversation (debate?) starts here...
teej wrote: |
Thanks to this thread, especially crazyvwvanman and thatvwbusguy, we now have a horn that is loud enough and sounds vw.
New stock horn from van cafe
relay and wiring harness kit from thatvwbusguy |
r39o wrote: |
Nice idea, but I would NEVER put a relay out in the elements like that...... |
Zeitgeist 13 wrote: |
Concur ^ Time to wrap that rascal. Someone here came up with a cool idea for a weather resistant electrical box by using some form of tupperware with the clasping tops...or better yet, just relocate the relay under the dash. |
MarkWard wrote: |
It's a horn, not a fuel injection relay. It cost what $10? Use it as is. If it is problematic then deal with a more ideal location. It is not like you would be left stranded.
Good job in my opinion. |
r39o wrote: |
Does it rain a lot in Seattle?
You can cheat some, as those relays are cheap, and just lay a bead of sealant on the bottom.
I'm in Oly, so I share the same rain clouds as Sea. My response was informed by numerous BTDT moments here in the PNW. I really like how clean the wiring is, hence my suggestion to just seal the relay in a box, away from watery goodness. Trust me, no part of the chassis is spared from water intrusion when it's peeing outside. |
r39o wrote: |
Being an electrical engineer and being around our family owned German Car Repair for over a half century, I kinda got a feeling about these things. I have seen poor installations in my time with the result of having problems. Relays and water, generally, do not mix well.
_________________ - Jim
Abscate wrote: |
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Mon Apr 20, 2020 5:02 am Post subject: Re: Louder and Hornier |
I replaced the stock horn years ago and added a relay next to the horns and wrapped it. Lasted for years until the terminals rusted away and my pre-state-inspection test revealed silence, so I replaced the relay and terminals and wrapped (I hope) more thoroughly.
Incidentally, I used a set of Fiamme horns from the FLAPS and the van now sounds like a Cadillac; better than stock but not as loud and urgent as I'd like a horn to be so I might be getting a Stebel, famous in the motorcycle world for scaring the crap out of inattentive drivers.
The van is seldom driven so redoing this is down the list of priorities, but if I need to do it again I'll relocate the relay and add a Stebel. _________________ '87 Westy in Wolfram Grey Metallic |
jlrftype7 Samba Member
Posted: Mon Apr 20, 2020 1:36 pm Post subject: Re: Louder and Hornier |
jimf909 wrote: |
It's always Covid...... You didn't put a mask on that poor relay....
As wet as the Northwest is around Seattle, I think you got lucky with the 4 years of operation[ Chicago is often that wet too it seems].... we start your new timer on the newest Relay set-up NOW.......tick tick tick _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Vanagon Nut Samba Member
Posted: Thu Apr 30, 2020 1:38 pm Post subject: Re: Louder and Hornier |
jimf909 wrote: |
Back in 2011 (the start of this thread) there was a conversation (debate?) going on about whether or not one should seal up a horn relay installed next to the horn if one was driving around in Seattle. |
I haven't been driving around Seattle but have been doing so in similar weather in, near, Vancouver BC.
I "sealed" the horn relay I added on my '81 using dielectric grease. I'll be curious to see how long it lasts. It's been a couple years at least. So far so good. IIRC, I mounted it above the frame rail.
I did the same relay upgrade on my '88 recently and tried to mount the relay as high up as possible at area above the horn itself.
I've used these "sealed" relays before. In particular, I installed one forward of the passenger side tail light. Still works. They appear to be sealed quite well.
Pico sealed relay, socket, pigtail that I've used:
https://picocanada.com/view_product/928-91
Wire gauge is "overkill" for this application but I bet the relay would last a long time.
1988 West DIY 50º ABA
VE7TBN |
Posted: Thu Apr 30, 2020 4:53 pm Post subject: Re: Louder and Hornier |
Vanagon Nut wrote: |
Neil. |
This looks just like the relay I installed. Here's hoping it lasts longer than four years. I'll check back with more science.
Abscate wrote: |
Posted: Thu Apr 30, 2020 5:07 pm Post subject: Re: Louder and Hornier |
jimf909 wrote: |
here's a pic that works. Don't know why Pico website is all hinky right now.
I would guess that the Pico sealed relay in front of tail light (sees some water) has been there for at least 7 years.
VE7TBN |
