bosruten Samba Member
Posted: Fri Oct 07, 2011 8:08 am Post subject: |
You better get the van out of there before it snows... otherwise, you will need to take the tires off and drag it out!
Fantastic pace for just two. Do you drink lots of Red Bull? _________________ '87 Syncro Weekender |
yanos Samba Member
Posted: Fri Oct 07, 2011 11:33 am Post subject: |
You two are doing a fantastic job. I really enjoy following this build.
My Syncro spotted me looking at your thread. Now she is asking questions, "How come you don't treat me like that?" |
bluefirefly Samba Member
Joined: March 16, 2011 Posts: 438 Location: Calgary, Ab
Posted: Fri Oct 07, 2011 9:02 pm Post subject: |
mariusstrom wrote: |
insyncro wrote: |
You are doing a great job.
FYI, without the muffler tin and side tins...an amazing amount of dirt, debris and water are able to get into the engine compartment.
Just something to think about for the long haul.
dylan |
I'd also be worried about the radiant heat from the j-pipe on the overflow tank, since you haven't shielded that.
What's the upside to leaving the exhaust heat shield out? |
Back to your post, I checked this afternoon and there is about 4 to 5 inchs clearance between them so it shouldn't be an issue at all. _________________ 86 Syncro Tintop G60
work in progress ...as always! |
Posted: Fri Oct 07, 2011 9:09 pm Post subject: |
bosruten wrote: |
Fantastic pace for just two. Do you drink lots of Red Bull? |
Come on, I already ask you not to say the S word, bad think will happen...
Thanks a lot, we are working everyday, this is my vacation.
We should be able to get the van out tomorrow with the minimum inside but I still need to check those flashers they broke down just before we took the van apart and I didn't see anything wrong with the wiring.
No Red Bull but the box on vitamine C is almost done....
Like your idea of dragging the van out, might be easier. _________________ 86 Syncro Tintop G60
Posted: Fri Oct 07, 2011 9:22 pm Post subject: |
yanos wrote: |
This is a big job and we are happy it is almost done, cost us a lot , especially time (6 months) but we should be ok for a while, only driving and enjoying it.
It will be strange to get our weekend back, not sure if we'll have time for hiking, we might go snowshoeing in a short time..... _________________ 86 Syncro Tintop G60
Posted: Fri Oct 07, 2011 9:46 pm Post subject: |
Not much done today, spent almost the all day to look for an exhaust donut, didn't find.
So I went to Lowe's and got some stuff to make one.
It works so I'll be able to set my timing right.
I just replaced the oil after the cam break'in and as usual, I unplugged the igniton so the motor doesn't start and I can get some oil pressure.
I did use 10W30 this time and the pressure was about 4.3 bar (about 65psi) only with the starter, I was impressed (again, this is my first car with a real oil pressure gauge...).
We need to work a lot tomorrow, I would like to go for a ride to seat those rings and check if everything is good. _________________ 86 Syncro Tintop G60
Posted: Sat Oct 08, 2011 9:12 pm Post subject: |
More picture today as we put more stuff in.
We might be able to go for a drive tomorrow (I know, I am saying that everyday....) after a last job. I need to find a small 7 wires cable for the gauge.
That gauge is for a front motor vehicle so those sender cables are too short for this application and there is no way I am driving the van without it.
We tried to put windows back on passenger front door, but it didn't work.
So, we are going to order new rubber seal without grove, I hope it will go better.
Window for the sliding door wasn't easy but it is in and I need to cut that piece of flat nylon I got the put under the sliding glass itself.
Here are pics of the van, almost done:
I took a look at the cleareance at the garage door and we should be ok without doing anything, no need to load the van or anything else.
Still a lot to do inside, no sure if we'll have time to finish everything as we planned but as long as we can drive, we'll be happy. _________________ 86 Syncro Tintop G60
GrindGarage Samba Member
Joined: October 14, 2008 Posts: 710 Location: Ocean City, NJ
Posted: Sun Oct 09, 2011 5:19 am Post subject: |
WOW
Looks like she's rdy for some actio _________________ -cliff
91 Vanagon AUTO
97 Single Port EJ22 all smallcar.com |
Posted: Sun Oct 09, 2011 8:27 pm Post subject: |
GrindGarage wrote: |
WOW
Looks like she's rdy for some actio |
Damn right about that.... _________________ 86 Syncro Tintop G60
Posted: Sun Oct 09, 2011 9:34 pm Post subject: |
Today was a happy day.
Almost everything went well, some little screw-up but overal a good day.
Did finish some interior this morning, I didn't want to have wires in my way so we cleaned a lot, almost put back everything in front.
We did plug the new gauge (not with the support but as long as I can see it when I am driving...), good indication of the motor, really happy with it.
Rechecked the timing this morning, I put a mark before on the pulley at 2" as per 10cent.
I was a little of, adjust it and thought about it, I am still away from my mark on the distributor before I took the motor apart:
1st screw up, I put back the distributor shaft like that, I didn't look where, I just put it in.... lucky me it wasn't too far from the right spot. Should I remove the shaft? Yes I should but I am too lazy for that....
I was not sure if the gas gauge was working so early this morning, I played with it and I was able to get "response" plugging a 9V battery to it.
No luck with the temp gauge, but I don't need it.
Put back the cluster, still no gas, that was 5 months ago, not sure.
We went to the gas station, put 30l and got gas now, it works, happy.
On the way, motor "cut" 2 times, like in the past before I repaired the bad wire on the distributor.....
So, we started the "rings break'in", motor seems ok, pull easy, really easy (even being nice on the gas pedal), may be those small tire are helping a lot (205-55/16 instead of 215-85/16).
A lot of noise, of course no motor lid, no carpet, no mats, I want to hear the motor in case something goes wrong, we have tools and a bicycle in case....
Break'in went well too, water temp went once at 93C (back at 90c after), oil temp at 97C (back at 93C after), oil pressure when hot at 4 bars, about 2 bars at idle.
Seems good to me.....
Cold down the motor driving nice and easy, we decided to stop to take a look, everything good, we did open the bleeder screw on the rad, some air but not much and the rad is kinda cold. I checked the pipe after the thermostat housing, it is hot but it seems those stainless still coolant pipes cold down the water before the rad, I remember I read about that from other threads. Of course, there is about 12C today, I am sure that help.
Put the lid back on the motor, much quieter but still hard to speak because of the missing front door windows.
Still a lot of noise front everything, especially under us.
Take some speed, put the trans in neutral, lot of noise but if I push a little on the brake pedal, everything is fine.
2nd screw-up: we got those Audi wheels and I decided to do nothing on them, no mod but they shouldn't fit correctly because of that (sorry for stealing your pics Sodo):
I was planning to use spacers in front with those wheels to correct it.
Of course, guess what, I forgot to put those spacers so the rotor was free to move a little against the rim and the hub..... no damage, but it could have been bad......
Since this morning, I had some problem with the stick, I needed to hold it when I was in 2nd gear, not much travel on 2nd and 4th, needed to be adjusted.
3rd screw-up, checked later one, I did put the last bushing close to the trans on the shift rod the wrong side off the support plate, so I was limiting the travel of the rod....
Anyway, we drove for about 100kms, everything when well, not clutch problem, motor is running smooth, may be rich since the catalytic convert isn't in place, that means no oxygen sensor neither but still run great, idle is a little high but really stable (not idle control box neither), I am really happy.
Motor oil is drained, front diff is drained too (I was thinking if the trans and rear diff had dirty oil..... so we did buy shift gear oil on the way back to rinse it).
I need to put that back tomorrow, need to replace the front stud on front hubs because I don't have any thread coming out of the wheel nuts and after that certainly put back more stuff inside the van.
We'll certainly drive it for a week or two and after that, coolant and good gearbox oil will go in.
Time to go to bed, it has been a long day, but a good day _________________ 86 Syncro Tintop G60
Welchmaster Samba Member
Joined: January 26, 2011 Posts: 445 Location: Milwaukie, OR
Posted: Sun Oct 09, 2011 10:31 pm Post subject: |
_________________ ________________________
90 2wd Orly Blue Multivan weekender. "Van-Duzer"
"Further up, further in!" |
Zero419 Samba Member
Posted: Mon Oct 10, 2011 6:13 am Post subject: |
Awsome job. Are you going to put clamps on those intake hoses? _________________ 1987 Westy Auto Bostig 2.0 Ztec |
Posted: Mon Oct 10, 2011 8:32 pm Post subject: |
Thanks, I am happy with all the time we spent on it. _________________ 86 Syncro Tintop G60
Posted: Mon Oct 10, 2011 8:34 pm Post subject: |
[quote="hero419"]
bluefirefly wrote: |
Awsome job. Are you going to put clamps on those intake hoses? |
I am not sure, it was really hard to put them on so for now it should be ok.
In the future with oil and gas, they might become soft and I might change my mind. _________________ 86 Syncro Tintop G60
Posted: Mon Oct 10, 2011 9:01 pm Post subject: |
Work inside and out the van today, we didn't go for a drive, problem with the front.
I thought I had longer wheel studs for those front wheels but apparently, I don't, they are the same 52mm.
I need to get some, I hope I can get them localy.....
We repaired the heater face plate:
Changed oil again, any tool used to make my life easier:
and put some carpet in place:
We have a rear heater, but there is not control for it, so we add one, easy to do with a control cable that is supposed to be for a truck gas control or something like that:
and the command is just at the left of the driver seat, I didn't find an easier and closest place for it:
This is all for today, taking apart the front to have access to those studs took me some time and I had to clean the trans top to be able to figure out where the oil leak is from.
The front diff got his new oil, regular cheap stuff to rince it.
Of course, I had to take care of the daily driver, oil change and exhaust fix, it should be good for another year....
Tomorrow, need to go back to work, vacation over that means less time to work on the van, too bad, I liked the pace we had last week. _________________ 86 Syncro Tintop G60
carterzest Samba Member
Joined: January 22, 2008 Posts: 3842 Location: Eagle, ID/Sun Valley, ID
Posted: Tue Oct 11, 2011 2:23 am Post subject: |
Mine will be that dull white as well. I love it. I am very motivated by your posts
Keep up the good work!
GET NEW CARPET your van is blushing _________________ Happiness=Portland, Oregon in the rearview mirror! |
Posted: Tue Oct 11, 2011 8:44 pm Post subject: |
carterzest wrote: |
GET NEW CARPET your van is blushing |
Might be the flash on the camera because the van isn't white, I'll try to take a picture with something white beside when I have some time or you need to wait this winter for a picture in the middle of snow.
I thought about carpet, but we spent too much already so the only things we'll be adding is what we already bought or essential items and our carpet aren't that bad after all.
How is your back?
I am pretty sure your "time off" is giving you more ideas about your van... , I hope you are going to get better soon. _________________ 86 Syncro Tintop G60
Posted: Tue Oct 11, 2011 9:06 pm Post subject: |
carterzest wrote: |
How is your back?
I am pretty sure your "time off" is giving you more ideas about your van... , I hope you are going to get better soon. |
Just egging you on! It looks white, but then again, I am medicated. Surgery in the morning for the Hernia.
All I can think about is being able to drive and work on my Syncro again.
Make me proud _________________ Happiness=Portland, Oregon in the rearview mirror! |
Posted: Fri Oct 14, 2011 9:40 pm Post subject: |
A fast post to show some mod, if you want more info about it, ask.
We'll go with 2 speakers per door, a older 6" Pionner, 3 way at the bottom and another 3 way, 3 1/2" in the factory grill:
I put some epoxy on the speaker itself and add a plastic ring with epoxy, it shouldn't move even if it a little heavier than the original.
We bought some rubber sheet to put under both batteries since we painted under, it should pretec for a while.
At the same time, why not add the same rubber on the battery lid....
Another big job (dirty too) was to remove the foam inside the motor lid, that was just gross.
There is a kind of wire netting, not sure why, the glue was still good.
we bought some 3/4" close cell foam, not sure if I'll go the same way to hold it.
We got our new and longer wheel studs this afternoon (70mm, thanks Loogy) and it is in place.
I know, I should have replaced those bearing since it is the second time I am taking them apart, but I think I'll see that next year, I am able to put them in place and there is not play when they are correctly torque.
Cannot hear any noise neither when driving so I think it is not too bad.
Apparently, 70mm is too long, it will stay like that this year, I'll cut it later.
Last picture is for Jeff, see, our van isn't white.
Posted: Sat Oct 15, 2011 8:14 pm Post subject: |
The back of the van is almost done, we need to take advantage of the good weather, it sems it is going to be like that until the end of the month.
A little cold in the morning but no choice.
We bought some aluminium sheet yesterday, I am a little lazy so there are pre-cut, but there is still stuff to do.
the first one for the hatch, here is a shot of both:
and now, we are going for the side one:
No more aluminium for now, we are keeping the rest but there is plan for next year, I think we'll go with wood for the rest of the van, but not 100% sure for now.
A look at the motor lid, the old foam was soak in oil, smelly dirty oil.
Cleaned yesterday and it is under work:
We need to wait for the rest of the interior, I had a grade 8 bolt in bad shape (the one holding the seat belt at the rear bench), the thread in the frame wasn't better and since it is 11mm, I re-thread at 12mm but I need to get a bolt on Monday.
There is still more electrical to do, we add an amplifier for the back, need to be plugged and the radio need to be plugged too and we need to find a place for the new gauge.
A little side track because of a oil leak from the trans, there is another thread for it, hope I'll get answer soon. _________________ 86 Syncro Tintop G60
