prpent Samba Member
Joined: September 30, 2009 Posts: 18 Location: MONTANA
Posted: Sun Jul 17, 2011 8:08 am Post subject: starts fine won't idle |
any starting point would be helpful for my 86 vanagon
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1001 Location: Oakland CA
Posted: Sun Jul 17, 2011 8:35 am Post subject: |
Is your Air Mass Meter harness plugged in? _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
prpent Samba Member
Posted: Sun Jul 17, 2011 8:42 am Post subject: |
I'll check i did undo and replace alot of connections i'll try again thanks |
prpent Samba Member
Posted: Sun Jul 17, 2011 8:56 am Post subject: |
reconnected air flow mass conn twice no go |
Bassyaks Samba Member
Joined: October 06, 2010 Posts: 1137 Location: S.E. Connetitcut
Posted: Sun Jul 17, 2011 10:21 am Post subject: |
look for a large vaccum leak |
prpent Samba Member
Posted: Sun Jul 17, 2011 11:14 am Post subject: |
idle control valve doesn't vibrate but also no electrical power to the switch will try to follow wire and maybe find bad ground?? very difficult to follow. can I create a new source of power off air massflow connection? |
Posted: Sun Jul 17, 2011 11:18 am Post subject: |
the valve may be stock open, creating a large vacumn leak |
prpent Samba Member
Posted: Sun Jul 17, 2011 11:27 am Post subject: |
did you just hit yours when you had problem? sprayed carb cleaner already |
Posted: Sun Jul 17, 2011 7:00 pm Post subject: |
If it were the idle control valve it would keep running and not die.
The problem is more likely a hose that has been knocked off creating a massive air leak. |
prpent Samba Member
Posted: Mon Jul 18, 2011 6:03 am Post subject: |
Ok hoping your right the other options are expensive. |
prpent Samba Member
Posted: Wed Jul 20, 2011 2:25 pm Post subject: |
To Bass and Wild Air leaks checked and some lines replaced better throttle control gained however can attain 1200 to 4000 rpm but can't get idle. I had read in older thread that with the ignition on, idle control valve (not idle control module) should vibrate is this true? Would applying spray lubricant in the control valve be kosher, possible loosening if stuck. Thanks in advance your prior help has gotten me to seeing the light at the end of this tunnel. |
Posted: Wed Jul 20, 2011 3:50 pm Post subject: |
You can spray the idle control valve with carburetor cleaner and it may improve its functioning for a while. Yes it should vibrate if it is working correctly. |
prpent Samba Member
Posted: Wed Jul 20, 2011 4:53 pm Post subject: |
OK that's the answer when 12 volt directly hooked from battery I get nothing no actuation at all Thanks a guy on samba gotem used for $20...Let you know what happens next week. Thank you |
prpent Samba Member
Posted: Sun Jul 24, 2011 1:31 pm Post subject: |
Back to square one I have no live wires zip zero connecting to idle stabilizer/control module that's eight connections. Anybody know what my next step should be on this 88 vanagon motor. Engine will start no problem but will not hold any thing close to idle rpm range. |
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Posted: Sun Jul 24, 2011 10:51 pm Post subject: |
Try another idle stabilisation relay? It's fitted the in front of the right rear light cluster - a double relay size relay. They do die.
MG _________________ T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD |
prpent Samba Member
Posted: Mon Jul 25, 2011 6:31 am Post subject: |
Stabilizer coming Tuesday. Shouldn't I get some current when I test wires that plug into the stabilizer? |
prpent Samba Member
Posted: Tue Jul 26, 2011 12:15 pm Post subject: no power to the idle control module ignition switch on |
therefore no power to idle control valve ie no vibration. have checked all grounds twice. |
prpent Samba Member
Posted: Tue Jul 26, 2011 1:01 pm Post subject: ecu not switching to ground any home mechanic fixes? |
If continuity is not present, check for continuity between terminal No. 85 of fuel pump relay and terminal No. 3 of ECU connector. If continuity is present, circuit is okay but ECU is not switching to ground. Replace ECU and install fuel pump relay.
When I manually ground relay idle control vibrates |
prpent Samba Member
Posted: Tue Jul 26, 2011 4:21 pm Post subject: |
Van Cafe best rebuilt price $229 exchange coming thursday. Will post if fixed or not. |
AnmlMthrM60 Samba Member
Joined: July 10, 2007 Posts: 228 Location: Prescott, AZ
Posted: Thu Sep 01, 2011 4:31 pm Post subject: |
Any updates on this? I'm having a high idle issue. At first it would idle around 3000rpm with the idle control valve hooked up. If I disconnected the valve it would go down to around 1000rpm, then back up to 2100rpm after driving it. Today it was around 2100 either way. Disconnecting the module behind the tail light didn't seem to make a difference either. _________________ Justin
86 Syncro - 2.2L WBX
69 Bug - 1776cc |
