Vinnems Samba Member
Joined: December 23, 2008 Posts: 1183 Location: Simi Valley, CA
Posted: Sun Jul 17, 2011 8:23 pm Post subject: New struts and springs question |
I bought new struts inserts for the front of my Super Beetle and it is TIGHT. I can't get it to move at all. Is this normal? It concerns me because I don't think it is even possible to compress the spring enough to install the bearing stuff on the strut. They are just new Monroe. |
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Sun Jul 17, 2011 9:13 pm Post subject: |
I'm A little confused about your question,, what is too tight? _________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods! |
Posted: Mon Jul 18, 2011 12:02 pm Post subject: |
The strut cartridge protrusion part, I guess you can call it. The bit that moves up a down, returns things to its original position. |
beetlenut Samba Member
Posted: Mon Jul 18, 2011 12:41 pm Post subject: Re: New struts and springs question |
Vinnems wrote: |
Are they Gas shock inserts? _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Mon Jul 18, 2011 12:45 pm Post subject: |
Yeah, I think. These are the struts:
Link |
stasher1 Samba Member
Joined: August 06, 2006 Posts: 296 Location: Lilburn, GA
Posted: Mon Jul 18, 2011 1:44 pm Post subject: |
Do you have a set of spring compressors? |
Posted: Mon Jul 18, 2011 3:15 pm Post subject: |
Stasher, yeah, some Craftsmen, but the thing is, it's so low I would have to completely compress the spring, and even then, I'm not sure if it would fit. I'll take a pic when I get home.
I think I'll but the bearing housing stuff together and bring it to a local shop to worry about. |
flyboat Samba Member
Posted: Mon Jul 18, 2011 6:30 pm Post subject: |
It sounds like you need to completely remove teh strut from the car and replace the inserts on a bench. Use the compressors withthe parts out from under the car. It should work fine. This will allow you to hook up the tops parts properly. I wonder if you should do a "How To" search _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car |
Posted: Tue Jul 19, 2011 9:06 pm Post subject: |
OK, here's what I'm talking about. I don't think, even fully compressed, the top of the strut cartridge would be out enough to attach the bearing housing, and I find it impossible to move these new strut cartridges out. |
Posted: Tue Jul 19, 2011 9:13 pm Post subject: |
Strut cartridges are typically shipped compressed, and some brands may even be held in that position with things like safety wire or clips. These apparently have no safety wire, so have you tried "unscrewing" the shaft by using a slotted screwdriver in the end? |
Posted: Wed Jul 20, 2011 6:20 am Post subject: |
You'll have to find out why those piston rods won't move. They should move up and down fairly easy. After you discover that, you won't have any problems _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
Posted: Mon Jul 25, 2011 1:33 pm Post subject: |
What did you find out about the strut rods. Were they threaded for shipping or something else _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
Posted: Mon Jul 25, 2011 3:04 pm Post subject: |
Haven't tried anything flyboat. I'll definitely check when I get home because I need to put them back on like right now |
Posted: Mon Jul 25, 2011 8:00 pm Post subject: |
Stasher, that was the ticket! I used a screwdriver to twist it about a quarter turn, and they popped right up. Now I probably don't even need a spring compressor. My brother can push the spring down enough for me to cap it. |
Posted: Tue Jul 26, 2011 6:08 am Post subject: |
Glad you figured it out. Get insurance on your brother's teeth. _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
