What's the best way to crimp these panels?
TinCanFab
TinCanFab is offline
PostPosted: Fri Jul 22, 2011 4:39 pm    Post subject: What's the best way to crimp these panels? Reply with quote
I posted this in the Paint/Body forum, but haven't gotten a response. I've looked through many build threads but didn't get a specific answer.
What is the best tool(s)/way to crimp this panels on to my single cab? I've seen the door skin tools, but how well do they work on round edges? I don't want the corners to look like poopoo! Smile
Flat edges are easy and I've got the hammer and dolly techniques down for those. I've never attempted these kind of crimps. Thanks
krusher
krusher is offline
PostPosted: Fri Jul 22, 2011 10:42 pm    Post subject: Reply with quote
I dont know if a door skinning tool can handle that corner, I would probably end up cutting triangles out of it and hammer and dollying it.
I dont think there are any basic home tools that can fold and shrink that edge Confused
Try making a card copy of the panel corner to work out how big to make the cuts if you go that route
(06:31:07) RoachGhia: "i drink dick way too fast"
Saul Koll
Saul Koll is offline
PostPosted: Fri Jul 22, 2011 11:03 pm    Post subject: Reply with quote
Roachdub, do you have any more pics of your bed replacement?
I have the same job looming.
Thanks!
Saul
"I wish you could smell the smell that's coming from the bus"...
Culito
11010101
Culito is offline
PostPosted: Fri Jul 22, 2011 11:38 pm    Post subject: Reply with quote
I saw a thread around here a while back that described this exact procedure....it's around here somewhere, but I haven't found it yet.
Copyright CJ Industries, Inc.
'64 standard
'62 bug
johnnypan wrote:
dref
Banned
dref is offline
PostPosted: Sat Jul 23, 2011 12:01 am    Post subject: Reply with quote
Flat vise grip to get it started, then a block of wood + hammer. It's a real PITA but tis' not so hard once you get it started and have a few or 10 hours to spend....
j.pickens
j.pickens is offline
PostPosted: Sat Jul 23, 2011 8:51 am    Post subject: Reply with quote
I have never done this specific job, but for folding and crimping flat steel, I use these:
Knipex 8603-12 12-inch Plier Wrench
They have smooth jaws, and are basically my favorite tool in the toolbox.
BeaterBarndoor wrote:
Red Fau Veh wrote:
sventinker
sventinker is offline
PostPosted: Sat Jul 23, 2011 10:06 am    Post subject: Reply with quote
I have the same ones but with the toothed jaw and they are the nicest pliers I have ever used. I would imagine they would do that job well without marring the metal
April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
dawerks wrote:
Perfection only comes with delusion.
http://www.oacdp.org/
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Sat Jul 23, 2011 10:29 am    Post subject: Reply with quote
Also my most favorite tool in my tool box. Also works great to crush the vent wing pivot rivet
"no more hacking my sig line"
splitpile
PostPosted: Sat Jul 23, 2011 10:37 am    Post subject: Re: What's the best way to crimp these panels? Reply with quote
I spot weld (could be plug welded or screw down also) the bed sections down along the edges then use my heal dolly and slowly start working the lip. When folded I just continue with the dolly and finish with a couple pieces of 6 inch long 1/3" square tool steel useing the knipex smooth jaw channel locks to get a tight crimp. When I get to the corners I get the mapp gas torch out and slowly heat and hammer the corner lip over.
Everyone has their own method, this just works for me
TinCanFab
PostPosted: Sat Jul 23, 2011 1:07 pm    Post subject: Reply with quote
Thanks!
Saul
http://www.thesamba.com/vw/forum/viewtopic.php?t=420762
Well, no not yet. Check out my build's link. The bed skins were missing when I got this truck.
cru62
cru62 is offline
PostPosted: Sat Jul 23, 2011 3:22 pm    Post subject: Reply with quote
Start folding it over at the corners. If you don't start there you will end up with extra material that has no where to shrink to. The corners actually have too much material when folded over. There is plenty of room on the long flat sides to shrink the metal. Obviously you will want to sneak up on the fold. In other words, don't pound it all down at once. Just in small increments. Sheetmetal pliers work great after the edge of the panel is locked,(i.e. folder past 90 degrees). The pliers make short work of it and then everything is seated with a hammer and dolly. There some great tutorials on YouTube. Search door skins.
http://www.youtube.com/watch?v=PlKnUptnflU&feature=related
This is a start. Lots to look at.
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
double-cab
double-cab is offline
PostPosted: Sat Dec 03, 2011 12:42 am    Post subject: Reply with quote
http://www.eastwood.com/ew-panel-flanger-extra-wide.html spot weld the bed at first and then use that plier around the rest!!
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Sat Dec 03, 2011 10:37 am    Post subject: Reply with quote
1958 custom camper
http://www.thesamba.com/vw/forum/viewtopic.php?t=483656
1957 oval
http://www.thesamba.com/vw/forum/viewtopic.php?t=426468&postdays=0&postorder=asc&start=0
1957 dd kombi
http://www.thesamba.com/vw/forum/viewtopic.php?t=186478&highlight=
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Sat Dec 03, 2011 10:40 am    Post subject: Reply with quote
Eastwood has them
1958 custom camper
1957 oval
1957 dd kombi
