funagon Samba Member
Posted: Mon Jul 25, 2011 9:06 am Post subject: |
When I pry the cylinders off I use a LONG extension on the prybar. It's a three foot long steel pipe that I fit over the end of a foot-long prybar. With that much leverage you can push the cylinder and head apart. If you're using a prybar that's only a foot long, then you just won't get enough leverage. You need a cheater bar! _________________ 1990 GL 7-passenger
2.2 liter WBX |
duderanchero Samba Member
Joined: October 25, 2008 Posts: 166 Location: el paso, tx
Posted: Mon Jul 25, 2011 1:19 pm Post subject: |
i'll bang about with the mallet a few more times (if it doesn't work, it's still fun to do). how do you avoid prying the cylinders along with the heads? that's what mine was doing, but i'll try to rig up a longer lever if needed. boy, they're stuck in there but good. |
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
Posted: Mon Jul 25, 2011 7:04 pm Post subject: |
duderanchero wrote: |
You don't need to AVOID prying the cylinder from the head, the TAB at the top of the cylinder are there for this unique reason.
Get both pistons as close as you can to the head but equal (remove spark plug and feel each piston), now pull that head out a bit until you can clearly see the tab at the top of the cylinder barrel, an inch and a half is safe. Now get that giant prybar in between the tab and the head and PRY HARD...
On over 60 engine ONLY once a sleeve would never budge.
Ben _________________ Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta |
Posted: Mon Jul 25, 2011 7:17 pm Post subject: |
Look at the link I included on page one of this thread. There I have a description and photos of using a pry bar to separate the cylinder from the head. Your prying tool goes between the head and the tab sticking out of the cylinder. As you pry the two apart the head comes further off and the cylinder stays in place. It's hard to get enough levarage unless you have a cheater bar, such as a long piece of pipe, to increase leverage. _________________ 1990 GL 7-passenger
2.2 liter WBX |
Posted: Mon Jul 25, 2011 10:11 pm Post subject: |
ah, i see now. thanks, ben and fun. i didn't grasp that there were tabs. i'll get back to it then.
also, i've searched around the site, and i know that opinions differ on sealants, but--is it bad to use the reinz stuff included in my van cafe kit? i'll get the right stuff and loctite and permatex if i must. in fact, i tried to get them from lowe's tonight, but i guess they're on bar time. |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Mon Jul 25, 2011 10:55 pm Post subject: |
i'll get the right stuff |
Yes please. Like Frank's Red Hot sauce, I put that $%*! on everything. Almost everything. _________________ www.zwerks.ca |
Posted: Tue Jul 26, 2011 2:23 am Post subject: |
mark, i'll try out the right stuff. but i'll stick with melinda's xxx habanero sauce--we've got a good thing going.
for now, i'm still trying to get the head off, and i'm worried i may have pulled it too far. it's less than an inch and a half out, but i can't seem to work it back in. the cylinders are really stuck in there. i have a little prybar, but even it won't fit into the tiny space between the tabs and the head. i'm going to think on it for a little while, or i'll probably go nuts.
here's a terrible picture of the stuck cylinders, and the head that might be pulled too far. i couldn't find a small lens, and i can't see what the picture looks like till i take it. so, i took 20, and this was the best one. seriously.
morymob Samba Member
Posted: Tue Jul 26, 2011 3:58 am Post subject: |
If both are stuck i find moving pistons so they are even in both cyls will give the max room to play with without pulling cyls past rings. My 'tool' is an old large screwdriver with the one edge ground at an angle, this edge goes to the tab on cyl and working back and forth loosens heads(tapping screwdvr with hammer). |
Posted: Tue Jul 26, 2011 3:41 pm Post subject: |
i've got the pistons in mid-stroke. but i'm really worried that i pulled the head off too far, as i can't work it backwards at all. i've got about a two-inch gap now. is there a big noise when the ring pops off? i was working at prying the tabs, but i just kept dragging the whole head along, and didn't realize it was moving til it was too late. |
Posted: Tue Jul 26, 2011 4:04 pm Post subject: |
here's a slightly less blurry picture of the cyls. we apparently do not have the means to take a picture from less than 4 feet away.
am i screwed?
**and also, is that an okay amount of corrosion on the sleeves? i really, really don't want to get into this stuff now if i don't have to. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Tue Jul 26, 2011 8:45 pm Post subject: |
Whoa, that's pretty far/close to the danger zone. One thing is it helps to mindlessly (because you think you're wasting time) pry from the top, then crawl under and pry from the bottom. Get up, pry from the top, and then crawl under again. And so on. You're slowly wiggling it off that way. If you merely pry from the top, you're not as effective and as the cylinder tilts it creates more friction to keep itself from coming off the head.
Dunno if you've pulled the cylinder too far but I'd proceed as if you have not. You have it well out enough to pry. Borrow or buy a $20 2 foot or more pry bar.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Tue Jul 26, 2011 8:57 pm Post subject: |
i did try switching between the top and underside, but they were simply not coming along at all. so, a dozen or so rotations, i finally decided to give it a good, long pry, and i slid the head out. i may have to get a legit pry bar, but what i've got rigged up is fairly torquey. i'll try to attack them tonight. i have somewhat lost hope of getting them loose. |
Posted: Tue Jul 26, 2011 10:57 pm Post subject: |
If you can get a helper, or a lucky confluence of tool length and orientation lets you do this. I was able to apply very hard prying force and then hammer away on the head with a plastic hammer. The vibrations seem to redouble the prying effect and break the ring of grundge loose. It's frustrating but suddenly you'll be grinning from ear to ear.
Posted: Tue Jul 26, 2011 11:46 pm Post subject: |
thanks, doug. i'm trying to picture myself atop this mountain, but i can't help but feel like old sisyphus.
i wish i had ripped out the remains of the water jacket earlier, as i think that would have prevented the cylinders from getting quite so stuck. there were chunks of rubber wedged right against the sleeves.
i'm pretty sure the pistons are out too far, since there's a pretty definite point i cannot push them back past.
my technique now is to pry with one hand, and shake the head vigorously with the other. i'll let everyone know if it works.
i better go get my hands dirty again. |
Posted: Wed Jul 27, 2011 2:03 am Post subject: |
at the last attempt, there came something like a gasp--like a gurgle without the urgle--from the engine side.
i'm going to get a pry bar tomorrow, and i'll see what i can do. it feels like the cylinders are coming out, and so are the pistons. we might just have to take the damn truck.
if i had the $500, i'd happily give it to pete the mechanic to make this all better. |
Posted: Wed Jul 27, 2011 6:26 pm Post subject: |
still getting nowhere. i have a strong feeling i've moved the cylinders too far. is it better to keep knocking things around with the head still on, or can i just pull the whole deal off? because this is seeming like lunacy, to keep futzing around with these tabs when i feel like i'm gonna have to do the piston rings, etc.
focaccia. shitake. |
Posted: Wed Jul 27, 2011 6:32 pm Post subject: |
Pull everything out, you lost way to much time already. It happen ONCE to me, 3 of the 4 sleeve wound's budge, even when out I broke a sleeve that was welded to the head. So when out you will need to heat the head/sleeve a lot. It's just more labor but not much money.
I would put new rings on the pistons.
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Wed Jul 27, 2011 6:34 pm Post subject: |
Don't give up yet. As long as you haven't pulled it out so far you can see the wrist pin and/or the rings, you should be able to push it back on after you've separated the head. I wouldn't bother trying to push it back on right now.
This type of stuff always sucks. Just keep at it.
I thought everything was bigger in Texas, why is your prybar not big enough? _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
Posted: Wed Jul 27, 2011 6:51 pm Post subject: |
i'll keep at it for a little while longer, then i'll yank it out. my prybar is a chisel which fits into a socket which is connected to an extension bar (~2' total). i couldn't find a long prybar that was narrow enough to fit in between the head studs. but mine has pretty much no wobble, and it feels like it's giving me adequate leverage. i think the badly rusted sleeve is the problem.
i can't see the rings yet, but i can feel the piston with my fingers far enough down there. at least i think that's what i'm feeling. |
