jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Sun Jul 24, 2011 1:38 pm Post subject: What to do with the engine out? |
I am preparing to exchange engines between two buses, so I have the opportunity to do all those nice things that are most easily done with the engine(s) out of the vehicle. These are both 2.0-L FI engines. -- one is a keeper, and the other I don't care so much about, but it will end up in a running bus.
I know this has been discussed, but Search is not helping me find it. Perhaps it was an article somewhere... ? If anyone recalls, I'd appreciate a link.
Here's what I have thought of, so far:
- exhaust refurb (I probably need the whole kit and kaboodle)
- clean up tin and get it screwed in right
- replace front seal and O-ring
- replace clutch disc, throwout bearing, and pressure plate
- service CV joints if necessary
- clean engine and engine room, of course
Any other recommendations? _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
bajafreaks Samba Member
Joined: July 17, 2007 Posts: 467 Location: gardnerville, nevada
Posted: Sun Jul 24, 2011 1:45 pm Post subject: |
Pull fuel tank if needed (rust ?) check filler hose, fuel vent line replacement, sender and seal. |
werksberg Samba Member
Joined: February 08, 2005 Posts: 2151 Location: Prescott Valley, AZ
Posted: Sun Jul 24, 2011 5:43 pm Post subject: |
Replace all fuel lines and hose clamps.
While in there, replace the engine compartment ceiling particle / saw dust & glue drooping panels and FG bags that are so call noise deadner and use real PUF foam with alum foil instead. _________________ Werksberg Products....Products that work!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!" |
BusterBrown Samba Member
Joined: December 15, 2009 Posts: 1397 Location: Arizona
Posted: Sun Jul 24, 2011 5:57 pm Post subject: Re: What to do with the engine out? |
jtauxe wrote: |
I know this has been discussed, but Search is not helping me find it. Perhaps it was an article somewhere... ? If anyone recalls, I'd appreciate a link. |
I find that happens to me a lot here. Saw some good information somewhere, and can't find it. The FAQ page below has a lot of info on "Service to perform while the engine's removed". Scroll down to the "Engine" section.
Good luck with the engine swap, and the tasks associated.
http://www.thesamba.com/vw/forum/viewtopic.php?t=165001 _________________ 1978 Sage Green Westfalia (Happy Trails, SOLD)
1977 Transporter
Life is short. Can I have some of yours? |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
SGKent Samba Member
Posted: Sun Jul 24, 2011 9:37 pm Post subject: |
John - depending on the condition of the motor, you probably want to start with a compression test and a leakdown test. Sometimes it is worthwhile to retorque the heads if there is any sign of loosening. If I have the tin off I usually bring the case bolts up to the minimum listed if any have loosened. The tin will often have cracks in it, and this is a good time to tig the cracks and repaint it. All the rubber should be replaced if you can find it. Do the injector seals and manifold boots etc. Check all the FI items for the specs listed and replace anything questionable. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
SuperSamba Samba False Idol
Joined: June 03, 2000 Posts: 1536 Location: The Interwebs
Posted: Mon Jul 25, 2011 7:24 am Post subject: |
This is a very popular topic.
Please read and/or use one of the threads in the Bay Window Bus FAQ. |
