Hubcap Clip Questions
jazzed
jazzed is offline
PostPosted: Mon Jul 25, 2011 11:37 am    Post subject: Hubcap Clip Questions Reply with quote
Just rounded up 5 rims and of the 25 clips, I'm missing 11. Has anyone used the WW clips with success? Should I remove the OG clips and install all new ones, or just install the missing ones? Is the $12 hubcap rivet tool sold by WW worth buying?
GLHTurbo
GLHTurbo is offline
PostPosted: Mon Jul 25, 2011 11:43 am    Post subject: Reply with quote
the tool is a must... I just did a handful on my 14"s. Haven't fit any hubcaps to them yet though to report back.
1957 Beetle
1966 Bus
justcruzin
justcruzin is offline
PostPosted: Mon Jul 25, 2011 12:15 pm    Post subject: Reply with quote
I was only missing 2 of my clips and I used the WW one's to replace them. The only thing I didn't like is it seemed like the studs that came with them were pretty small. We did manage to get them mushroomed out good enough to hold the clip on, but I was still not to happy with the size of them. We didn't have any special tools to install them. Just tried to use a hammer and something on the back side to hold the stud in place, like a socket.
I can't say for sure how they are holding up, there were only 2. I left the other original clips on, so for all I know they are doing the holding! I do think with the right tools though, one could get those little studs to mushroom out good. Just wish they would make them a bit bigger.
Kim
Sacramento, CA
1964 Split Window Bus
1966 Beetle Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=472933
1969 Delivery Van= http://www.thesamba.com/vw/forum/viewtopic.php?t=566282
1970 Westy Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=479538
1971 Squareback Build Thread = http://www.thesamba.com/vw/forum/viewtopic.php?p=6652459#6652459
1970 Single Cab, Samson = http://www.thesamba.com/vw/forum/viewtopic.php?p=8022609#8022609
Dave24
Samba Hack Purist
Dave24 is offline
PostPosted: Mon Jul 25, 2011 12:53 pm    Post subject: Reply with quote
On my 5 rims, there were only 8-10 clips left. I removed them, and replaced them w/the WW clips and rivits. Been on the bus for 5+ years, no issues. IMO, they are just fine... nice and tight. And YES, buy the tool.
dreadnotmusic
dreadnotmusic is offline
PostPosted: Mon Jul 25, 2011 1:50 pm    Post subject: Reply with quote
The WW rivets and clips worked great. I made my own tool though:
66 Riviera
sventinker
sventinker is offline
PostPosted: Mon Jul 25, 2011 2:17 pm    Post subject: Reply with quote
does anyone know the hole size for the rivet? mine were drilled out very poorly and need to be welded shut and redrilled. should I drill it to fit the smaller WW rivet? or go factory size?
April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
dawerks wrote:
Perfection only comes with delusion.
http://www.oacdp.org/
cru62
cru62 is offline
PostPosted: Mon Jul 25, 2011 4:57 pm    Post subject: Reply with quote
I found the rivets to be smaller than the original holes as well. I don't know why they would send those, because the originals seems to fit pretty tightly in the hole. I will try to get the correct size rivets.
The biggest problem I had was that the clip touches the rim where the cap fits. So it is almost impossible to paint the rim decently with the clips installed. I also have a set of the chinese Huff clips which are just as bad. If they are held up to a good original clip the profile is way off. Sad
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
KarmannBob
KarmannBob is offline
PostPosted: Mon Jul 25, 2011 6:24 pm    Post subject: Reply with quote
I had no problem with the WW clips, rivets, and tool. I think the original clips are made of a tougher spring steel though. To avoid enlarging the rivet holes I carefully ground off the original rivet heads and then popped the remains through with a punch rather than drilling. I also painted the clips prior to installing to delay eventual rust.
'71 Ghia
'65 single cab
'57 pg/sg standard
VolksFire
VolksFire is offline
PostPosted: Mon Jul 25, 2011 6:50 pm    Post subject: Reply with quote
All the repop clips ive used were shit. nothing like wasting all day drilling out broken rivets, then rivet in new ones only to have all 5 snap immediately upon hubcap installation. so pissed Mad Confused
i prefer to use og clips. ill drill out good ones from junk rims. i just pop rivet mine in with a rivet gun. before negative comments, theyre still holding 3 years later with daily use.
Jahnai Pearson - VW Restoration Technician
60 Double Door Panel
63 Double Cab
63 Single Cab
67 SO42 Westfalia
73 Thing
76 Kombi
82 Westfalia Deluxe
82 Quantum Coupe
85 Quantum Sedan
85 Quantum Syncro Wagon
96 Golf GL
sub-hatchtim
sub-hatchtim is offline
PostPosted: Mon Jul 25, 2011 10:30 pm    Post subject: Reply with quote
i used ww clips on all 5 of my rims and i also purchased the tool i dont remember it being all that expensive and it works well
im happy with them
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
camerod
Volksfab
camerod is offline
PostPosted: Mon Jul 25, 2011 11:52 pm    Post subject: Reply with quote
The new WW clips are very nice, not to be confused with the old shorty import type that break the first time you pop on your hubcap.
I use an air hammer W/ punch bit to pop out the old pins and the hammer head bit to mushroom the new WW pins using the WW tool as the back stop. takes less than 5min. per wheel start to finish. I usually just replace all of the clips, chances are those old clips are waiting to break the second you slap your caps on.
It helps to dial your air hammer to it's lowest setting( if it is adjustable like the snap-on unit)
DON'T SHIT WHERE YOU EAT!
bushaus
bushaus is offline
PostPosted: Mon Jul 25, 2011 11:57 pm    Post subject: Reply with quote
I used the clips that are sold by Ronnie at Bustoration (samba: splitpile) and made my own tool using a ground-down tool-steel punch and a bench vise. Caps have been off and on lots, no broken clips yet. Very Happy
1967 13 window walkthru bus
1965 Karmann Kabriolett beetle
hitest wrote:
Even if completed, the abarth's gonna belch spluey all over your Eriba.
fizzbang
fizzbang is offline
PostPosted: Tue Jul 26, 2011 12:10 am    Post subject: Reply with quote
I installed the WW clips (about 12 over 4 rims) and they are all still on there and tight after some hubcap pulls dialing in my brakes and other things.
The tool made it very easy for my first time and they are all very tight. Highly recommend the tool and a big vise on a cement floor. The clips seem a little smaller than the hole, but when your beating them it's amazing how they spread and tighten themselves in there.
I would paint them before you install or see if they would bend a hair off the rim. They do seem to touch the rim and you'll miss that little spot like cru62 said.
Riff Raff
Shivering Sambian
Riff Raff is offline
PostPosted: Tue Jul 26, 2011 6:52 am    Post subject: Reply with quote
A fairly comprehensive comparison of German and Brazillian clips:
http://nutsusers.proboards.com/index.cgi?board=virtualgarage&action=display&thread=377
The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin
PostPosted: Tue Jul 26, 2011 8:27 am    Post subject: Reply with quote
And here's the thread from the Bus FAQ with lots of info:
http://www.thesamba.com/vw/forum/viewtopic.php?t=167948
BeeDubyaBugz Premium Member
BeeDubyaBugz is offline
PostPosted: Tue Jul 26, 2011 2:23 pm    Post subject: Reply with quote
I just did all my rims with the newer version of the WW hubcap clips. I have had no trouble with them. And we have had the hubcaps off a few times for adjustments of the brakes. Not one problem. They have been on the bus about a year or so. The tool makes the job much easier. The rivets were a hair small but they do tighten up ok.
ALL LOST IN MARSHALL FIRE 12-30-21
1964 21 window
1963 bug sedan
1963 ragtop bug
1965 Bug convertible
Fire Survivors:
1969 bug autostick
1974 sun bug
PostPosted: Tue Jul 26, 2011 5:03 pm    Post subject: Reply with quote
I measured one of my loose original wheels that has no clips or rivets and I measured a little over 5mm.
I have some old clips & rivets I got from OEVeeDub:
The rivets are 4.5mm.
The hole in the clip is 5mm.
I have used these and they worked fine and were tight after I hammered them in.
I think most of the ones on my 15-Window are these clips and rivets.
I have some newer clips & rivets I got from Bill & Steve's at an OCTO show - the rivets and the hole in the clip are both 5mm.
I don't know what WW sells but 5mm would be optimal.
EMPIImp69
EMPIImp69 is offline
PostPosted: Tue May 29, 2012 7:58 am    Post subject: Reply with quote
Anyone ever weld the rivet to the rim on the backside? thanks
1963 Ragtop Bug
chrisflstf
chrisflstf is offline
PostPosted: Tue May 29, 2012 9:33 am    Post subject: Reply with quote
You can also use a small flathead screw/nut to secure them also. Makes replacement pretty easy
RobzKombi
RobzKombi is offline
PostPosted: Tue May 29, 2012 10:05 am    Post subject: Reply with quote
Yup! that's how i've been doing it as well.
