geoffwg Samba Member
bajamike560 Samba Member
Joined: December 11, 2009 Posts: 544 Location: Vancouver WA
Posted: Tue Feb 28, 2012 3:27 pm Post subject: |
Going for the trophy bug look, I like it.
Mike _________________ Jackpot motorsports |
TJFIG Samba Member
Joined: January 11, 2012 Posts: 3 Location: Yucaipa, CA
Posted: Thu Mar 01, 2012 4:34 am Post subject: |
She's Lookin good there Mr. Geoff |
Posted: Mon Mar 05, 2012 12:23 pm Post subject: |
thanks guys
i ordered up some heims and pulled my 3x3's down so just waitin for parts. then a trip too buy some more tubing.
then i found a bunch of tranny stuff up in the attic while i was searchin for my 3x3's
it was built by wright
it was a mid engine trans that was used in a pretty heavy car. i belive the engine was a turbo 2180.. and when i got it third gear was stripped.
i pulled the super diff and hardend shift fork out off it and ran it in my car
_________________ speed cost money.... how fast do you want to go?
http://www.thesamba.com/vw/forum/viewtopic.php?t=474256 |
TJFIG Samba Member
Posted: Tue Mar 20, 2012 3:48 am Post subject: |
Hell yeah, and I'll be home soon to see it in person! |
Posted: Mon Mar 26, 2012 9:57 pm Post subject: |
ive been working at adjusting out my bump steer.
and also thinking about my shock set up.
single 2.0 resie
or 2.0 coil with a secondary by pass or smoothie
im also thinking about relocating my bottom mounts on the arms so i can run a longer shock....
Posted: Sat Jun 02, 2012 10:51 am Post subject: |
alrighty its been a while,
ive been busy so here are the updates
finished my steering
it looks like i have the majority of my bump steer adjusted out,
fire wall almost finished, im making the remaining panels removable.
well hot dog! i got some coil overs
FOA 2.0 12 inch stroke
springs 200 tender and 300 main
then.....
Posted: Sat Jun 02, 2012 1:29 pm Post subject: |
Looking great.
Do you think there is enough spring rate? I have been doing a little looking around (I am in the market for coilovers myself) and some guys run a bit heavier rate, but mostly race cars.
Posted: Tue Jun 05, 2012 10:03 am Post subject: |
thanks !
i was having the same problem trying to figure out spring rates,
it seems like the the 200 is a little soft but since it is 10 inches while the 300 spring is 14 inches, it has a good amount of droop and when the main spring kicks in it seems plenty stiff, i piled almost 400 pounds right on the front end and tried to compress the coils by jumping up and down, but i never got the arms to be level.
i know with the bug fully loaded it will be a different.
but worse case senerio i will go to a 350 or 400 main but i really dont think i will need to change. im estimating the car will weigh 2300 to 2500 when finished. _________________ speed cost money.... how fast do you want to go?
Posted: Tue Jun 05, 2012 2:04 pm Post subject: |
I do see the 350lb spring quite often talked about for primary.
There was a guy selling springs CHEAP on race dezert dot com a while back, I did not buy any, not sure what I need yet.
And I am in a whole new ballpark with going "A" arm front. Whole new adventure now.
Keep us posted on progress.
Posted: Wed Jun 06, 2012 9:34 am Post subject: |
i will do that!
as soon as i get my jeep to pass smog i will be back in the garage for some bug time.
ive failed smog three times soo far
do you have a build thread for your a arm car??? _________________ speed cost money.... how fast do you want to go?
Posted: Wed Jun 06, 2012 2:30 pm Post subject: |
3 TIMES??? They need a new sniffer...
No build thread yet, working on gathering parts and supplies before I start the thread. My goal is/was 2 years from this spring to be driving it. Could be close I think.
Posted: Tue Aug 07, 2012 10:20 pm Post subject: |
bump stops and limit straps
full comp
im thinking i will run a support up too bumper
like soo...
and the bumper
im going to run two lights right below the bumper with a skid plate up to the bottom of the lights.... i will have to put up pics i would have trouble following that
and a rare sighting of sasquatch.... _________________ speed cost money.... how fast do you want to go?
Posted: Wed Aug 08, 2012 1:32 am Post subject: |
Sasquatch, that is to funny... I think you are to far South...
Judging from the photos, the up stop tube with mount is what 3" or so? and the mock bar going up to bumper is close to stop/angle of arm hitting it so close to a straight line?
I might think about putting another piece from the side down to the stop. 1, how long the tube is. 2 photos do no justice on distance, area or dimension.
I am not nit picking it apart just giving untrained advice.
Overall car looks really BAD A$$. Just keep the momentum going, even if it is slow. (Ya I have room to talk lol)
thext94 Samba Member
Joined: April 11, 2010 Posts: 1003 Location: Manhattan Beach, CA
Posted: Wed Aug 08, 2012 11:34 am Post subject: |
This thing is looking awesome! |
Posted: Wed Aug 08, 2012 9:05 pm Post subject: |
thanks guys!
i think sasquatch is a little far south! im right at home lol
alright as for the bump stop mounts
the whole lenght of the bump stop/mount is close to 5 1/2 inches
i am thinking i will run a tube from the side of the shock tower down to the mount as well as up to the bumper, triangulation is good!
a little bit of work a day will add up to something eventually, these last two days i made mounts for my fiberglass and got it finished up. ill post up some pics when i finish my bumper.
i want to finish my front end up by the 24th
mike, any closer to starting your car? _________________ speed cost money.... how fast do you want to go?
Posted: Thu Aug 09, 2012 5:27 am Post subject: |
Ha ha, yes and no...
I might have a buyer for my race car, still talking things out.
I spent $1500.00 on a lot buy of VW stuff I could not pass up, so THAT puts me that much $$$ behind on the build. But I should be money up if I sell for fair market value...
