cdennisg Samba Member
Joined: November 02, 2004 Posts: 20233 Location: Sandpoint, ID
Posted: Wed Apr 25, 2012 8:40 pm Post subject: |
OK, 5.5mm, picky picky. _________________ nothing |
Desertbusman Samba Member
Posted: Wed Apr 25, 2012 9:23 pm Post subject: |
cdennisg wrote: |
picky picky. |
It justs makes 3/16" just that much smaller than it should be. I still use the 5.5mm cr@p hose but would probably go with the too large 1/4" than the too small 3/16". Either that or flip a coin and go with the winner since they are both losers.
webwalker wrote: |
The only 5.5ID I've seen for OEM automotive are for the Acura NSX, and that's pre-cut.
What can you tell us about this, M? From a quick check it seems to be 7 mm which is a lot larger and sloppier than 1/4".
We need 5.5 mm and not 3/16", 1/4", or 7 mm. _________________ 71 Superbug
71 Westy |
Posted: Wed Apr 25, 2012 9:40 pm Post subject: |
Desertbusman wrote: |
cdennisg wrote: |
picky picky. |
Jim Bear wrote: |
I did the math: 3/16" is .74mm smaller than 5.5mm and 1/4" is .85 larger. |
This is from the other recent thread. I have a hard time believing that .74mm is going to cause any issues with using the 3/16" fuel line on a 5.5.mm fuel fitting. I would have to expect that any issue that may arise from this would be far outweighed by the issues that come from using non-compatible German line.
I am considering changing all of my brass fuel taps to standard sizes to eliminate this issue altogether. Sounds like fun. _________________ nothing |
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
Posted: Wed Apr 25, 2012 10:45 pm Post subject: |
I have this on my Split-Window Bus, O'Reillys had a roll the first time I went there. I went to get more and they didn't have any and had no idea what I was talking about.
There are no fitment problems:
It slips on with no effort though (loose) over my upright engine's original smooth fittings so you do have to clamp it down more than Continental lines. _________________ How to Post Photos
Posted: Wed Apr 25, 2012 11:33 pm Post subject: |
cdennisg wrote: |
I am considering changing all of my brass fuel taps to standard sizes to eliminate this issue altogether. Sounds like fun. |
I'm considering it also. Tank outlet, steel line around the fan shroud, fuel pump and carb(s). Not really fun. _________________ 71 Superbug
71 Westy |
Jim Bear Samba Member
Joined: March 25, 2006 Posts: 670 Location: Watkinsville, GA
Posted: Tue May 01, 2012 8:12 pm Post subject: 5.6mm 30r9 fuel line... |
5.6mm 30r9 fuel line available in the UK...
http://www.advancedfluidsolutions.co.uk/56mm-saej30-r9-rubber-fuel-injection-hose-627-p.asp
I Emailed for a quote for 5 meters shipped. _________________ "You're either on the bus, or you're off the bus." ~kk
'85 Vanagon Westy - George In the Stable 2020-?/'74 Weekender - Ophelia In the Stable 2007- ?/'69 Beetle Convertible - SOLD 2017-2020/'67 Beetle - September SOLD 2013-2016 /'67 SO42 Westy - Sage SOLD 1996-2001 /'69 Transporter - Baby Blue SOLD 1995-1995/'72 Westy - Nelly - SOLD 1990-1995--STOP FRACKING |
Posted: Tue May 01, 2012 8:33 pm Post subject: |
Interesting. _________________ nothing |
drozdenko Samba Member
Posted: Wed May 02, 2012 3:39 am Post subject: hose from FI pump to filter |
has anyone found a source for the ~1/2" line between the fuel pump and filter? The one i removed was 1/2" but I don't think it was rated for the higher pressure. I checked all around and the largest I found was 3/8"
That's the last section I need to replace before starting the engine install.
Thanks. _________________ '79 Westy 2.0L "Hiltrude"
‘74 Super Beetle Rallye Yellow
'00 Jetta TDI
'01 WE Jetta 1.8T (Sold)
'02 Passat GLS 1.8T (Sold)
'96 Jetta Trek (Sold)
'88 Gti-16V (Sold) |
Posted: Wed May 02, 2012 4:27 am Post subject: Re: 5.6mm 30r9 fuel line... |
Any feedback on this? It looks like for 5 meters shipped it is approx $53.00. Not too bad for the correct fitting 30r9. _________________ "You're either on the bus, or you're off the bus." ~kk
aryue Samba Member
Joined: January 16, 2006 Posts: 1027 Location: Austin, TX
Posted: Wed May 02, 2012 4:59 am Post subject: Re: 5.6mm 30r9 fuel line... |
Jim Bear wrote: |
Any feedback on this? It looks like for 5 meters shipped it is approx $53.00. Not too bad for the correct fitting 30r9. |
I'vw bought 3 meters of 5.6mm 30r9 fuel line from AFS in the UK. They take paypal and the fuel line arrived in about a week.
Compared to OEM German 5.5mm fuel line, 30r9 has a thicker wall and is multi-fuel rated.
- Andrew in Austin, TX - _________________ OldandSlow - but still chuggin.
http://www.ph.utexas.edu/~yue/VW/VWBus.html |
Posted: Wed May 02, 2012 8:52 am Post subject: awesome! |
aryue wrote: |
Jim Bear wrote: |
- Andrew in Austin, TX - |
Does it have the liner in it and does it say 30r9 on the outside? _________________ "You're either on the bus, or you're off the bus." ~kk
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Wed May 02, 2012 10:05 am Post subject: Re: 5.6mm 30r9 fuel line... |
aryue wrote: |
How much including shipping? _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed May 02, 2012 10:23 am Post subject: |
Just recieved this from AFS, $32.98 for 3m of 3/16" (4.8mm) to my door, no liner visible and very stiff, time will tell
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
aryue Samba Member
Posted: Wed May 02, 2012 11:26 am Post subject: Re: 5.6mm 30r9 fuel line... |
BUSBOSS wrote: |
aryue wrote: |
How much including shipping? |
I believe it was about $34 USD shipped for 3 meters of the 5.6mm fuel line back in late February. No, it isn't lined and its much stiffer than OEM.
Busdaddy, why did you buy the 4.8mm hose instead of the 5.6mm ID?
Posted: Wed May 02, 2012 11:50 am Post subject: |
busdaddy wrote: |
Just recieved this from AFS, $32.98 for 3m of 3/16" (4.8mm) to my door, no liner visible and very stiff, time will tell |
Got to be good if it came via the Royal Mail. |
Posted: Wed May 02, 2012 12:11 pm Post subject: Re: 5.6mm 30r9 fuel line... |
BUSBOSS wrote: |
Jim Bear wrote: |
Posted: Wed May 02, 2012 12:12 pm Post subject: |
busdaddy wrote: |
Why 4.8 instead of 5.6? _________________ "You're either on the bus, or you're off the bus." ~kk
Posted: Wed May 02, 2012 12:30 pm Post subject: |
Another project, not VW _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed May 02, 2012 12:45 pm Post subject: |
busdaddy wrote: |
Another project, not VW |
Sounds to be a heathen act. |
Posted: Wed May 02, 2012 1:03 pm Post subject: |
Some of us enjoy a little watercooled Sushi occasionally, VROOOOOMMMMMM!
Слава Україні! |
