DannoT Samba Member
Joined: September 15, 2007 Posts: 249 Location: Up where the air is thin
Posted: Wed Jul 27, 2011 8:23 pm Post subject: Lost nut in sump I screwed up |
Ok so I was installing a new empi 1.5qt deep sump on my engine today and everything was going smoothly untill it came time to bolt the oil screen plate back on to the new longer stud, when I slipped and lost the 10mm lock nut in to the depths of my engines sump . I fished around in there with a magnet for about an hour without success and Im pretty sure having the nut in there cant be good for the engine and at any point Im ocd when it comes to my engines so I have to get it out. Does any body have any suggestions on how to get past the oil pick up tube in to the sump that doesnt totally require tairring apart the engine? As I said before i screwed up on this one and any help would be appreciated. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jul 27, 2011 9:02 pm Post subject: |
While not ideal, as long as you have the oil strainer in place that nut will just drop down into the sump later and cause no problem. _________________ In Stereo, Where Available! |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3444 Location: San Diego
Posted: Wed Jul 27, 2011 9:07 pm Post subject: |
Did U make sure it didnt fall on the floor instead? |
DannoT Samba Member
Posted: Wed Jul 27, 2011 9:21 pm Post subject: |
Im positive the little bugger got lost in the sump, I thought i had gotten it threaded on to the stud and when i let go of it, it just fell right in and sounded like it bounced once or twice inside the sump. |
mr white Samba Member
Joined: October 02, 2005 Posts: 1193 Location: beautiful Oregon & Mohave County, AZ
Posted: Wed Jul 27, 2011 10:34 pm Post subject: |
I agree with Eric and Barb,you should- most likely will have no issues. Sleep well. |
Stuart Maingot Samba Member
Joined: December 13, 2009 Posts: 240 Location: Trinidad West Indies
Posted: Thu Jul 28, 2011 12:13 pm Post subject: |
Sometimes this can be a blessing on a new rebuild when yuh accidentally drop a 13 mm gen stand nut down the oil fill and decide to tear everything apart to get it and find you forgot to reinstall the oil pick up tube that was removed after yuh found it was fitting too slack. There is a god out there!! |
