Front disc brake conversion
Page: Previous  1, 2, 3 ... 45, 46, 47, 48  Next
d___dles
d___dles is offline
PostPosted: Sat Nov 06, 2021 8:00 am    Post subject: Re: Front disc brake conversion Reply with quote
johny__utah wrote:
Type E Kit.. easy install, zero issues! Save yourself some time and buy his 67 dual master cylinder kit. Thanks again Brian.
How much did the kit end up costing after you bought all the other parts?
1967 Riveria Camper
Braukuche
Braukuche is offline
PostPosted: Sat Nov 06, 2021 8:05 am    Post subject: Re: Front disc brake conversion Reply with quote
pacifcoflyr wrote:
rustednuggs wrote:
I ended up going with the EMPI disc brake kit for the bus, keeping the stock 14s even.
Rustednuggs
Is the quality of the parts really a huge downfall? I would hate to buy that kit and be bummed it was made poorly.
We have the EMPI kit on my 60 double cab and my sons 65 standard and no issues to date. Easy to install with stock wheels. We did upgrade to a German dual master and used the CSP conversion kit which added to the costs.No issues to date.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
johny__utah
johny__utah is offline
PostPosted: Mon Nov 29, 2021 9:53 am    Post subject: Re: Front disc brake conversion Reply with quote
Replying too d__dles. About $210. All parts needed were ordered from rockauto.com
1956 L31
1961 L346 L347
1963 L380 L289
d___dles
d___dles is offline
PostPosted: Mon Nov 29, 2021 3:19 pm    Post subject: Re: Front disc brake conversion Reply with quote
thank you!
1967 Riveria Camper
mykillcykill
mykillcykill is offline
PostPosted: Mon Nov 29, 2021 8:58 pm    Post subject: Re: Front disc brake conversion Reply with quote
Just installed my second CSP kit. Once again a really straightforward install. I'm a ways away from road testing though.
Birdmanhere
Birdmanhere is offline
PostPosted: Tue May 17, 2022 5:08 am    Post subject: Re: Front disc brake conversion Reply with quote
I also went with the Type-E Motorsports kit.
It is simple and well made, but most importantly works fantastic.
I run 215/75 BFG all terrains, I still have had no rubbing with the slight increase in offset that comes along with the kit.
I also had a friend get me the wear parts for cost at his shop.
Brian was great to deal with with any questions I had.
Would not hesitate to buy this kit again, and wish I had done it sooner.
66 Bus
71 Bug
tdubz510
tdubz510 is offline
PostPosted: Wed Oct 05, 2022 11:16 am    Post subject: Re: Front disc brake conversion Reply with quote
Arrow Big fan of this Type E kit's concept and GM part usage. Yours looks like a pre-64 bus.. I have a stock 61..how did you fit his 64-67 Type E kit? brian hasn't responded to a couple emails, yet.. Do you have a narrowed beam or stock beam? I'd love to get a Type E Disk Brake kit, but I need to change spindles and some other things, right? TIAA
demon1018
demon1018 is offline
PostPosted: Fri Mar 17, 2023 2:22 am    Post subject: Re: Front disc brake conversion Reply with quote
Just finished installing these brakes on a 63 bus with our hydraulic suspension and rack and pinion steering freaking amazing! I’ve installed them all and this is by far the best way to go hands down. The instructions and parts list make it go incredibly smooth as well. We’ll be recommending these for everyone. The idea of using parts designed to be daily driven on a car heavier than a bus is brilliant. You can get better brakes than this at any cost
tdubz510
tdubz510 is offline
PostPosted: Fri Mar 17, 2023 1:44 pm    Post subject: Re: Front disc brake conversion Reply with quote
Nice! That rack and pinion looks and sounds amazing. Does Demon make a full beam with R&P built in, or was it pieced together?
FeveredMind
FeveredMind is offline
PostPosted: Fri Mar 17, 2023 2:39 pm    Post subject: Re: Front disc brake conversion Reply with quote
I got a Type E Motorsports kit for Christmas from my family. Cant wait to install it.
I would love to know what rack they used for this set up.
New to split window busses but learning new things everyday. This forum is a wealth of knowledge. Thank you everyone for sharing.
Mitch Case Premium Member
Mitch Case is offline
PostPosted: Mon Sep 18, 2023 5:20 pm    Post subject: Re: Front disc brake conversion Reply with quote
I just had two sets put on my buses. I’m ecstatic how they turned out. One was a 65 the other a 66. Clean and simple everything I needed came with the kit. Obviously i had to buy the required rotors and calipers.
I’d recommend them to anyone.
Check out a few of my projects.
61 mango
http://www.thesamba.com/vw/forum/viewtopic.php?t=269607&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=281851&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=428154
http://www.thesamba.com/vw/forum/viewtopic.php?t=429578
http://www.thesamba.com/vw/forum/viewtopic.php?t=439644&highlight=
View user's profile Send private message Send e-mail Facebook Classifieds Feedback
Braukuche
PostPosted: Tue Sep 19, 2023 9:08 am    Post subject: Re: Front disc brake conversion Reply with quote
I had the shitty SACO kit on my ‘59 and after five years or so of dealing with warped rotors, rotors coming apart, pulsating pedal I junked it and bought the EMPI kit. I bought quality wheel bearings and used my CSP dual master and the bus brakes like a dream.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
turkis-deluxe
Samba Security
turkis-deluxe is offline
PostPosted: Tue Sep 19, 2023 4:36 pm    Post subject: Re: Front disc brake conversion Reply with quote
I'm going to buy a few EMPI sets soon for my earlier buses since Type E is only later. Can you clarify the bearing concerns as far as what it comes with versus the quality bearings you bought?
Chuey
Chuey is offline
PostPosted: Thu Sep 21, 2023 9:49 pm    Post subject: Re: Front disc brake conversion Reply with quote
For users of AC brand discs, do your brakes take a lot more effort to stop than seems reasonable?
My new set of these brakes, with new shoes and cylinders in the rear brakes feels a bit "wooden". We did set the push rod a bit looser and that helped a tiny bit.
I'm waiting for that wonderful stopping power everyone writes about. It's not here yet. The pedal seems to take too much effort to stop and it's not like applying a lot of pressure on the pedal makes it stop brilliantly.
Chuey
Braukuche
PostPosted: Fri Sep 22, 2023 5:00 pm    Post subject: Re: Front disc brake conversion Reply with quote
It comes with Chinese bearings which most stuff I read is no bueno. I bought German and Japanese ones instead at FLAPS.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
rusty ducktape
rusty ducktape is offline
PostPosted: Wed Nov 01, 2023 8:26 am    Post subject: Re: Front disc brake conversion Reply with quote
I just completed the Type E Motorsports kit on the font of my bus couldn’t be happier with the fit and finish on this kit! No one off rotors ,calipers or pads all off the shelf GM parts, I was able to purchase everything locally. This is the third one I’ve installed but FINALLY on my own bus. Only took two hours in the back yard start to finish.
BulliBill
BulliBill is offline
PostPosted: Wed Nov 01, 2023 9:39 am    Post subject: Re: Front disc brake conversion Reply with quote
I too changed over from stock drum brakes on the front of my '67 Westy to the Type E Motorsports front disc brake conversion kit that Brian offers. I saw all the great reviews, I loved the concept that the list of possible wear parts (rotors, calipers and pads) could be found easily and quickly most anywhere if/when needed, that those parts were from heavier cars and are robust and more than needed to consistently stop a Transporter quickly and straight as an arrow, and I found that the instructions with photos were well written giving me the confidence to tackle the job (disc brake work - which to this point I have never dabbled in) with the tools I already have in my shop. And I admit that the very reasonable cost was also enticing.
I ordered the optionally offered new dual-circuit master cylinder with reservoir, as well as a second complete set of Brian's bearing/seals just to carry on-board if ever needed 'em long into the future.
Everything went together beautifully, and appears to all to be the stock front braking system unless they crawl under the Bus to take a look. Which they usually do, as I brag about this safety upgrade to all of my Bus friends!
It's such a relief to be sailing along at speed toward an intersection and knowing that if the streetlight turns yellow that I won't need to panic stomp on the drum brakes and grab for the e-brake handle "just in case" to stop in time. Luckily after only having the disc brake system installed for about two months now I have not yet needed to make any panic stops, but this system seems very up to the challenge!
"Two thumbs up!" Thanks Brian!
Bill Bowman
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
early
early is offline
PostPosted: Sat Nov 04, 2023 7:45 am    Post subject: Re: Front disc brake conversion Reply with quote
I too just installed the type e kit on my 67 so42.
Very happy with it, easy, straightforward.
However the rear seal is a little tricky and you must be careful to insure
The seal lip is maintained and not folded over upon installation of the rotor. Take you time .
The seal lip has a small round spring that holds it in place.
From bullibill photo above it appears the seal is installed inside out. ??
My photos .
early-
Barnfind westy project
my 73 sports bug project build
http://www.thesamba.com/vw/forum/viewtopic.php?t=497088
Current Projects :
73 Sport Bug - L13M gone now
67 Westfalia
57 oval window ragtop - sold june 2021
61 sedan
68 Corvette Roadster - Small Block, 4 Speed
86 GMC Sierra Classic- 4x4, Shortbed
94 Harley Flstn
early
early is offline
PostPosted: Sat Nov 04, 2023 8:18 am    Post subject: Re: Front disc brake conversion Reply with quote
Maybe we can get Brian e to comment.
I want to make sure I have installed correctly as well.
Thanks..... early
From the installation instructions:
"Last, lube and install the wheel seal into the back of the rotor. The seal might look backwards, but it is correct. Make sure the wider part of the tapered rubber lip is facing out. It will need to be able to slide up onto the wider shoulder at the base of the spindle snout. "
"Pack and install the smaller outer bearing in the hub.
-Carefully slide the rotor over the spindle shaft, and rotate it as it gets near the end to help the seal onto its surface. Pay attention to the wheel seal, and make sure it goes up over the large diameter shoulder on the spindle spud. "
early-
Current Projects :
67 Westfalia
61 sedan
94 Harley Flstn
BarryL Premium Member
BarryL is offline
PostPosted: Wed Nov 08, 2023 10:30 am    Post subject: Re: Front disc brake conversion Reply with quote
So which way is correct?
Bill Bowman
Page 46 of 48
